Question about Intel D845HV (735858149143) Motherboard
750 GB Hard Drive support on intel 845 motherboard
I would like to know if my intel 845 motherboard is going to support 750 GB Hard Drive or not?
Thanks in advance
    President:
  • 2,351 Answers
Hi prabhatkumar, your Intel motherboard's bios will see the drive. The question is will windows?
Do not use windows to setup the hard disk drive. Download the free bootable software for a floppy disk from the manufacture's web site. Boot the system to the floppy & format the drive. You'll be able to set the cluster size (Like windows would do) but the software from the manufacture is far better than windows. Any version of windows XP will see your total drive size. Just make sure the drive is seen while in the bios. (If it will be the primary drive make sure it is listed in the boot order).
Good day prabhatkumar!
Run into any issues just drop me a note.
Mike
Posted on Sep 23, 2008
My motherboard is intel d845gvsr tell me how can i install sata hdd with this mother board and how many gb sata support
For sata HDD Your can connect your sata HDD using IDE to SATA cable. Intel 845 can support upto 320GB only.
Mar 17, 2011 | Intel D845GVSR Motherboard
Swaping hdd 845 motherboard to 915 motherboard
its always safe to have data backed up
u can swap the HDD
but bootup with the Win2K CD in the Drive and after the files are loaded at the first screen select install then after it detects the OS select R (Repair) and this will reinstall the operating system files and then you can use the system as before though u may have to install the device drivers and motherboard drivers
for any other clarifications u can place a comment in the same question or u can mail me at mail2pvs@gmail.com
Jul 30, 2009 | Intel Pentium 4, 3.0 GHz 530...
Adding a second hard drive
Get a SATA PCI Card. Problem solved.
Dec 25, 2008 | Computers & Internet
Slow speed+hard disk
problem not clear enough
Please Don't Forget To Rate "FIXYA" Me For The Help
Dec 21, 2008 | Intel D102GGC2 Motherboard
845 GLLY Maximum Hard disk support
Try first to reformat the 40 GIG hard drive that you have since it still detected under BIOS so hopefully that can still be reformatted and still work after that, but if still have the same problem this 40GIG hard drive may have alot of bad sectors already , Sorry to say but the 200 gig of sata drive wonto work for this motherboard since it doesn't support SATA drive , you can get a 1600GIG of IDE drive for this, this is teh complete specs of your motherboard
http://shopping.msn.com/specs/intel-desktop-board-d845glly-motherboard-micro-atx-i845gl/itemid63207496/?itemtext=itemname:intel-desktop-board-d845glly-motherboard-micro-atx-i845gl
Nov 04, 2008 | Intel D845GLLY Motherboard
Maximum hard disk support
this hard drive size will work with your motherboard but the problem is the size will be detected only up to 130 GB or less, so if you will be using that size of hard drive you will just waste it.. so better use a 120 GB of hard drive or upgrade your motherboard so you can use a 250 GB.....
Hope that helps.............
Sep 01, 2008 | Computers & Internet
250gb sata hard disk to 845 glad mother board
Hello all. I have the same issue. My MB is 845G [P4 2.4 Ghz] and SATA harddisk I need to install is Seagate 250 GB Baracuda with 3.0Gb/s interface, I belive which makes this HD as SATA II. So for this motherboard should I prefer PCI cards which support SATA II over the supports SATA I [these are cheaper].
Thanks so mcuh!!!
May 12, 2008 | Computers & Internet
Ram support for intel 845 motherboard
Ok. So you've defined the Intel 845 chipset on your motherboard.
But is it the 845 or 845G chipset?
Click HERE for the specifications of the Intel 845 chipset.
Click HERE for the specifications of the Intel 845G chipset.
Peepnklown is only HALF right.
The Intel 845 chipset does NOT support PC133 memory.
The Intel 845G chipset DOES support both DDR and PC133 memory.
The difference?
The 845 has a single memory controller for DDR memory.
The 845G has two memory controllers. One for DDR and one for PC133.
Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
These boards typically come with DDR266 (PC2100) modules installed.
I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
Think of it as giving the motherboard "breathing room".
I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
Click HERE for PNY's memory configurator.
Good luck.
Cyryl
Nov 10, 2007 | Intel Motherboard
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Intel D845HV (735858149143) Motherboard Logo
206 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
