Question about Brother MFC 240C All-In-One InkJet Printer
Replacing the cart holder on a Brother MFC 240C
Hi, I saw that you said my printers failure to recognize my new ink cartridges is because of the use of generic ink causing the circuit to short...My question is how would I replace the cart holder? Can this be done myself, can I bring it in somewhere or is my printer useless now?
Thanks
  • Gary Weeks
    Gary Weeks Oct 26, 2008
    I have the same problem and I figure the Printer is toast. It will not fax or scan with an ink cartridge empty or non recognized. I plan to take it apart and attempt to clean the circuit board. I will let you know it this works. I purchased an MFC-685cw printer because fixing the MFC-240 is unlikely.
  • karl sarmiento Nov 03, 2008
    same problem...the unit will not recognize the cart,even new ones..
  • 21 Answers
Somethings that have worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Posted on Nov 05, 2008
Tip
How to change an ink cartridge on the Brother MFC-240C
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
on Jun 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc-240c doesn't recognize ink cartridges that I put in
It may be a memory issue.
Unplug the machine from the power.
Remove all the ink cartridges
Replug the machine and reinstall the ink cartridges
Jan 19, 2010 | Brother Multi-Function Center MFC-240C...
New ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Jan 28, 2008 | Brother Multi-Function Center MFC-240C...
Ink
Did you lock and secure the latches?
If yes and still this message, do you run generic ink carts?
If yes, the cart holder is stained with ink and the led-controll-board has a short circuit, which cant be fixed!
You need a new cart holder as a spare part!
Jan 19, 2008 | Brother Multi-Function Center MFC-240C...
"No Cartridge" error on Brother MFC-845cw
Something that has worked for some Brother owners to get cartridges recognised.
Jan 04, 2008 | Brother MFC-845CW multi-function...
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Does not accept black ink cartridges
Did you use generic ink? These generic carts are different (no seal to prevent staining). This carts stain the led control circuit board which has to be replaced by a new one (the spare part is only avaiable as the whole ink cart holder incl. led board and tubes).
There is no way to do a short fix, sorry!
Nov 28, 2007 | Brother MFC 240C All-In-One InkJet Printer
Ink cartridges....
Which cart arent recognized? The yellow one or the cyan(blue) one or both?
Anyway:
Unplug machine from power. Wait three minutes. In this time take all carts out and close cover. reconnect machine to power. Machine demands carts. Open cover. Reinsert carts. Make sure that the support clip of the cart.holder is secured above the cart cover.
If you still have probs with one cart. the led contact on the circuit board is defectiv. You need a new cart holder then, which can be ordered as a spare part from a service partner near your home (see brother homepage).
Nov 13, 2007 | Brother MFC-3240C All-In-One InkJet...
Model mfc-240c
did you replace with brother carts, are you sure machine is refering to mag and yellew being mt, not the other ones, power off, remove all carts, power on , reinsert carts one at a time answer machine when prompted. these cartridges are deemed empty even when they look like they have a little ink left. Try putting in 4 new brother inks
Nov 09, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C All-In-One InkJet Printer Logo
816 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
