Question about Panasonic KX-T7633 Corded Phone
Revising extension directory on LCD
I need to make some updated revisions to our inhouse extension directory. I press, Menu, then extension directory, but it doesn't give me the option of making changes.
  • sbclutch Nov 25, 2008
    I have a KX-T7633 and we just got another cordless extension phone but the person who set it up for us didn't program the button on all of our corded phones. How do I add that extension to the rest of the phones?
  • Panasonic Master
  • 2,460 Answers
Correct. Changes are done in system programming. In a TDA it resides in system program 004. You get there by going to the main phone or phone used to program, dial PROG **1234 004 and enter the extension number of the name you want to change. It will display the present name and let you use the keypad to spell out new names. For example 2 gives you ABCabc2. The right arrow steps to the next character and ENTER saves it.
Carl
Posted on Sep 23, 2008
How do I set security on my DWL-952
There are 2 possible areas raised by this question. The first is a security patch needed to fix the firmware of your router, which by the way is not dwl-952. Your router is a di 954. Dwl 952 is a bundled router and network interface. The details of the firmware update are below.
Security patch for your D-Link router
These firmware updates address the security vulnerabilities in affected D-Link routers. D-Link will update this continually and we strongly recommend all users to install the relevant updates.
As there are different hardware revisions on our products, please check this on your device before downloading the correct corresponding firmware update. The hardware revision information can usually be found on the product label on the underside of the product next to the serial number. Alternatively, they can also be found on the device web configuration.
Please make sure you follow the firmware install guide provided within the ZIP firmware package.
DI-524 Revision E1/E3Thu, 28/11/13
The new firmware 5.13b01 that fixes the security vulnerabilities
DI-524 Revision Ex 5.13b01
Please note: please unzip the file and use the file DI524Ex_FW513B01.bin to update firmware.
DI-524UP Revision A1/A2Thu, 28/11/13
The new firmware 1.08b02 that fixes the security vulnerabilities
DI-524UP Revision Ax 1.08b02
Please note: please unzip the file and use the file DI524UPAx_FW108B02.bix to update firmware.
The second possibility is to set the local security on your network.
From the wikipedia page:
Wireless security is the prevention of unauthorized access or damage to computers using wireless networks. The most common types of wireless security are Wired Equivalent Privacy (WEP) and Wi-Fi Protected Access (WPA). WEP is a notoriously weak security standard. The password it uses can often be cracked in a few minutes with a basic laptop computer and widely available software tools. WEP is an old IEEE 802.11 standard from 1999 which was outdated in 2003 by WPA or Wi-Fi Protected Access. WPA was a quick alternative to improve security over WEP. The current standard is WPA2; some hardware cannot support WPA2 without firmware upgrade or replacement. WPA2 uses an encryption device which encrypts the network with a 256 bit key; the longer key length improves security over WEP.
The complete article is here
Wireless security
Log in to your router and find the wireless security section. Set up the security model that best suits your needs and then set up your wireless network card with the same information.
Mar 11, 2014 | Computers & Internet
Dell dimension 8400 frozen on BIOS revision A01
you might need to update your bios contact the dell website for a possible update
hope this helps
Jul 06, 2012 | Dell Dimension 8400 PC Desktop
I have just bought a new Technika LCD 32-56 tv from tesco and cant find a code so my Sky Remote controls can work with this tv. The remotes i have are Sky+ URC 1650-03 R02
need to know what revision it is, underneath the urc 1650-03 bit it should say: skyhd rev.9f where the 9f is your revision (using what it says on mine as an example) if you have a revision 9 remote try 2087 that worked for me
Sep 10, 2011 | Televison & Video
Philips 42PFL7422D/37 42-Inch 1080p LCD HDTV Picture went out but still have sound. Any tips on how to fix it?
If the backlight of the LCD-panel does not function, (no picture) then Master and/or Slave inverter are defective. Inverter boards are screwed to both sides of the LCD display, if they have revision 1.2 boards then they will need replaced with revision 1.3 boards.
