Question about Kenmore Elite 45986 Front Load Washer
Kenmore two way tumble action washing machine - shakes, vibrates very loud
Kenmore front load washig machine sounds like it is flying apart - vibrates very bad and is very loud.
  • 32 Answers
Sounds like you have a broken stantion on the back of the can confirm this by opening the door and trying to pull up on the stainless steel basket.if it pushes up and flops back down,that is what you have.if the mach is over 2yrs old,look in your manual under warranty.if it has a 10yr on stainless steel basket and lifetime on tub,you will only have to pay for labor on repair.if it only has 1yr on entire mach,est would be higher than the price of a new one.
Posted on Sep 28, 2008
Remove front panel on kenmore tumble action front loading washing machine model417 44152400
If it is the one I'm thinking there should be 2 screws that hold the bottom panel, that should give you access to most of the parts.
Feb 12, 2015 | Kenmore HE2 Plus Front Load Washer
Kenmore 3.5 cu ft front load quiet tumble action washer. Will not stop cycling, leaks, and shakes violently when spinning.
The shaking could be due to a defective drum support bearing. The shaking also could have caused the door seal to fail, resulting in the leak.
Jan 22, 2014 | Kenmore 3.5 cu. ft. Front Load Electric...
Loud shaking in the spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
Jan 19, 2011 | Kenmore HE2 Plus Front Load Washer
I have a kenmore washer that does not drain and spin at the end of the wash cycle....Kenmore Super Capacity 3.5...Quiet Tumble Action...Easy Access
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Sep 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 22, 2009 | Kenmore Washing Machines
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
Kenmore Elite 45986 Front Load Washer Logo
298 people viewed this question
Sal De
 Brian Main
Brian Main
