Diagram for s plan central heating control cicuit plus frost stat
2 Suggested Answers
SOURCE: keston c40 honeywel 9400c programmer
do a s plan plus and buy a poly plumb roomstat combined programer with built in relays as you require the relays to stop back feed! simple!
Posted on Jul 23, 2008
My Baxi Combi 80e boiler turns the heating on randomly. With the wall thermostat turned down and even with the boil switched to hot water only the heating still fires up when unwanted.
If the thermostat wire run passes anywhere through, beside or inside any metal surfaces and the wires touch any of the metal its the same as if you turn the stat to on. I've seen this a few times. Easiet way to detect it, if its inside the house is at night in the dark. Look around when its doing this you may see the small spark when it goes on. Otherwise you will need to inspect the entire run from the stat to the untis, etc.
Jun 23, 2014 | Heating & Cooling
Rehema Boiler-central htg switching on when boiler is off on the programmer
frost stat could be set to high if you have one / or is boiler fited in a cold spot ?
Apr 02, 2012 | Heating & Cooling
Connect my 24 milivolt gas (between the studs) wall furnace ( in my hall) to my thermostat that operates my electric heat central unit. problem: to sync both units to give home more balance ( hall is...
the first problem is you need a milli-volt t-stat and your central has a 24volt t-stat if you connect the 2 it will fry the controlls in the wall heater the second problem is t-stat location if the wall heater is near the central heats t-stat it will shut off the central to soon . maybe relocate wall unit to coldest room ?
Nov 16, 2010 | Honeywell Heating & Cooling
I have a Goodman airhandler model #A24-10, serial #9305071035 and can not get fan motor to cut off except by turning off breaker. Ihave replaced two sequencers and checked out all 24volt wires to...
Let me know if this is the diagram u looking at?
Jan 05, 2018 | Goodman Heating & Cooling
Hi, I have just replace the room thermostat on my oil fired central heating system it is an RS1, which requires only 2 connections plus an earth. I had to get this one as the flex from the stat to the...
Well in your case,if the central heating was working before you change the defective thermoatat.Phaps you have done the wrong connection of the thermostat,if you look well at the connection of the thermostat, how will you recognise the earth borne is that it is fixed to the body of the part,so this means that the thermostat 3 cores are (1) common,(2) normally close,(3) normally open.With a multimeter it be very easy to determine the core that you have to cannect.
Oct 04, 2009 | Plumbing
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
Wiring diagrams schematic (boilers)
call me alan 0776 7494009 have books on c, s,y plans
Mar 04, 2009 | Cooper Wiring Devices 1301-7B GROUNDING...
Wiring a Drayton Room Stat into central heating system
Oct 26, 2008 | Water Heaters
Heating & Cooling Logo
540 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