Feb 16, 2011 | Philips 42PFL7422D 42 in. LCD TV
How to reset bios password of hp 2530p notebook? a) Flashing BIOS anew won't work (password required) b) Removing RTC battery inside for one hour won't work either
o check the current BIOS version on the computer, follow the steps below:
  1. Click Start , and then click Shut Down .
  2. Select Restart , and then click OK .
  3. When the first screen appears, press F10 to enter the BIOS Setup.
  4. The BIOS revision is listed on the Main menu.From there look for administrartor password and disable it. Make note of the current BIOS version; you will need this information to determine if a newer revision is available.
  5. To exit the BIOS setup, press F10 , select Yes , and then press Enter .
Nov 28, 2010 | HP EliteBook 2530p Notebook
Need a BIOS update for K7SEM motherboard. I am running Ubuntu 10.04. Is there a software that will allow me to update the system?
First you need to find the revision. Seems revisions are v1.0, v1.0+B1 and v3.0. My board is a v1.0+B1 since there is a little "B1" sticker on the MB just above the gold ECS heatsink.
Then go to the ECS Taiwan website to get drivers. ECS.com.tw.
Oct 18, 2010 | EliteGroup K7SEM Motherboard
How do i update the firmware to my sony ericsson w850i? procedures, pls. thanks
Accessing Firmware Information
To find out which firmware revision your phone currently has installed, select Menu > Settings > General > Update service > Software version. For more detailed software versioning information, perform the following:
Where < and > represents pushing the joystick left and right respectively.
Sony Ericsson Update Service
The firmware of the W850/W830 can be upgraded either over the air by selecting Settings / Update Service / Search for update or via the more traditional (and potentially cheaper) method of the Sony Ericsson Update Service. In order to use SEUS you will need to have internet access (preferably Broadband) and attach your phone to your PC via the supplied USB cable.
Note that the required firmware update drivers are present in the following directory after installing SEUS:
C:/Program Files/Sony Ericsson/Update Service/drivers
If you run into problems, you may wish to download and install Sun's Java Runtime Environment separately.
If the firmware update fails part way through, retry the SEUS. If the update consistently fails you will need to perform a Master Reset on your phone. It is likely that you will be required to perform a Reset All - a settings reset is unlikely to do the job. It is recommended to use a tool such as MyPhoneExplorer to create a backup of the data on your phone before performing a Master Reset. Note that you will still lose any games, themes or ringtones present in your phone's memory.
SEUS will currently install the following firmware revisions for UK phone brands:
W850
Unbranded UK (CDA102677/95) - R1ED001
O2 UK (CDA102677/58) - R1ED001
Vodafone UK (CDA102677/51) - R1ED001
Orange UK (CDA102677/36) - R1ED001
3 UK (UNKNOWN) - R1ED001
T-Mobile (CDA102677/26) - R1ED001
Oct 07, 2009 | Cell Phones
Airplus G DWL-G510 Vista Driver
revision B of this model has a driver for vista 32. go to http://support.dlink.com/products/revision.asp if you don't know where to check the revision of your device. if it's revision B, just click on the link for revision B and it'll give you the option to download the vista driver. make sure also that your vista computer is running 32-bit. if not, there's no available driver for vista 64
May 23, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Buscando por drivers
Dont worry you can download from D-Link's website. However you need to choose correct Revision (Rev A or Rev B) before download. Its very clearly indicated on the website. You can proceed to links;
driver for Revision A
http://support.dlink.com/products/view.asp?productid=DWL%2DG510
driver for Revision B
http://support.dlink.com/products/view.asp?productid=DWL%2DG510%5FrevB
If you dont know what revision you have you can check these links
for Revision A
http://support.dlink.com/prod_img/revisions/DWL-G510v.jpg
for Revision B
http://support.dlink.com/prod_img/revisions/DWL-G510_revBv.jpg
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Feb 11, 2008 | Computers & Internet
Adding 2 Xeon 2.8 On X4000
trying defulting bios for the new chip maby chip not full compatible with your mobo u can do a bios serch online type in your model # of mobo asus ## or ect
Jan 02, 2008 | HP Xeon , 2.8 GHz Processor Upgrade
Panasonic KX-T7633 Corded Phone Logo
505 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
