Cyberlink capture device
I have a friend using your software for video editing, if I try to use their webcam on MSN I recieve a cyberlink panel and the message no capture device available. Is there an easy option for avoiding th=is issuee
  • 2 more comments
  • bonsaichris Sep 25, 2008
    Hi,and thanks for the info. Unfortunately I did not make my self very clear. The webcam link is only a problem if cyberlink is either in use or has been used during the current session. If they reboot and dont link to cyberlink there is no problem. It appears an issue directly relating to there webcam lnking to me via cyberlink
  • mathew1981 Dec 21, 2008
    I am having this HP Laptop and i am not able to view any video on my Cyberlink YOUcam as well as in any Messenger (Yahoo, Google, MSN). The message which comes up is "There is no available captured device". Can someone please help me?
  • Anonymous Jan 11, 2009
    I can't use mi webcam when I'm using Windows Life Messenger. I try to configurate my webcam, but I can't change anything. And I also try to change where it says AveoCap, but it is useless. HELP!!!
  • Anonymous May 03, 2009
    benim bilgisayarımda da aynı problem var ne yapabilirim
  • 258 Answers
Maybe the webcam driver is not installed or the webcam is not configured in msn check if the webcam is properly installed in device manager if there's a question mark around the webcam icon the webcam must be installed properly
Posted on Sep 25, 2008
    Problem Solver:
  • 5 Answers
The web cam maybe disabled in device manager chek it out
Posted on Aug 04, 2010
Fh13ff-238 fault
Get the webcam software from the website. If they have windows 7 software supported you should be fine. It they are giving software for windows xp only then it will not work. Bottom Line go on the website and install the webcam software again.
May 17, 2014 | Fujitsu Computers & Internet
Error during capture error code 800706f8
The very first step is of course to check your webcam connection. Most webcams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in webcams this steps does of course not apply. Many new laptops have a build-in webcam. Also try connecting your webcam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
windows-xp-other-device.jpg If the device is not recognized in Windows XP, it will be listed under Other Devices.
windows-vista-device-error.jpg In either case you can try to update the drivers. Right-click the device, and in the popup menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the webcam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to uninstall the software that came with your webcam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party uninstaller.
After uninstalling the software, restart your PC and then reinstall the webcam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your webcam during the software installation.
If the drivers and webcam software are correctly installed, and you still cannot see any video, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the webcam feature. If you have multiple devices that qualify for video, you might need to select your webcam device as the source for the webcam feature in that program.
Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
Lastly, if your webcam's image is not sharp, check to see if it has a focus ring. A blurry image can sometimes simply mean the webcam is not in focus. Adjusting the focus through the ring can solve that problem.
Other picture quality problems with webcams can be addressed by changing the video capture properties for the webcam. Most programs that can use a webcam will have an option to access the properties of the video source, which will bring up the video capture properties window.
video-capture-properties.jpg Do keep in mind that not all settings will be enabled depending on the webcam and the webcam driver installed on your computer. In the example you can see that some settings are disabled. The example shows the video capture properties for an Acer Crystal Eye webcam.
What else to try: download missing webcam drivers! If you are using your webcam for instant messaging with one of the popular chat programs, have a look at EatCam, which allows you to record your webcam chats from MSN, YM, ICQ, Skype, AIM and a few more!
Mar 05, 2011 | Computers & Internet
I just bought an HP notebook and I don't know how to hot to 'register' or 'turn on' my webcam.
Your computer may include an integrated webcam, located at the top of the display. The webcam is an input device that allows you to capture and share video. Preinstalled CyberLink YouCam software provides new features that expand the webcam experience.
To use the webcam and CyberLink YouCam software, select Start > All Programs > CyberLink YouCam > CyberLink YouCam.
note.png NOTE: The first time you access the YouCam software, you may experience a brief delay as the software loads.
Using YouCam as your default webcam software enables you to experiment with the following features:
? Video-Record and play back webcam video. You can also e-mail or upload video to YouTube, using the icon on the software interface. ? Streaming video-When you open your instant message program, YouCam displays a floating toolbar that lets you add graphic effects. ? Special effects-Add frames, filters, and emoticons to your snapshots and video. ? Snapshots-Take single frame or "burst" webcam shots in rapid succession. ? Connect-E-mail photos and video using the icon on the software interface. note.png NOTE: For details about using webcam software, refer to the software manufacturer's instructions, which may be provided with the software, on disc, or on the manufacturer's Web site.
