Question about Car Audio & Video
My sony cdx-4280 is giving me an E-99 code and I cant load a cd
SOURCE: Sony CD interchanger CDX - T69 (how to reset?)
This would invalidate the warranty and you may break it but I have just had to do one:
1. Remove 4 black screws
2. Unclick the front panel - yes it is clicked on but may appear to be screwed
3. Take off black lid
4. Pop the cradled player from the 4 dampers and unhook from the 2 springs
5. Remove the ribbon connector - do this by slipping/clicking the brown holder very slightly and then the ribbon comes out easily
6. Now using a suitable tool push the stuck CD back into the magazine
7. Click the magazine out - there is a white piece of plastic what when moved does the eject.
8. Do the above in reverse.
The trick to get the grey horizontal/vertical discs back on is to set them passed horizontal one notch on and click them on at the end - turning one notch anti-clockwise to lock them.
Posted on Sep 06, 2008
  • 3 Answers
SOURCE: Sony CD CHANGER Model:CDXA35RF
cleaning the machine
Posted on Sep 16, 2008
SOURCE: lost code
theres 3 probes underneth on the circuit board maked tp1 tp2 tp3, (can be seen though the radio outter tin case) one or more may be joined across with a blob of solder, join all 3 and they need no code!
jobs a good un!
Posted on Oct 12, 2008
HitWizard
  • 67 Answers
SOURCE: aux input for sony car stereo (cdx c 5000r)
For Sony Stereos, you will need to get what is called a Bus Converter. The RCA ports you are trying to use are for a CD changer or alternate device like satellite or HD radio, and those have to have some sort of frequency signal to even be selected. You can find a Bus Converter that will allow you to use this as an Auxiliary input. The device you are looking for is called a Sony XA 300, and it will allow you Two extra Aux Inputs, I believe.
Posted on Jan 29, 2009
  • 27 Answers
SOURCE: Sony CDX-S2210 CD Player stuck on demo mode
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Posted on Jan 29, 2010
Intermittent error code E-04 - CD won't play
I looked it up at Sony.com.They say E-04 means there is a problem with the CD changer(real helpful huh).It says you can press the reset button to reset your CD changer,but you will lose all memory and have to re-program it.The diagram looks like it has a removable faceplate?It is under there.Use a fine point to press it like a pencil.There is an * though and it says CDC-X517M only though.It also is basically the only resolution they give.They say if that doesn't work,you have to send it to an authorized AIWA center.
You may need PDF to look at the page.If yo do not have it,it is a free download,just google for it.I did it and you do not get ads popping up everywhere nor is it harmful.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=CDCX417pdf&sliceId=pdfPage_8&docTypeID=DT_MANUAL_1_1&dialogID=184603613&stateId=0 0 184607067 Good luck!
Jul 23, 2010 | Sony CDX-5290 CD Changer
Code 99
e-99 indicates that there is some type of mechanical jam, the microprocessor requires reset, or the system had some major failure. try to remove power from the system for a few moments, and then reconnect. this will rest the microprocessor and possibly restore function. if there's a disc stuck in the magazine, or stuck somewhere in the loading or unloading sequence, it's sometimes possible to free this but the changer will have to be removed from the vehicle and partially disassembled.
Jan 17, 2010 | Sony CDX-540RF 10-Disc CD Changer
I cant find the schematic diagram of Sony CD changer CDX-757MX
typy in on a google search sony cdx-757mx manuals or how to if i remember right it was e-support sony// i saw on there about a week ago//
hope this helps
Sep 29, 2009 | Sony CDX-757MX 10-Disc CD Changer
Need security code for my sony cdx-m8800
Sony CDXM8800 Radio Codes are available from the website - www.instant-radio-code.co.uk
Aug 07, 2009 | Sony CDX-M8800 CD Player
I get an error 4280 when I attempt to burn an audio cd
Apparently a common error; if you google error 4280 you'll get several different versions of what is happening. Some blame the Sony CD's other blame Dell, HP, etc...like I said there is a long list so I didn't want to pick out just one, it depends on your Computer type, combined with the CDs..so go ahead and take a look. Personally from reading some of the fixes I came up with; don't use Sony disc and run at 16x to get rid of the error. Hope this helps..
Please rate this solution.
Mar 18, 2009 | Computers & Internet
Cant play New MP3 CDs on CDX-FM687
have you tried using another computer to burn them as some of the latest updates will give u this problem if not there are probably some compatability issues
May 23, 2008 | Pioneer CDX-FM687 6-Disc CD Changer
Error code 99 on Sony CDX-525RF 10 Disc Ce
compre el magasine y no lo agarra y no sale como le ago
Dec 08, 2007 | Sony CDX-540RF 10-Disc CD Changer
Lost code
jobs a good un!
Sep 23, 2007 | Sony CDX-M610 CD Player
SECURITY CODE
hey could sum1 please give me a securitey code for my sony cdx-800 much appraitated
Apr 23, 2007 | Sony CDX-M800 CD Player
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
