Question about Liebherr Refrigerators
Liebherr larder fridge not working in normal mode
I have 8 year old free standing larder fridge with no ice compt. in past fee days fridge has increased in temperature despiter placing dial to max. Super cool still works and will cool the fridge down nicely, but will cut off when its supposed to do. However, eventually the temp rises and one has to revert to super cool function. If it ws compressor the super cool, would not function so either the thermostat is u/s or something else could be wrong. Please advise - thank you.
  • Anonymous Mar 22, 2014
    I have a new fridge/freezer, but I can turn the demo mode off. Therefore I can't get the unit to cool/work.
  • 1,462 Answers
Thermostat is faulty - supercool just bypasses the stat
Posted on Sep 24, 2008
How can i stop my larder fridge from producing lots of ice?
If your fridge is built into the furniture, pull it out by releasing all the retaining screw, clean the condenser and the areas behind your fridge. Dust and fluffs reduce the efficiency of the fridge. Also turn the dial to three, if it is higher, older fridge do not need to be cranked to higher numbers. If no joy call an engineer, the level of refrigerant in your system may need topping up. Will cost you anything from sixty pounds for a qualified engineer to do this.
Aug 15, 2014 | Refrigerators
How do you stop ice building inside, at the back of fridge model Beko LA87 Larder fridge
It can be 2 things. One is that the thermostat is broken but then it will also freeze your food. The other reason is that it has lost part of its gas charge due to a leak on the system causing the unit not to reach temperature thus not switching of on the thermostat and building ice inside. Normally it is not economically viable to fix the unit.
Oct 06, 2017 | Refrigerators
Our fridge keeps creeping up to 10 degrees Centigrade despite defrosting every week. It must need some fan to keep the air cool and circulating from the freezer which works well?
If your freezer side is capable of making ice, and that ice is dry and remains so,
the only issue you have is insufficient airflow to the reefer box section from the freezer.
The refrigerator section is 100% reliant upon the frezers side for all of its cold air.
The refer box has no evaportator of its own, There are 2 settings or dials.
One is the temperature thermostat, it actually controls the compresssor motors cycling,
thus the desired ice box temperature as well, it often says 1-10 and off as well, the reamaining setting, the one that cannot turn the compressor motor either off nor on is a damper door controller, that modulates the freezers airflow into the reefers box!This is where the problems occur, when one notices the reefers box is warm, they max both settings,which seems logical , and is for the thermostat dials setting.Where the major counter intuitive reality exists is the flapper dooors setting will say Colder and Warmer!!Colder of course!! right?? No, it actually means and usually does say, Colder Freezer!!not Colder Reefer! so you MAX or RAISE the thermostat, thats ok to do.But maxing or raising the other setting is just starving the reefer box section from sufficient cold air flow to maintain adequate temps.I have gone to hundreds of identical calls, Freezers ok, but Reefers warm! If the freezers making ice and the ice is dry, there is no problem with the refrigeration system, its airflow.when defrost timers or heaters fail the symptoms may be as yours, however the freezer will slowly warm in another day or so. But if the freezers making ice for days and never getting wet theres an airflow issue period, you may need to remove the back wall panel in the freeezer to see the coils condition , is it iced up or blocking airflow with icing/ is the ducting open between the freezer and reefer boxes?setting both dials to the midway setting should work fine. the condenser coils may be dirty/dusty too, is the cardboard backing still in place on back? it needs to be there intact.
is there product inside the reefer box? if not add 3 gallons of water.
Dec 27, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Hi, I have a Hotpoint RLA51 larder style 'frost free' fridge. Its approx 6 years old. For the past 3 years its been frosting up meaning every 8 weeks we have to defrost it manually. I bought a new...
high chris
check to see if you have a drain at back/near bottom of the fridge,if so, clean out with neat clorine bleach.if you have a fridge thermometer adjust fridge to run at +5c(optimum temp) and cover all food with cling film to cut down on condensation.
Aug 26, 2010 | Refrigerators
My Samsun RS2534ww side by side refridgerator will not maintain temperature on the fridge side. It consistantly warms up to between 50 and 60 degrees despite resetting the thermostat.
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try defrosting the FF as despite common belief these units are not totally frost free.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Nov 06, 2009 | Samsung RS265LABP Side by Side...
We have a Whirlpool gb22dk refrigerator freezer. The bottom freezer keeps meat frozen but will not keep sea food ice cream bread ect frozen. This fridge came with our house which we purchased 2 years ago...
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Jun 09, 2008 | Whirlpool Refrigerators
AEG Santo 3778-8 KA Temperature Problem
hi tracy, think its possibly better getting a repair guy in as this fault is not streight forward. possibly a fault in the defrost circuit, or freezer fan not functioning, or possibly a leak in the system. all theese areas need testing equiptment.
Sep 19, 2007 | AEG Santo 7085 KG Side by Side...
Refrigerators Logo
1,110 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
