Upon turning camera on get message-lense error, restart camera. I have cleaned camera with compressed air and still same results. To my knowledge it hasn't been dropped or mistreated in any way. Is th
Battery is well charged, no abuse of camera, always in case when not used, not exposed to water, dropped, or anything unusual, just stopped working and gives me error message- lense error,restart camera.
Could be sand particles getting into the seams around the lens barrel, binding it up. Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
I would get a card reader to connect the card to the computer. For the future, it will save wear and tear on your camera and doesn't use up the camera's batteries.
You can find them at any large store, such as Walmart or Target. Here's a link to one on Amazon:
Kingston 19-in-1 USB 2.0 Flash Memory Card Reader
I hope this helps! Happy Shooting!
Check to see that the lens aperture ring is set to the smallest (largest numerical) aperture setting (usually f22 or such). Nikon AF cameras have to have their lenses set at the smallest aperture for most of their program modes to work. Nikon AF lenses have a small slide or twist lock adjacent to the aperture ring to lock it in place at the smallest aperture. This may have been unlocked during the cleaning.
Another possibility is that the lens's electrical contacts were damaged during cleaning, so the body is not "seeing" the lens. Do you have another lens you could attach to the body to test this theory?
If i told you to smack it around a bit would ytou believe me?
But that is the fix Canon use to get rid of these errors 98% of the time. Charge or change the battery, insert it tuen camer on when it goes off smack it hard into your palm a few times and turn it back on. Just incase there is some dirt/dust stopping the lens from extending blow a can of compressed air around it and give it another few slaps . Sometimes after about 20-30 ngoes of this the camera will jump back into service Believe me it does work nearly all the time Canon charged me $90 to do this trick
While turning in off softely press the lense in and out a couple of times. The lense would retract. If not fully, but most of the way, push the lense a little harder in until completely retract. If you turn it on, I should work fine. The reason the lense does not retract is most likely some dust in there somewhere. If it did not help, you would have to open the lense and clean it and close the lense.
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your
lens needs to be cleaned or repaired, and if it cant be repaired it
needs to be replaced. There are online places that will do it for a
decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
*&%$@#%^&*&^% !!"It's working!!!!
Turn your camera on and put it near your ear. Did you hear a softly motorized sound in the lenses area and the green LED is flashing? If you hear this sound do this.
Do it under your own responsability. (any way your camera does not work).
When you turn on the camera wait until the lenses come out, in that moment grab the lens with your hand and don't let it go back. The camera will turn off but the lens will stay out.
With the camera off push in the lens with your hand. Turn on the camera and that's it. I had to do it 2 times, but now my camera it's working again. This system error could be caused because the lens get out of it rail and the camera can not set the focus system.
