Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Whirlpool lte5243dzo washer combo thin-twin
Stopped working with water in it when I stopped it at the rinse cycle like I usually do.When I turned it on again it did not come back on in any cycle. please help me.
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
LTE6234 Whirlpool Twin Thin Timer Broken?
Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
How can I fix my whirlpool thin twin washer?
It almost sounds like your motor is kicking out on overload. The fact that it starts agitating after the fill can rule out the pressure switch. You have installed a new timer so we should be able to rule that out. It's possible that your pump is binding, which is attached directly to your motor and causing it to overheat. To tell for sure you would have to check the motor to see if it's getting power when it cuts out. Check your terminal block where the power cord comes in to see if all connections are secure. Other possibilities could be the clutch and brake assy. With out being there too see the problem, this is where I would start.
Apr 27, 2006 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
544 people viewed this question
Dan Webster
Dan Webster
Sal De
