Question about HP LaserJet P3005n Printer
HP P3005 Will not pull from Tray 1
We have an HP P3005 that simply won't pull any kind of paper from Tray 1, the manual feed tray. Manual Feed is ON and Tray 1 is set to Any Type on both paper and size. You run a paper path test, set it for Tray 1 but it just sits there and says Load Tray 1 - you put paper in to Tray 1 and it still just sits there - no reaction whatsoever. You have to switch to Tray 2 to get the printing out. Any one have any ideas?
Sue
  • 1 more comment
  • ajaydikshit Nov 01, 2008
    sir I have a hp laserjet p3005dn printer.at the time of printing when all the pages finished from first tray ,the printer can't pull media from second tray.so please solve this
  • fol0699 Jan 08, 2009
    have an hp3005dn.I have always use tray 2 to print but when sending a job to the printer,the printer i looking in tray1
  • Thomas F. Schneider May 11, 2010
    I am confused . If you place a printer in to the manual feed does that not mean that you have to fed it by hand and it does not feed itself from the tray? I have a panasonic and manual feed and when placed in that position,  mean that automatic feed does not operate.
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green check until you see Information Menu. Scroll using arrows until you see Print Menu Map then press green check. If it prints from tray 1, your problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Posted on Jul 25, 2009
    Problem Solver:
  • 17 Answers
It is possible to set each needed setting up as if it is an different printer so that when you need to print to a specific tray you just pick the 'printer' that has the settings you need. We do it at the university I attend to print out textbook cards and various other letters all from the same printer, but when we print we just select a 'different printer'.
Posted on Jul 27, 2009
Solved it, if media in tray 1 is slightly curved, like labels and the slight curve up is in the centre, then it will not pick up, try putting a nice flat sheet of whatever in , and see if that picks up , ours did,
so try and keep media flat,
labels are difficult because they start to curl slightly when only a few are left, due to tempreture and the fact they are not laying flat.
Posted on Dec 11, 2009
    Problem Solver:
  • 9 Answers
Remember whatever you tell your printer to do from the PC will override whatever settings you have put in the printer control panel. Check your settings when you're printing a document. If your default tray in software is tray 2 it will not print to tray 1 no matter what you tell it to do from the control panel.
Posted on Feb 06, 2009
  • Alan B Steiner
    Alan B Steiner Nov 18, 2012
    I did this test and the printer is working fine, however what ever tray I pick in the computer... the mac be it auto or tray two, it still goes to tray one on the printer.In the printer tray two is the lower tray and tray one is the manual feed tray.
Won't print manual feed
MANUAL PRINT IS ALSO KNOWN AS TRAY 1 ON HP PRINTERS. LOAD PAPER INTO THE SLOT ABOVE YOUR PAPER TRAY.
Dec 13, 2015 | HP LASERJET P1006 Printer
Hp laserjet p3005dn printer taking 3 papers
Your problem description is not clear, but based on experience I bet that your printer is taking three sheets of paper at a time. The pickup roller in tray 2 and the separation pad in the tray are probably worn out. They are easy enough to replace. You can verify that printer works properly by printing from manual feed tray and if that works ok then above solution is likely your fix.
Apr 14, 2014 | HP LaserJet P3005 Printer
Tray 1 doesn't feed while tray 2 has paper, after I empty the paper from tray 2, tray 1 work fine.
if you setup tray 1 any type, any size and tray 2 to plain, and letter size, it will allow you to use tray 2 for your plain letter jobs but will pull from the manual feed tray first only if the paper is in the manual feed tray if this makes any sense to you... please mark this as a fixya...
Nov 24, 2013 | HP LaserJet P4015N Printer
Where is the manual feed
I think, there is None.
You have only tray 1 so manual feed must also be done using tray 1 by taking out all the other papers
If that is too inconvenient, get the optional tray 2. Fill that with paper and leave tray 1 for manual feed
Nov 02, 2013 | HP Officejet Pro 8600
Hello. During printing I often can see error message 13.01.00 - paper jam, but really nothing jammed. I have printer HP LaserJet p3005. Thanks
Your printer has a misfeeding problem.
It never fed any paper so the sensor never sensed paper and thinks that there was a jam.
Try using the manual feed tray. If that works, pull out tray 2 and clean the feed roller . Is this printer
up to date on its maintenance? The feed roller might have to be replaced.
Mar 16, 2011 | HP LaserJet P3005 Printer
Does my printer have a "Manual Feed?"
Yes. The manual feed tray is in the front door with the HP logo on it. When you fold that down this becomes the manual feed tray. Also note that HP referes to this tray as Tray1. The bottom paper tray is tray 2.
Thank You for using Fixya.
Dec 01, 2010 | HP LaserJet P2015dn Printer
Hp 3005dn prints blank pages, even the configuration pages requested from the machine itself
if you haven't any error message then you may have a problem in laser shutter, check and reseat your catrtidge, or you have a problem in your DC Controller
Apr 01, 2010 | HP LaserJet P3005 Printer
HP P3005 - skid marks along paper's edge
Print 3 pages. Use the manual feed tray. As they print, open the cover, remove the toner and look down at the paper in the printer. Do you see marks along the edge? If no...replace the fuser. If yes...it could be the transfer roller.
Jan 07, 2010 | HP P3005d Monochrome LaserJet Printer
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
HP LaserJet P3005n Printer Logo
4,621 people viewed this question
Seeker5211
Seeker5211
