Question about GE WBB4500EWW Top Load Washer
Top Load washer Noisy
My top load Ge washer sounds like the tub is not connected all the way to the rest of the washer.  When in the wash and spinning mode it is very noisy.
  • cuongvan3 Dec 14, 2008
    the wash and spinning mode it is very noisy, shaking, vibration and moving.
  • GE Master
  • 5,568 Answers
Most washers are suspended from thick rubber bands and they do decay after years.
You may need to pull the back off (~ 6-10 screws) and watch with a flashlight while it runs to see which has failed.
Posted on Sep 23, 2008
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
It is starting to squeak and was wondering what you suggest I do to fix it p
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
Apr 02, 2015 | GE Dryers
My washer is very very loud during its spin cycle
There are a number of things that can do this. For a top-load machine, an out-of balance load can get noisy. Many GE washers have bungee-cord type straps at the top of the tub to dampen out-of-balance gyrations. If these break, you get a lot of rattling. Other washers (some older Kenmore models for example) have a spring-and-bar arrangement under the tub. If this freezes up due to rust, or something breaks, your washer will bounce a bit. Older Maytag washers may dance around if the baseplate is worn out. In all washers, bad tub bearings can make a racket; you will often have leakage as well.
Sep 09, 2014 | Washing Machines
Tub is out of balance; how can I fix this?
Ge has stabilizer rubber straps at top of outer tub remove front of washer remove 2 1/4 screws to remove top 5/16 screws hold 4 corners of top rim and 1/4 in scews under top frame replace all broken stabilizers then your problem should be fixed if still loud you may have bad trans
Jan 30, 2013 | GE WHRE5550K Top Load Washer
My GE top loader leaks at the spin cycle when it is letting out the water
Sounds like the tub seal under the tub where the transmission goes into the tub. Replace the trans and seal.
Mar 15, 2011 | GE WBSR3140DW Top Load Washer
Top load washer filling, emptying but tub not oscillating or spinning. Motor sounds like it is running fine. Colin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 27, 2010 | GE Washing Machines
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
GE Top load washer 15years old. noisy when spinning
washer making a load cluck noise when the spin cycle starts.
It only happens when the motor turns slow for the first minute during the spin cycle. Otherwise it works fine.
if the motor is proper then the bearings in the motor got rusted and that needs replacement.the beasrings are located on the back of the motor.
Apr 03, 2009 | GE WVSR1060A Top Load Washer
Noisy clothes washer
I am thinking there may be an object caught between the inner and outer tubs...perhaps something came out of a pants pocket and was "flung" overboard into the outer tub. If you remove the top, and push the inner tub (moving tub) to one side, look with a flashlight for a foreign object. the noise will be fine until high speed kicks in and begins to disturb the sleeping object into a frenzy.
Jul 25, 2007 | GE WHRE5260E Top Load Washer
GE WBB4500EWW Top Load Washer Logo
189 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
