My tv is changing channels on its own and when i turn the tv off, it turns back on...seriously.only way to stop it is to unplug the tv.
  • 10,594 Answers
Though you have not mentioned model and brand of your tv so I can offer a tip only here.
Check in what order tv changes its channels, like if its in forward order, +Preset or +Channel knob would be stuck. If its changing in reverse order, check -Channel knob at front of tv.
Hope this info would be helpful.
Thank you.
Posted on Sep 23, 2008
Magnavox TV turns itself on and changes channels
channel + or - switch is stucked in,,or broken plastic stucked in ,watch thorougly
Dec 14, 2015 | Televison & Video
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
Is a Insigna TV, it turns on by it self and starts changeing channels and I can't stop it I have to unplug it.
the problem of your TV is the button of the channel will not getting back so channel can't stop
you have to do is replace the button if you will or use a remote control to access the channel and never use manual changing channel again
Mar 09, 2011 | Televison & Video
My tv channels surfs on its own wont stop. have to unplug to stop
What you got here is common. The issue is the controller under the volume and channel and power butoons, This is defective!! your going to need to have the tv serviced. this part cost $75-90 bucks the labor may vary in your area. Please do be considerate as you recieved this info FREE when leaving feedback and ratings today.
Apr 28, 2010 | Vizio VW37L 37 in. LCD HDTV
TV turns off when you change the channel
sounds like a power fault, prob just weak capacitors if you can change them it would not cost a lot to replace them, when you change channel it draws more power and if its at its limit it will turn off as the capacitors cannot take it. few £'s or $s to get the replacement capacitors, you will probably see the blown capacitors on the power board as the will not have flat tops they will be rounded, change them same for same i.e 16v 330 for same 105c type would be best. it will say this on the capacitor.
May 27, 2017 | RCA TruFlat 27F520T 27" TV
RCA P52929 changes channel non stop
try unplugging it from the electric wall outlet for an hour then plug back in, this should reset your tv back to factory default, you will have to adjust your setings if you changed them
Jan 25, 2009 | RCA P52929 52" Rear Projection Television
Lg lcd tv
It sounds like a stuck button on the TV. Probably a channel button. Try tapping on each button to get it to stop. If it does, then use the remote from now on. If I was repairing the set here at my TV shop I would open the set, turn it on, and unplug the buttons while it is running. If it stoped changing channels then I have the proof that it is the buttons causing the problem. If it did not stop with buttons unplugged then the tv would need a circuit board. The Brand and model number posted would let me look at the schematic.
Steve
Mar 24, 2008 | Televison & Video
Channels
Try unplugging the set for a couple of minutes then plug it back in.
Nov 01, 2007 | Sony KV-32FS13 TV
Posessed TV!
microprocessor circuit----possible bad solder connect--examine w/magnifier--
Oct 05, 2007 | RCA TruFlat 27F520T 27" TV
Remote control not responding
Perhaps you can try what I do when my KV24FV300 runs through channels and will not stop.  Hard to watch and remote will not work.  Nothing works but on and off from set.
Sony Says:  Take all batteries out of ALL remotes that you use in any way for that set, VCR, etc.  ALL batteries out.  Turn TV off at set.  Unplug TV.  Wait at least 15 minutes then replace all batteries in ALL remotes.  Plug TV back in and turn TV on from set.
Maybe, just maybe it will work.  If it does not work why not call Sony, they always say that cannot happen but they have a solution for it.
niteowl@dejazzd.com
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
