Question about Sony VAIO VGC-V517G PC Desktop
Sony Vaio PCV-RX540
One day my desktop simply would not boot up. It would freeze during the start up. It won't even start in safe mode-it also freezes. Any hope besides using recovery disks and losing data?
  • ablrn1 Sep 23, 2008
    Thanks, Coolguy, but I've tried the last known working configuration trick and it still freezes when booting. I've managed once to get into safe mode, but can't get anything done.
    Genius:
  • 1,550 Answers
You mentioned that you could not login in the safe mode so try this remove the hard drive and using it as en external drive for another computer.Then open notepad and copy and paste below.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /fastdetect /noexecute=optin
Then save this to the external drive as boot.ini , It should as if you want to replace you answer yes..then all you have to do is replace the drive back in original PC .
You will be able to login after performing the above operation .
This works for xp
Thanks for using Fixya.
SAM ANDERSON
Posted on Sep 23, 2008
  • 10,594 Answers
I have following info for your Vaio problem...
Symptom:
The set will be hung up or rebooted after it has been resumed.
Solution:
Update the BIOS by using the following tool.
MODEL: PCV- RX540(UC)
BIOS/DMI Update tool (Ver.1004, 1005) P/No.: J-2507-185-7
BIOS Version: 1004
BIOS File Name: BIK1004.bin
You need to contact Sony Service Center for updating as it requires tools and proper update file.
Thank you.
    Genius:
  • 3,422 Answers
HI,
You can try restarting your laptop and then hitting F8 repeatedly and then choose LAST KNOWN GOOD CONFIGURATION.If this doesn't fix the issue then you will have to go for a recovery.This is the only way to fix the issue.
  • Priya darshan Sep 23, 2008
    IF you have the data in other drives like d,e,f or g then you will not loose them because your OS is installed on C drive.So you can go for a recovery.But if you have all the data in your C-drive then you will loose the data.You can first try a repair option.Insert and boot with your Xp disc and then choose the option to repair xp.
    If you need anymore help let me know.
    Goodluck.
My sony vaio pcv rs720g stays in windows xp logo when booting ....what do I do to fix this.......recovery disk is not helping...
AS YOU START THE SYS. JUST KEEP PRESSING THE F8 BUTTON EVEN BEFORE THE XP LOGO COMES. AND YOU GET A MENU THERE. SELECT SAFE MODE AND PRESS ENTER. IT WILL BOOT IN SAFE MODE. THEN RESTART. SHOULD BE FINE ELSE PLS REPLY WITH THE ERROR STATUS
May 13, 2011 | Sony VAIO PCV-RS720G (027242658103) PC...
When attempting to start my desktop computer (sony vaio pcv-rx540), I got the 'we apoligize for the inconvenience, but windows did not start successfully...' error message. From doing a little research I'm...
try starting it in safe mode(f8 while starting up and restore from there), if not you might have to boot from the recovery cd, and last but not least reinstall windows
Nov 11, 2010 | Sony VAIO Digital Studio PCV-RX540 PC...
My Viao will bootup and then restart after a couple of minutes. This continues until I finally unplug the PC.
Boot loops when the op sys is corrupted.
Can you get into safe mode f8 key and see if it is stable if not reload the OpSys.
Jul 27, 2009 | Sony VAIO Digital Studio PCV-RX540 PC...
Sony Vaio PCV-RS710G wont start up
one of the files in the system32 directory in the windows folder is corrupt, the files in the system32 folder contains vital files for the boot procedure, try to start the machine in "safe mode" by pressing F8 after the sony boot screen, if it allows you into the operating system you will need to choose "system Restore" take the time back to at least a week before your problems started DO NOT CREATE A RESTORE POINT
Nov 14, 2008 | Sony VAIO PCV-W600G PC Desktop
Cpu fan control wont stop running
I had the same problem. Luckily, I found the "Sony Fan Control Driver" here:
http://esupport.sony.com/perl/swu-download.pl?template=EN&upd_id=170&os_id=6,7&mdl=PCVRX450
Runs nice and quiet now!
Oct 18, 2008 | Sony VAIO Digital Studio PCV-RX540 PC...
Computer not booting to Windows and sometimes freezes
hiya
this cud be many causes, a corrupt driver or overheating
try booting into safe mode to find out if it is a driver or software issue, if it does not then i wud suggest checking your cpu fan is working as you say it shuts itself off.....as new cpu's have a thermal protection built into them to stop the from cooking.....
let me know if you have any joy
Sep 12, 2008 | Sony VAIO PCV-V200G PC Desktop
Abnormal program termination error
Thats a USB driver error. You might have to reload it.
Before you do that though, try putting your computer into safe mode.
Turn the power off.
Wait 30 seconds. Turn the power on.
At the beginning of the booting process press and hold the f8 button. When the safe mode menu appears, move the up and down arrows to select safe mode and press enter.
Once windows is out of safe mode, restart the computer in the normal mode.
Jun 21, 2008 | Sony VAIO PCV-RZ40C1B PC Desktop
Sony VAIO VGC-V517G PC Desktop Logo
219 people viewed this question
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
