Question about HP Pavilion dv9005us Notebook
Card reader failure
Why won't my card reader read xD cards? The message is: "Please insert card". It does see the card, but it won't read it. It still works with SD cards. I've checked for driver updates.
I assumed the front slot in my toshiba L450-13U is a card reader / why cant i insert my xD card?
Hi, please check if the card reader is all in one card reader. Because some of the card reader is not all in one, posible thing it can't support the xd card.
Another option you can buy external USB card reader. (all in one)
Mar 27, 2010 | Computers & Internet
Tip
You can purchase a Targus card reader from Walmart which will plug into a USB...
You can purchase a Targus card reader from Walmart which will plug into a USB connector on your computer. Directions on it's usage are included with the card reader. The package says it is compatible with SDHC SD/MMC, XD, Memory Stick, Pro Duo, and Magic Gate.I ran into a problem with the Targus TGR-CRD25 when trying to read an XD or SD memory card 1GB or bigger. Targus fixed it with a note on their web site:
To operate plug card reader into the USB port, go into "My Computer", click "Removeable disk drive", insert your memory card into the card slot and upload your data. Please remove your memory card before disconnecting the card reader.
on Dec 13, 2009 | Saws
Tip
Downloading picuters directly from your digital camera SD or XD card.
You can purchase a Targus card reader from Walmart which will plug into a USB connector on your computer. Directions on it's usage are included with the card reader. The package says it is compatible with SDHC SD/MMC, XD, Memory Stick, Pro Duo, and Magic Gate.I ran into a problem with the Targus TGR-CRD25 when trying to read an XD or SD memory card 1GB or bigger. Targus fixed it with a note on their web site: To operate plug card reader into
on Dec 04, 2009 | Cameras
OLYMPUS XD Card - CLEAN or FORMAT - and not reading in computer
Your 2gb xd card would be of the "M" or "H" designation, which is a new type of card which is not always compatible with many cameras and card readers. If the other cards that work are not H or M cards, that is most likely the problem
Jun 24, 2009 | Fuji FinePix A340 Digital Camera
XD card seems to have damaged card slot, won't boot anymore
I accidently inserted my xD card into my Fuji Finepix s5000 and i bent all the things inside to get it out... it is possible to replace to slot, or get it fixed? Please someone help
May 09, 2009 | Toshiba Satellite A105-S4074 Notebook
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
Xd clean card
me too , thats my prob .
Sep 25, 2008 | Olympus Stylus 820 Digital Camera
Problem with new XD card
This could possibly be a problem with the card reader ..Just insert a different card and see if it works..If it reads other cards..then i advice that you get new card coz the recovery softwares and stuff r pretty expensive and will be a waste of money..
Oct 30, 2007 | Fuji FinePix A120 Digital Camera
HP laser Jet 2840
Try using a different Memory card and see if it reads it, if not you might need to replace the memory card reader.
Oct 26, 2007 | HP LaserJet 2840 Printer
Memory card problem
Hi I suspect this is due to the printer being unable to read this size of memory card, as i have the same problem, where as it will read a 128mb card but not gb !
Feb 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
HP Pavilion dv9005us Notebook Logo
139 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
