Question about Remington 16" Electric Chain Saw Assembled 3.0 Peak
Chain Saw will not start
I have a Remington Type "EC9" 12 amp, 16" bar chainsaw, Model LD 3516AWB. I plug it in but it won't start. Is there a safety or kill switch that I am overlooking? Any ideas on why you think it will not start?
Thanks. Al
  • IMGAR Mar 23, 2009
    I am having the same problem. It was working fine and then it would not start
  • 10865 Answers
SOURCE: replancement bar for 16 inch remington chain saw
The bar is the piece of metal that the chain goes around. This link has lots of info on your saw http://www.remingtonchainsaw.com/chainsaw.html
Posted on Apr 01, 2009
firesnake09
  • 2923 Answers
SOURCE: Owners Manual for a Remington 2.5 HP 16 '' Chain saw, Model EL-7
Kindly check this link for manual. Please select the correct model:
http://lawnandgarden.owneriq.net/manuals/mfg/remington/remington_chainsaw_product_list.html
Posted on Apr 18, 2009
dontbother10
  • 2220 Answers
SOURCE: where can I find a bar & chain for a remington
You provide no model number for your saw. What is pictured is a RPS96.
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" (RPS96) into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
There are 8, 10, 12 and 14" chains on the IPB depending on the actual model pole saw. RemingtonPower is no longer in production, and parts are often difficuilt to find. All 4 chains listed are available and range form $12.92 to 15.95 plus shipping and handling. You can take your saw (or just the chain) to a local saw outlet and have one fabricated in about 5 minutes. It is rarely more expensive at a local outlete and you save shipping and handling fees. HTH
Lou
Posted on Jan 26, 2010
dontbother10
  • 2220 Answers
SOURCE: need new chain for remington pole saw, model
It should, I have been on this earth to long for a definate answer. Both saws have 40 drive links, are 3/8s, and a gauge of 0.050. Please verify my findings here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Have you contacted a local saw shop? With your chain as a pattern they can make a replacement in couple of minutes. Inquire by phone about a price you may be pleasantly surprised. Give them Oregon number 91VG040G (low kickback, most likely what your saw is fitted with). If you feel adept you might try a slightly more agressive chain but the odds of kick back increase. HTH
Lou
Posted on Feb 06, 2010
Testimonial: "thanks, chain went on easy, worked great"
  • 5603 Answers
SOURCE: 16" remington chain saw - model 111174-01- this
If it is very old, the fuel pump diaphram and flap check valves MAY have deteriorated even without fuel in the saw. You might want to rebuild the carb.
Posted on Jan 31, 2011
What type of oil does remington 3.5 electric saw use
Use regular chain/bar oil available from home centers, hardware stores, and saw dealers. Hope this helps!
May 30, 2010 | Remington 16" Electric Chain Saw
Looking to download manual for Remington 16" 3.5hp chain saw.
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 03, 2010 | Remington 16" Electric Chain Saw
Where can I find a chain saw blade for my remington 3.0 16 inch bar for my electric saw?? m30016us
Your data gave me bar pn 540530 (solid nse 16" bar). There is a dealer locator on the lower right corner of the guide.
Lou
May 02, 2010 | Remington 16" Electric Chain Saw
Where can i find a 16" blade for my remengton electric chain saw. part #097572-03s
Afternoon Lionel;
A replacement bar can be found here:
Remington.com
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
Your part number returns replaced with;
Part #: EL16SB Price: $22.88
Description: BAR REPLACEMENT SPROKET NOSE HEAVY DUTY
or
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
Part #: EL16SB DESA SPECIALTY PARTS: BAR GUIDE 16IN (107704-02) (REM-SH5) $22.99
or
This is worth a look IMO, given an Oregon part number you may find a local source (often saves shipping and handling fees).
Select "Remington; YourSawModelNumber; 16; All; All; All".
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 06, 2010 | Remington 16" Electric Chain Saw
What type of oil is used in the remington 16" chain saw?
From page 9 of a M12510US (bar oil is SAE 30 with additives to help it adhere to the bar and chain):
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE #30 motor oil. Note: For temperatures below 30°F, use SAE #10 oil. For temperatures above 75°F, use SAE #40 oil. 3. Replace oil cap at once. Tighten oil cap firmly for good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
Note: It is normal for oil to seep when saw is not in use. Empty oil tank after each use to prevent seepage.
This is one of the most complete "Owners Manuals" Remington offers. If not your saw you can find your manual here:
Remington.com
  • Type "YourModelNo" into the "Model #:" window, then click search.
HTH Lou
Jan 23, 2010 | Remington 16" Electric Chain Saw
The chain came off of my Remington 16" electric saw. How do I put the chain back on?
If the saw was at speed when the chain came off there are probably burrs on the chain drive links (the part that goes in the bar). They often cause binding and in extreme case may cause the chain to ride up and off the bar when operated. Use a file on the drive link flats to remove all burrs.
An Operator Manual far almost all models of RemingtonPower chainsaws can be found here:
Remington.com
HTH
Lou
Dec 28, 2009 | Remington 16" Electric Chain Saw
No manual / chain came off ; need to put back on model ld4016aw remington
I couldn't find your model number but did find an "Owner's Manual" for a M15014US. The chain installation should be similar.
In the "Search for your unit by Model #:: window type & enter "M15014US" search.
Click the "View Model" link to the right of "M15014US - Remington Electric Chainsaw"
Click the "View Owner's Manual" link.
The chain atop the bar needs to be like page 16, figure 25 or it is installed backward.
You can save the Owner's Manual and the Illustrated Parts Diagram. I recommend you do. HTH
Lou
Nov 03, 2009 | Remington 16" Electric Chain Saw
What type of oil do i use in my remington 3hp electric chain saw
According to the manufacturer... Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil.
Apr 23, 2009 | Remington 16" Electric Chain Saw
Replancement bar for 16 inch remington chain saw
Mar 31, 2009 | Remington Electric Chain Saw
What type of oil do I use for a Remington Electric Pole Saw?
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
Mar 13, 2009 | Remington 16" Electric Chain Saw
Remington 16" Electric Chain Saw Assembled 3.0 Peak Logo
95 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