Dec 19, 2010 | HP Pavilion dv6000z Notebook
I dont know how to install my new lifecam !
Set Up and Use the VX-3000 personal web camera
  • 1 Install the software using the included CD and plug the LifeCam into a free USB port. For desktop use, place the LifeCam on a clear spot on your desk that's free of other objects, including cables. The camera should not be more than an arm's length away from you. For LCD (or similar object) use, push the center part of the camera's base upward, place the camera on the LCD and close the base around the monitor to secure it.
  • 2 Open the device software by clicking the Microsoft LifeCam icon on your Windows desktop. If no such icon exists on your Windows desktop, click "Start," click "All Programs" and locate the Microsoft LifeCam program in the list of programs there. After launching the LifeCam program, look at the image that appears. If necessary, adjust the camera to more precisely reflect your appearance. For best results, try to center the camera image on your head and shoulders.
  • 3 Click the video camera icon on the bottom panel of the LifeCam program to begin video capture. Video will begin recording, and you will see a "Recording Video" message beneath the live video image. To stop recording, press the same icon (the icon will have a red square with a blue background during recording).
  • 4 To begin audio capture, click the microphone icon on the bottom panel. To stop the audio recording, click the same icon (again, it will have a red square with a blue background during recording). To snap a photo, click the camera icon on the bottom panel.
  • 5 Access any of your captured video, audio or image files by clicking the folder on the bottom panel. The VX-3000 also provides the ability to edit video or image files using supported software. After snapping a photo or capturing video, click the "Edit" icon that appears beneath the thumbnail of the captured content.
  • Oct 09, 2010 | Microsoft LifeCam VX-3000 Web Camera
    Hp pavillion tx 2000 webcam drivers
    This package provides the Cyberlink YouCam Software for the supported notebook/laptop models and operating systems.
    Cyberlink YouCam is a webcam application that enables the capture of images and video from a web camera. Cyberlink YouCam also enables users to apply visual effects on captured images and video.
    Cyberlink YouCam Software for HP Pavilion tx2000 CTO Entertainment Notebook PC
    Dont forget to rate if this is helpfull.
    Sep 17, 2010 | Computers & Internet
    Webcam being used by some other unknown software.
    You will have to reinstall the Camera Driver. Uninstall the Camera Driver from the Device Manager and then reinstall it. Also, install MSN once you reinstall the Camera Driver.
    Jul 13, 2010 | HP Computers & Internet
    Will not work with MSN Messenger
    Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
    If it fails to work here concentrate on your webcam drivers and software before moving forward.
    Set your webcam mic (if it has one as default)
    Vista -
    Having proved your cam is working ,you can configure it to WLM (MSN)
    Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
    The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
    Mine, I just unplug it from the USB and plug it back in to reboot the software.
    If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
    Open MSN
    Click 'Open Menu'
    From 'Tools; navigate to, and click, 'Audio and Video setup'
    Set your speakers
    Click 'Test' - if OK, move on.
    Set your mic as default
    Use the slider to set volume and test.
    Click 'Next'
    This takes you to the video setup
    Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
    Use 'Webcam Settings'to fine tune the picture.
    Click 'Finish'
    Jul 01, 2010 | Logitech Webcam
    How to use compaq 510 notebook pc webcam without im service
    HP provides Cyberlink Youcam software free with laptop factory settings
    Click Start button
    Type youcam
    click the exe file
    view, capture image or video, save, etc.,
    If you cant see any file download this software
    Oct 10, 2009 | HP Computers & Internet
    I am unable to connect to friends webcams. I see that my Cyberlink webcam is downloaded with no problem & she feels hers is downloaded. I have a messanger account. Any thoughts
    Have you tried using Yahoo or MSN messenger itself? They both support webcam use.
    For more webcam troubleshooting, please check this How to fix webcam problems article. Might be network related, but I do not know which ports Cyberlink uses.
    Feb 23, 2009 | CyberLink PowerProducer 2 for PC
    Cyberlink YouCam Problem
    Can you please explain your problem in brief like exactly what is the problem with your Cyberlink Webcam or is it a problem with the Cyberlink Software.... Please don't hesitate to contact me to help you in a better manner
    Dec 10, 2008 | Computers & Internet
    Computers & Internet Logo
    7,097 people viewed this question
    David Payne
    David Payne
