Question about SmartDisk PowerPlay Pro Remote Control
Receiver The USB receiver for my SmartDisk PowerPlay remote can no longer be recognized by my laptop, whereas all other USB connections are fine. The USB plug is a tad loose and bent and was wondering if there's any way to fix that. I really love the remote and don't see any way to replace it since no one sells it any more. Any help you can provide will be greatly appreciated. Stephen Brown
    Problem Solver:
  • 58 Answers
If you're pretty handy doing things you can try these.
1) Using a small pair of needle nose pliers, gently squeeze the USB plug back into the right fit for the port. If this doesn't work, try 2).
2) Remove the cover from the remote by either unscrewing it gently prying open the seam along the side. You may brake a little of the case along the seam, but that is replied again after repair. Once you have the case open, look at how the cable is attached to the circuit board. Before removing the cable from the board, purchase a new data cable from an electronic store, or even cheap 2nd shop, etc. You will have to purchase a DATA cable not a charging cable! They're wired differently.
Once you have the cable, cut the opposite end that you need off and either solder on to circuit board or if a connector is used cut the wires close to the connector so you can solder the wires. (should be colour coded).
NOTE: If you need to solder the wires together purchase small diameter heat shrink tubing for electrical insulation from electronics store. If you can't get it, then use 2 strips of electrical tape with the wires separated in between & press the stops together using the tape adhesive to separate the wires from each other.
If you don't know which colour goes where, look on internet for USB plug wiring diagram.
Once finished reglue the case back together with a suitable plastic adhesive.
Hope this helps. Regards Bob From The Land Down Under, OZ.
Posted on Jul 08, 2017
Trying to connect my old Smartdisk USBFLB120 to my Toshiba Laptop with Windows 7 64 bit - can't get drive to recognize as drive - Lapop sees device but says it is unavailable
Change you usb port or replace the smartdisk's usb cable, probably the current one if broken. Also restart the pc whilst the smartdisk is connected. It shd be recognised now.
Jun 06, 2011 | SmartDisk FireLite USBFLB120 120 GB USB...
My USB smartdisk firelite is not recogniced by any laptop, regards
Connect it to a different DESKTOP computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Oct 29, 2010 | SmartDisk 80GB FireLite USB Bus-Powered 80...
USB Device Not Recognized...
try to the laptop firewire port, if works. I didnt find any support for youfirelite drive
Dec 29, 2009 | SmartDisk FireLite 40 GB Hard Drive
don't worry it only delete the virus not your data
I have a Smartdisk PB80 PhotoBank
I have a pb80, and I found that it would not read SD above 2 g.
It reads a 2 g fine, but not a 4 g.
I also have a reader with the same problem. I replaced the reader with a different model, and it works fine. Planned obsolence.
Apr 26, 2009 | SmartDisk PhotoBank PB40 40 GB USB 2.0...
SmartDisk PowerPlay Pro Remote Control Logo
50 people viewed this question
Top SmartDisk Televison & Video Experts
Are you a SmartDisk Televison and Video Expert? Answer questions, earn points and help others
