Question about Seagate Computers & Internet
Maxtor Basics E H D
Not recognised by pc E Machines 420 Windows XP SP2
  • ed_nglo Sep 23, 2008
    Thanks for info - have found cause which seems to be a faulty usb connection on pc
    Sergeant:
  • 264 Answers
There is a small step whic you should try.
Right Click MY COMMPUTER>Open Properties>Hardware>Device Manager
Scrol down and click the + sign on the universal serial Bus controller
Right click on USB Root HUB and select uninstall.
Uninstall all the USB Root Hubs.
Turn off the computer.
Plug in the maxtor on another USB port and turn on the computer.
Posted on Sep 23, 2008
    President:
  • 1,952 Answers
This may cause due to virus problem...its not a problem...u jusy click the drop down list box which was present in the my computer window address bar...after click tat u will open ur drive by selecting in the drop down list...this problem will fully recoverd by reinstall ur os as soon as possible..
  • mohammed marika thambi
    mohammed marika thambi Sep 23, 2008
    Windows thinks your external is a cdrom for some reason or another.
    Right click my computer and choose manage. Scroll down to disk
    management. Look for the drive in the lower right. See if it is comming
    up as a cdrom or disk drive.
    If it is comming as a cdrom right click the drive and choose update driver.
    Also try going to device manager (you can do this from the manage
    screen also). Expand the disk drives and cdroms - find the drive in
    question. Right click and choose remove/uninstall.
    Eject the device using the little green arrow in the task bar.
    Reinsert using a different USB port.
    When the auto run comes up choose do nothing.
    Open windows explorer (win key + E) clcik the drive on the left. check
    the drive for any auto run files, config files, ect. There may be
    something copied to it or installed on it that is making windows think
    it is a cdrom.
    If nothing is present - you'll want to try and remove your data from it.
    The manufacturer should have a utility to rebuild or reinitialize the
    drive on thier website. After everything is done copy your data back.
    Some good data removal tools are
    testdisk
    http://www.cgsecurity.org/wiki/TestDisk
    check ur port thro device manager..then usb port can be can be rectified by reinstall ur port software
  • 3,037 Answers
Is the PC not recognizing it at all or does it say that it is an unknown device?
MAXTOR 250 gb usb hard disk is not detected
On some computers the output power of the USB ports is too low to drive the Ext. HDD.
Have you tried other USB ports on your computer?
Get yourself a powered USB hub and try that, borrow one if possible, if that works get one for yourself....
Aug 21, 2009 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Maxtor Basics 320 GB external harddrive cant be recognized
There's a good chance the shop you bought the drive from didn't have SP3 installed. For some reason, SP3 has an issue with USB peripheral devices. Windows has created a patch to rectify the problem. Click on the link below and install the "Fixit" patch to enable your PC to recognize your HD. Best of luck.
Greg
http://support.microsoft.com/kb/925196#fixit4me
Jun 18, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Maxtor Basics portable 320gb Mac to pc compatability problems
Hi Tys,
I had a similar issue with my Maxtor Basics portable 500GB drive. I hadn't formatted mine yet, but had heard there were issues, so decided to find out before I start. I even saw your post here looking for an answer. Finally, one of my friends told me the following solution, which worked fine for me:
Don't format the drive as any of the Mac OS Extended options, simply reformat it as MS-DOS (it should be one of the options in Disk Utilities when you choose Erase and go to the Volume Format dropdown list).
Your Mac should be able to recognise and use the drive in this format and it works for PCs. Transferring files between the two shouldn't be a problem.
A thing to note, though, is that these Maxtor drives apparently come ready-formatted as MS-DOS (mine did). But while my Mac recognised the drive, I couldn't copy files on to it. If this happens, erase this MS-DOS formatting with... MS-DOS. Don't ask me why this works, I'm not a Mac Genius, but now my Maxtor is trouble-free and can transfer files from PC to Mac and back again.
Hope this works out for ya!
K
Apr 27, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Harddrive is not recognisable by both PC and MAC.. Its either one or the other..
Partition the drive into 2 250 Gig partions, Call 1 partition MAC and the other one name PC, for the apropriate partion on each machine
Apr 13, 2009 | Computers & Internet
1.5TB only showing 81 gigabyte
you got it man you have two reason for bios like you tell me and your partition table so download magic partition on your windows xp and you will be able to correct this easely
bye and good lock if you have other problem for this tell me
Mar 05, 2009 | Maxtor 1.5TB 7200RPM 16MB USB...
Have got a Maxtor Basics external portable hard drive running off XP Home. It has installed fine and is recognised by XP - everything looks OK. The only thing is... how do I begin to backup all of my PC...
The drive should have come with software to do just that. If it didn't then there are many programs out there that you can use to do just that. Nero is one of them, you can download a trial version at www.nero.com.
Jul 06, 2008 | Computers & Internet
Hooked up my PC with 2nd Hard disk, a MAXTOR 6L 160 MO Hard drive , but Windows XP SP2 does not recognise it, i.e it does not appear in MY computer. However it is recognised by the Device Manager in...
try open computeradministration.
go down to disk handling. If you can see it there you can format the disk and what way get it to be shown.
CS.
May 20, 2008 | Computers & Internet
My pc dose not come up my maxtor basics external desktop hard drive
What OS are you using? Windows 98SE does not always recognize exterrnal hard drives. Try the external HD on a computer running Windows XP and see if that works. If it works on WinXP and not Win98SE or possibly WinME the External HD is good.
May 06, 2008 | Maxtor Hard Drive
Maxtor Can't Touch
I understand the problem you are going through and it is due to the fact that win xp sp2 install an NTFS filesytem on its hard drive and this file system was designed to be secure in a way that you don't remove disk drive or add disk drives just like that.Now the best solution would be to just reinstall you xp machine with sp2 with the hard drive already in the case.In this way xp will be able to recognize it as one of its own drives and now you will have access to it.
Mar 13, 2008 | Computers & Internet
Computers & Internet Logo
107 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
