Question about Texas Instruments TI-84 Plus Calculator
Calculators I have a couple of calculators that will not work after replacing the back up batteries and the 4 AAA batteries. I also have a calculator that the screen is reduced so that it is cutting the numbers around the edges.
  • Texas Instru... Master
  • 7,993 Answers
This is a blank answer to a blank question.
Posted on Sep 01, 2009
Wont turn on
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to assist you. You are having problems because you calculator won't turn on. I think you should try changing the batteries. Did you know that your calculator has two batteries powering it? Not only are the 4 AAA batteries powering it, but there is also a CR 3V Lithium Back Up battery powering it as well. First, try changing the 4 AAA batteries. If that still does not power your calculator properly, you will need to replace the lithium back up battery. You can find this at a department store or store that carries electronics. To do this, open your regular battery compartment. Above the AAA batteries is a compartment that says "BACK UP BATTERY CR1616 OR CR1620" with a picture of it. Use a small crosshead screwdriver to open the compartment. Take the old battery out and replace it with the new one. Rescrew the lithium battery compartment back on and close the AAA battery compartment. Turn on your calculator and see if that works. I hope this solution solves this.
Sep 27, 2011 | Texas Instruments TI-83 Plus Calculator
TI 82 Does it need the disk battery and 4 AAA batteries to work?
No. The calculator runs on the four AAA batteries. The lithium battery is solely to retain the contents of the memory while you change the AAA batteries. If you don't care about retaining the memory, you don't need the lithium battery. You do, however, need the AAA batteries to use the calculator.
Jul 31, 2011 | Texas Instruments TI-82 Calculator
I have a TI84 plus texas instruments i have removed both the batteries in order to reset the unit but it still has not resetted the unit. All I am getting all zeros on the screen
First try removing all four AAA batteries and the small lithium backup battery (above the four AAA batteries). Leave all batteries out for five minutes, then replace them and try to start the calculator. If this doesn't work...
Replace all but 1 AAA battery. Press and hold the "CLEAR" button on the calculator. While holding the "CLEAR" button down, replace the missing AAA battery. While still holding the "CLEAR" button, turn the calculator on. The display should read "RAM Cleared". Release the "CLEAR" button and press again to remove the message.
If that doesn't work, remove 1 AAA battery again. Repeat the preceding instructions with the "DEL" key: With the battery removed, press and hold the "DEL" key. With the "DEL" key held down, replace the battery and turn the calculator on. The screen should say "Waiting... Please install calculator software now." Release the "DEL" key. Download this program onto your computer (from Texas Instruments). Connect the calculator to the computer using the USB cable provided with purchase. Run the TI OSDownloader program and follow the on-screen instructions to re-install the calculator's operating system.
Apr 30, 2011 | Texas Instruments TI-84 Plus Calculator
48GX has been idle for 4 years.Wont turn on. Is there an internal battery that I can replace?
The 48GX runs on three AAA type alkaline batteries. However, if the device was unused that long, the button cells used for backing up the RAM cards may also be depleted, and the calculator will report "low battery" displaying the ((.)) symbol, even with fresh AAA cells installed.
The RAM card mounted batteries are type CR2016.
Main batteries:
  • Remove the calculator battery compartment door by pressing down and sliding it off away from the calculator.
  • Turn the calculator and shake the batteries out.
  • Replace with a fresh set of AAA alkaline batteries. Polarity is marked on the bottom of the battery compartment.
  • Replace the battery compartment door by sliding it back in place.
RAM card batteries:
  • Turn the calculator over and remove the plastic cover over the plug-in card ports (display-end of the calculator).
  • HP recommends to turn on the calculator while replacing the RAM card battery to avoid memory loss. I assume, your HP48GX has no marbles to recover by now anyway, so it does not matter, I guess.
  • Near the left side of the end of the card. you'll find the nail grip in the black plastic battery holder. Use a thumbnail to gently pull out the battery holder. There is one battery in each card (additional cards are options).
  • Remove the old battery from the holder and replace by a new CR2016 button cell. The "+" side of the battery should point into direction of the calculator's front.
  • Re-insert the holder with the new battery and check the RAM card is properly seated still.
  • Close the compartment by sliding back in the cover.
Jan 11, 2011 | HP 48gx Calculator
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  1. Try a new set of AAA batteries.
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
In order for the calculator to work do you need the AAA batteries and the back up battery?
The backup battery is to preserve the contents of memory while you replace the main batteries. If you don't care whether the memory remains while you do this, then you don't need the backup battery. The calculator won't work without the AAA batteries, but will work without the backup battery.
Sep 15, 2010 | Texas Instruments TI-83 Plus Calculator
Do i need both the back up lithium battery and the 4 AAA batteries for my TI-83 calculator to work? Or can it work only with the 4 AAA?
The calculator can work with just the AAA batteries. But, without the backup battery, you'll lose all the contents of memory when the AAAs die. The backup battery is intended to keep the contents refreshed while you replace the AAAs.
Feb 06, 2010 | Texas Instruments TI-89 Calculator
Press
Have you tried to reset the calculator?
From page 671 of the TI-84 Guidebook:
To reset the calculator:
1) Remove all AAA batteries
2) Hold down the On button for 10 seconds
3) Reinsert AAA batteries
4) Turn the calculator back on.
Note: When you reset your graphing calculator, the contrast sometimes changes.
Nov 05, 2009 | Texas Instruments TI-84 Plus Silver...
How can I revive my TI89 after two years of not using it?
It could be that you need to replace the backup battery located behind a little door with a screw in the battery compartment. If this doesn't work, try resetting your calculator by leaving backup and AAA batteries out for about 8 hours and reassembling it. Hopefulyy this will work. Good luck
Jul 29, 2009 | Texas Instruments TI-89 Calculator
TI-82 display isn't fully working
This happens alot with calculators that have been in storage for a while, you can fix this by taking the batteries out and let it sit overnight.
May 05, 2009 | Texas Instruments TI-82 Calculator
Texas Instruments TI-84 Plus Calculator Logo
29 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
