Question about KitchenAid Kitchen Ranges
Installation of kitchenaid range - KGSS907SSS
We want to put small pull out cabinets on each side of the range. However, the instructions say to leave 5 inches on each side of the range for safety. That would eliminate the cabinets. Is there any way to safely install the range and keep the five inches on each side for cabinets --- maybe a shield to put on the stove or something?
  • 943 Answers
Hi every stove that i have worked on and believe me that's a few and all gas or electric were all right up against the counter tops with no space at all so i would install the cabinets thanks please a positive feed back and accept please the appliance doc
Posted on Sep 23, 2008
Kgst307gbs glass control panel replacement
KitchenAid is the most likely source of a replacement
Mar 23, 2013 | KitchenAid KGSS907SSS - Slide-In Gas Range...
We purchased a slide in range, Frigidaire fggs3045kf. We want to put a granite countertop and use tile on the floor. When we raise the heighth of the range to make room for the tile, the ridge of the...
Hello Mkoffice, this a very common problem when floors are installed in front of cabinets and not underthe cabinets. it also causes a problem for the dishwasher. it will become trapped or cant be installed.If you dont want to removed cabinets to install the tile. you will need to raise the cabinet height. my shop has run into this before. We add 1 inch tall strips of wood across the entire front edge of the cabinets. the same is done to the back wall and any area where two cabinets sides meet. we dont use full sheet of ply wood because the granite installers will need access into the top of the cabinets to level the counters. The wood type should match the cabinet.( at least in the front) it will have to be stained or painted.
Hope this helps
Joe Connolly
Aug 16, 2011 | Frigidaire FGGS3045KF Stainless Steel Gas...
I have a Kitchenaide model KGSS907SBL01 gas range. Everything works fine except that we find that the amount of heat generated is disappointing. This seems to come from the fact that the top of the grill...
It would seem like reasonable thing to do.However the adjustment is typically for the low setting so you can adjust just the small flame just enough to simmer a pot without the flame going out from being so low its susuptable to going out on the low setting, also it so you can adjust the flame smaller so on low it isnt too high,causing it will boil when you intend to only simmer a dish your cooking. A question;is it all burners and have they always been that way?
Gene
Aug 13, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
Door lock will not release after selfclean cycle is done
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 06, 2010 | KitchenAid KGSS907SSS Gas Kitchen Range
After installing range the door will not open
if posible turn your unit off for 5 minutes should rest it self
Feb 09, 2010 | KitchenAid KGSS907SSS Gas Kitchen Range
Oven not sparking to ignite burner
Many of the ovens do not spark but instead have a hot surface ignitor that will get very hot to light the burner. If it is not getting hot then it probably needs to be replaced.
Nov 12, 2009 | KitchenAid KGSS907SSS Gas Kitchen Range
Kitchen Ranges Logo
173 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
