Problem with Dell Latitude D600 PC Notebook i ran my computer battery dead then i went to put it on the carger then it started flashing twice orange than once green what do i do
The reason its turning orange is because the battery is going bad. When you put a new battery in there the light will be green constantly and you'll be able to charge up the battery with the ac adaptor.
Go to support.dell.com and download the latest bios firmware to update it. If it still does not work then most likely it is already a hardware issue so you need to contact dell support for the hardware issue.
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
The flashing battery light is an indication that the system is attempting to charge the battery. The orange light indicates a problem charging one of the battery cells. This usually means that the battery either needs to be recalibrated or replaced. To recalibrate the battery just use the system until the battery is dead, then recharge and repeat the process twice, after which time the battery should be recalibrated. If this doesn’t fix the flashing orange light then the battery may need to be replaced.
