Sony Grand Wego - Sound but No Picture
I have had this tv for three years with no trouble. I blew a fuse the other night and after switching it back on everything worked well. When I whent to turn tv off that night when I powered down picture wnet away but Video 1 remained on the screen. Turned on and off again from the tv itself. My problem is the following day when I turned the tv on there was sound but no picture at all. Checked connections with DirecTv and seems okay. Unplugged to try and reset the tv (as described by Sony) but no luck. I thought my cat unplugged something but I think that is wishful thinking. There is no lamp light in the front so I don't think that is my problem. Have you come across this problem or have any suggestions?
  • 1 more comment
  • csalvado Sep 23, 2008
    The model number is KDF-E50A10
    The only light in the front is the "on" light and the blinking "stand by" light that seem to be functioning normally. I wonder if it would benefit me to unplug everything that is going through DirecTv, DVD, and VCR and see if I can get a snowing picture just by running it directly to the outlet. Thank you for your reply and for your assistance.
  • csalvado Sep 24, 2008
    Thank you for your reply - blinking lite is not continuous. Seems to blink about 8 times before tv will power up. I will have to count them and get back to you later because I am not at home right now. It also does this when you turn the tv off. Seems to be an initial standby mode while tv is turned on or off. The blinking is not a new symptom and has always done this.
    Thanks!
    It definatley is not an on and on and on blinking light. I'll have to confirm the amount of blinks and get back to you perhaps around lunch time. I tried playstation hoping to divert going through DirecTv in case the wiring was loose or dislodged. Of course there was sound but again no picture.
  • 4,234 Answers
Before I commit myself, I need a little more info. First, what is the model number? Second, in the front there should be a standby light. does it blink at all? It should blink in a repeating pattern. If so, please post that too.
Thanks,
Dan
Posted on Sep 23, 2008
  • ABRsvcs Sep 24, 2008
    I have examined the owner's manual for this set and if you are getting a blinking standby light, it should be blinking a code. All indications for lamp replacement etc. are not present based upon your description of the problem. Can you count the blinks please? If it is just a continual blink, that too is good to know. It sounds like that is the case here. Can you confirm that please?
    Thanks,
    Dan
    Close. The light will blink for a while before the picture snapps on. That is normal. The blinking now should be a count followed by a few second pause then the count again, on and on and on. The 8 is important if that is the correct count. If it is, the problem is in the power supply and can easily be fixed. Update this and I'll look up the parts in the meantime.
    Dan
Tail lights work fine but no brake lights. Fuse keeps blowing whenever I replace the fuse.
check wiring on shift columb going to turn signal switch it could be the switch it self I had this happen on a new chevy truck hope this helps good luck jerry
Feb 16, 2013 | 2001 Jeep Grand Cherokee
Picture and sound shut off, blinking green standby
MY SONY PROJECTION TV WENT BLANK WITH NO SOUND GREEN LIGHT WAS ON WHATS WRONG
Oct 14, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Picture wnt out suddenly without any symptoms
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!!
Apr 13, 2009 | Curtis CM32020S 32" TV
Tv turns off and on
The first time my lamp needed replaced, the red light came on as well. This time my tv did the same thing, but after talking to my tv repair man he thought it was the lamp. He said that if you use your tv often then the lamp probaly needs to be changed after two or three years. I replacedmy bulb and it corrected the problem and I MUCH BETTER PICTURE.
Dec 29, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Standby/stereo light blinking no picture or sound
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!! My TV is 9 years old.
Aug 31, 2008 | Sony KV-36FS100 36" TV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony wega KF-50WE610 went dark...
If you have not changed the lamp in the 4 years you have had the tv you will need one soon if not now. is sound from tv or receiver, when the lamp dies usually no sound from tv. If you have sound from the tv try unpluging power from wall to reset and try again
May 16, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony wega 42inch
Power surge has damaged power supply, have serviced
Apr 22, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KDF-60XS955 60 in. Rear Projection popped and turned off
the reason your lamp blew so quickly is the the lamp fan has become cloged with dust. this is a known problem by sony and I have done 15 or so of the up grades needed. first look at the lamp door is it discolored and warped. if so have a tech order the up grade kit which includes a new door, siraco fan, thermal fuse, and lamp. the return fan may also be needed. also some service menu changes need to be made with the fan voltages of fan 1 and fan2.
Feb 22, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
