Question about Zyxel P660HW-D1 Router
Internet going off
My zyxel router keeps going off at set times like every night ill be on xbox live and my internet light on my router will just go off lke 20 seconds later it comes back on but thats after im kicked out of a match and that please help im sick of it i got told that it might be people on my street. Im wired up not wireless would that make a difference
  • argwat Oct 21, 2008
    I have the same problem with the router suddenly restarting for nor reason and I have VOIP connected to it so I often get cutoff in the middle of conversations.
  • ohcirej1 Oct 22, 2008
    Similar problem, router keeps forgetting some setting or another and won't connect. Have to mess around in diagnostics, switching on and off etc. Usually have to plug into to another switch port on the back, reboot etc and then it comes back. Very unreliable. Windows Vista system.
I got same problem with Zexel P660HW-D1.
I guess its because hardware is very warm, can be that it overheat.
No idea, what can be solution, I just updated firmware, lets see is it going to help.
Posted on Nov 08, 2008
How do I use my router so I can open NAT on my xbox for xbox live?
1 Make sure your ZyXEL Device hardware is properly connected (refer to the Quick StartGuide).2 Prepare your computer/computer network to connect to the ZyXEL Device (refer to theQuick Start Guide).3 Launch your web browser.4 Type "192.168.1.1" as the URL.5 A window displays
6 For administrator access enter the default admin password 1234 to configure the wizardsand the advanced features.(or if you already changed your password, enter that password)7 On the right hand side of the screen you will see a drop down menu. click on NETWORK. 8 Then click on NAT.9 Find the area to configure Port Forwarding.10 The ports that Microsoft recommends to be open are:88 UDP3074 UDP3074 TCP
It also looks like you will have to set up a static address (I was looking at the .pdf for your particular router) You can do this by editing your network setting on your XBOX console, and then using this address as your "server" address when opening the above mentioned ports on your router.
ftp://ftp.zyxel.com/P-660HW-D1/user_guide/P-660HW-D1_3.40_Ed1.pdf
Nov 29, 2011 | Zyxel P660HW-D1 Router
My xbox is connected to my internet via connecting my xbox to my laptop. I tried changing the nat settings by doing all the methods, you name it: port forwarding, DMZ, UPNP, and it STILL DOES NOT *******...
I know what you're going through as it is common on Belkin routers. There are actually some good solutions to this found on youtube for simple instruction to help demostrate but I'm gleaned you already have done some of the advanced steps. Here is my question did you ever set your xbox 360 with a static ip address and then add it to the firewall/virtual server settings. You put the static ip address in and the xbox 360 ports.
Dec 22, 2010 | Zyxel P660HW-D1 Router
NAT settings
A good reference for you can be found here:
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/eMule.htm
Click on Network > NAT > Port Forwarding. Set up the range of ports, and call it Xbox or something. Or, you can disable the Firewall, but I wouldn't recommend this. Hope this helps!
Oct 20, 2009 | Zyxel P660HW-D1 Router
Cant connect to xbox live.. I have my Motorola surfboard SB 5102 modem connected to the zyxel 660 router which is connected to the xbox. It says IP address not found" and sometimes, it passes the network...
Sorry if this sounds stupid.
It sounds to me like you are using your own dongle for the xbox connection yes??
Unfortunatly you have to buy one of the xbox 360 wireless adapters ..( £40.00 last time i got one)
Also have you tried setting up your connection in the menu screen
I cant guide you thru cos im slackin off work exp at BAE lool ^_-
Jul 06, 2009 | Zyxel Computers & Internet
Change NAT from strict to open
You need to do port forwarding on your router. First, you must setup a static IP address on your XBOX. Then You must open these ports on your router setup page using Port Forwarding feature. 80 TCP and UDP, 53 TCP and UDP, 3074 TCP and UDP.
Jun 01, 2009 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router wpa
you can access the router's setup page to retrieve your wpa key. just type http://192.168.1.1 on the address bar of your web browser. you will be prompted to enter the router's password, by default it's 1234. now go to the wireless settings of your router and look for the wireless security and there you will find your key.
hope this'll help you
ciao
Nov 09, 2008 | Zyxel P660HW-D1 Router
Ip address
try resetting your router & modem.unplug modem,unplug router....plug up your modem wait 4 all the little lights 2 light up & then plug up your router.if that doesn't work i don't know ;)
Feb 16, 2008 | Microsoft Xbox 360 Console
Set nat to open
These routers have a setting underneath the advanced tab (within advanced setup) called UPNP.....all three of the active tick boxes need a tick in (by default they don't) and this will sort the NAT stuff out.
Jan 19, 2008 | Zyxel Prestige 660HW Wireless Router...
Strict NAT setting on XBOX 360
my zyxel keeps losing internet conshone
Jan 09, 2008 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router Logo
305 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
