Question about HP LaserJet 1320 Printer
Hp laserjet 1320
The printer is pulling the paper in crooked. I've cleaned the rollers what I could see and the puller is still going in wrong. Help
  • 4 Answers
In the paper path above tray 2, there are 2 pinch rollers that sometimes pop out of place. This can be checked by removed tray 2 and looking underneath where the paper travels. You will see 2 white rollers. They should both be flat against the rubber rollers that they come in contact with. If this is your problem one or both will appear to be crooked or out of position.
Posted on Sep 24, 2008
Solucionar el problema por completo
Posted on Sep 23, 2008
  • HP Master
  • 5,568 Answers
You might try this before turning it over to the tender mercies of a tech:
Use a high-quality bond paper and remove any other sheets from the feed slot or tray; 'paint' a stripe of alcohol across the page; preferably pure, rubbing alcohol if you can't get other. Let the machine start to pull the sheet through but hold it so it can only take an inch or so before stopping; hold and release several times and hope that one of the stops is between pinch rollers that will yield up its load of paper fibers.
This is NOT a 'sure-fire' method but can often cure the problem for a while before the rollers load up with paper fiber again. BTW, 'bargain' paper can cause this to happen earlier than quality bond since it has more loose wood fiber that can depart from the sheet and build up on rollers.
My hp laserjet 1320 takes in more than one paper while printing, which get stuck.
Cleaning the pickup roller will only temporarily delay problem. The pickup roller and separation pad needs to be replaced to correct the multiple paper pickup problem. The roller and separation pad is easy to replace. These parts come in a kit caller RK-1320 the parts kit is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=71
Mar 28, 2013 | HP LaserJet 1320 Printer
Hp 1320n printer that constantly have paper jams after printing a few pages
As Vishwanathu stated first try cleaning the pickup roller. It is located on the bottom of the printer. Remove the paper tray and you will find it as shown here.
If cleaning the roller does not solve the issue then the roller kit will need to be replaced. The rubber tire gets worn down and become smooth, when this happens it can't grip the paper right to feed it into the printer. The roller kit for the Laserjet 1320 is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_42&products_id=71
I hope this helps, if so please rate my solution.
BuddyMc
Aug 24, 2011 | HP LaserJet 1320 Printer
When printing on HP Laserjet 1320 it brings the red light and it does not shows any error. no printout.
there is a paper in it's roller to remove it pull out the tonner and check the roller ther will be a paper stuck in it remove that papre printing will be contnue
Jan 19, 2011 | HP LaserJet 1320 Printer
Paper jam in hp laser 1320
Unplug the power cord and open the cover and remove toner and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Feb 10, 2010 | HP LaserJet 1320 Printer
HP Laserjet 1320 Series Printer-Grinding Noise Won't Pickup Paper
take the roller out again but this time make sure the paper sensor is in the proper place. it does go scew when putting a new roller in. It happened to me last month.
you dont need to get another printer.
Oct 09, 2009 | HP LaserJet 1320 Printer
Hp laserjet 1320 paper jams constantly. not even one page prints. what could be the problem?
could actually be the paper your using. make sure your using at the very least multipurpose paper or laser paper. check to make sure your settings for paper is also set to regular paper and not cardstock or special paper or anything else
Jul 30, 2009 | HP LaserJet 1320 Printer
HP LaserJet 1320 folds over top left corner of every page printed
I see this problem alot after a paper jam occurs and someone has pulled the stuck paper out. There is probably a piece of paper stuck in the printer somwhere. If you open the front toner door and take the cartridge out, you will see a roller at the bottom front. DON"T touch the roller but take it out. You may find the paper there!
May 24, 2009 | HP LaserJet 1320 Printer
1320 hp printer/no ink on paper
Try cleaning drum voltage contact
Sep 06, 2017 | HP LaserJet 1320 Printer
Laserjet 1320 will not pick paper
Paper misfeeds and failure to pickup the paper are both common symptoms of a worn pickup roller. This roller is on the bottom of the printer as shown in the attached picture.
With use the rubber tire gets smooth and can't grip the paper enough to pick it up and push it into the printer. The roller kit is easy to install yourself and will get the printer back going as good as new. You can get the roller kit here:
BuddyMc
Dec 05, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
100 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
