Question about Xerox WorkCentre Pro 412 All-In-One Laser Printer
Xerox 412 I put in a new drum and apparently it wasn't in all the way---I made a copy which caused toner to distribute all over the drum--I took a Q-tip and wiped it off--put it back in---I took out the 2 screws to the fuser assembly and removed the paper jam. The machine works, but its' making a rattling noise and the copies have a section down the center where its darker---(toner on the drum?) Do I need to replace the fuser, drum, or both? Also can't figure out what the rattle is coming from.
  • d920 Sep 24, 2008
    Thanks so much for all the great information and quick response. Apparently we do only have 2 screws holding in our fuser assembly---from what I was told when someone worked on the machine in the past thats all they put back were the two. We were getting the "ghost" image down the center---that's why I replaced the drum thinking that may be the problem. The reason I thought the drum was in all the way was because the old drum just pulled right out--but the new one had to be snapped into place--so I had put it in as far as it would go without really forcing it and it obviously wasn't far enough and everything escalated from there. Now back to the noise---maybe a rattle is not a good description---we checked the drums gears and that wasn't it (I actually put the old drum back in and it still is making the noise). It's hard to describe other than it has a consistant rythm to it, but gets louder the more copies we make. Almost like something is in there that shouldn't be!?! It reminds me a little of the sound that was made when kids would ride their bikes with a playing card clipped to the spoke of their bicycle tire--just not that fast--similar to that just to maybe give you some kind of comparison.
    So it sounds like if I would have replaced the fuser assembly first all this could have been avoided.
    I will order a fuser assembly today--and if you have anymore thoughts on the noise I would appreciate hearing from you.
    Thanks again!
    President:
  • 2,072 Answers
This post is loaded. First of all, there should be 4 screws holding in the fuser. Unless you are talking about removing the 2 screws that hold the pressure and heat roller together in the fuser. 4 screws hold the fuser in the machine, 2 screws hold the fuser together. I am not sure exactly if your fuser was mounted to the machine with only 2 screws, or if that is an accurate post and you removed the 2 screws that hold the fuser frame together. Either way, I seriously doubt the noise is coming from the fuser itself.
Now, the darker section down the middle. I would suggest taking the fuser back out of the machine and looking at the black heat roller in the fuser. If it is not clean and shiney, and has a rough texture to it in the middle, that roller is bad and will require replacing the fuser.
What I am curious about is, the rest of the copy. Is the copy fine outside of the middle? If so then the fuser should fix it. Note if there is some reprint, sort of ghost print in the middle of the page.
The rattle may be the gear on the back of the drum cartridge, It is a small gear that drives the cleaning roller. Pull out the drum and look on the back, there are 2 small gears on the back . One of them may have broken a tooth and is jumping and not rotating properly.
Another problem, as I read this may be the toner cartridge not having the ink distributed properly, To eliminate the toner cartridge as the problem. Remove the toner and look at the roller on the front of the cartridge.It shoud have ink distributed evenly across that roller, No streaking, it should be a dull black fuzzy apperance across the roller.
Firstr check the middle of the fuser roller for the wear I described. Then the back of the drum for the noise, then the toner carteidge for distribution.
If its not fixed yet, let me know. We can discuss the laser and scanner issues. But those are far less likely.
You posted a good one...
Posted on Sep 24, 2008
  • Rick Kasper Sep 24, 2008
    If you want, you can just replace the heat roller. Its a lot cheaper, and not to hard.
    If you want to, log onto google and look up "the parts drop": It should be the first item that pops up.
    Call them and ask for Britt, he has just the roller and probably would send directions to replace it.
    I don't work there, but have done business with them for years, They are honest and very helpful.
    Yeah, that is your problem. that will occur on a 412 approximatly eery 30-40 thousand pages.
    You can replace the black aluminum roller probably 4 times before needing to replace the fuser.
    I would suggeswt cleaning those little pointed fingers that rest on the heat roll. They build up toner and paper dust and can cause jams.
I have a Xerox XC820. I am getting dark copies with residual images from previous copies. Toner appears to be adhering to the drum cartridge. Do I need a new drum cartridge?
I have a Xerox xc820. The drum kit needed to be replaced, which I did as well as put in a new toner cartridge. The pages are now coming out very dark. Prior to putting in the new drum kit and new toner cartridge, the machine ran fine. I have tried all I know how to do and to no avail. Have cleaned the "wire", all the parts I can get to and cleaned the plate. Any help would be appreciated.
Apr 21, 2012 | Xerox Office Equipment & Supplies
Xerox M15i uneven print and photocopy quality. Center of the page is darker than edges. I have run the clean drum, put in a new toner cartridge.
If the problem appears BOTH by copy and print situations, the problem is the drum unit itself.
Unfortunately you have to buy a new drum assy.
Sep 04, 2010 | Xerox Office Equipment & Supplies
Just purchased a Zerox XC1255 Copier at an Auction. Replaced the toner cartridge because the light was on. The copies seem to have excessive toner in the background of the copies. I am wondering if I...
Could be a bad drum unit. Is the new toner cartridge a refilled? Remanufactured? or Brand New Xerox brand toner? If it is refilled or remanufactured I would run some copies and give it a chance to clear. Sometimes they end up with too much toner in the Developer mix and can be overtoned which causes a general background over the whole page. They should clear up as you run copies, say within 100 pages. Also try manually lightening the copy with the exposure control on the operation panel. If lightening the copy clears all of the background then you need to have the optics cleaned. There are 4 mirrors under the large original glass that need to be cleaned. If all this fails then you are looking at either drum unit or a defective or out of balance toner/developer cartridge.
Good Luck and Thank You for using Fixya.
Aug 18, 2010 | Xerox Office Equipment & Supplies
I have a new drum cartridge and a new toner and the copies ares so dark you can not read them. Does anyone know why this is?
did the tech put the charger or charge roller back in... if not then this is quite possibly the cause...
Dec 28, 2009 | Xerox 8830 Copier
Xerox WCP 416 , it showed message replace drum cartridge
It sounds like you are replacing the toner cartidges NOT the Drum Unit. Drum is located behind the toner cartidge and you will see it after removing toner. Pretty common mistake :)
May 12, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
Copies of xerox copier model 5201 almost black
USUALLY Black copies are a Drum grounding problem. I have not seen "black" copies due to old, bad, or otherwise inferior toner... Although, It is a Xerox, LOL
Apr 03, 2009 | Office Equipment & Supplies
Xerox 5305 copier excess toner
sounds like faulty drum cleaning blade,which is usually contained in the replacement drum module.I would be inclined to take the drum unit back where you got it (unless you replaced it with a second-hand one) 99% certain the problem is contained in that module
Feb 27, 2008 | Xerox 5305 Copier
Xerox WorkCentre Pro 412 All-In-One Laser Printer Logo
168 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
