Corruption in feature manager settings - Computers & Internet
  • 4 more comments
  • Anonymous Dec 23, 2008
    corruption in feature manager settings
  • Anonymous Jan 27, 2009
    the error displays when after booting the computer and when I start my air card connection.
  • jonajensen01 Feb 01, 2009
    Same Problem by Guest on Jan 31 2009
  • difriskyfeli Mar 04, 2009
    I received a pop-up that said, " Corruption hads been found detected in Feature Manager, back-up file has been loaded. Now my computer freezes and the scroll bar doesn't work for about a minute.
  • Anonymous Mar 31, 2009
    "Corruption has been detected in Feature Manager Settings - backup file has been loaded" pops up after turning on the computer. It doesn't seem to be causing any problems, tho.
  • salteesaltee May 15, 2009
    ATT aircard
    Problem Solver:
  • 15 Answers
Power Supply and Chassis Issues
No boot situations can be caused by any of the following power supply, chassis or fan issues:
  • Verify that your chassis and power supply is appropriate for the processor model and frequency and the desktop board you have.
    • An ATX12V or SFX12V with the 2x2 connector is required for all Pentium® 4 processor based and higher Intel® Desktop Boards. Power consumption requirements for high-end video cards, sound cards, peripherals, and the Pentium 4 processor will exceed the typical 5A current capacity of standard ATX & SPX power supplies.
  • Do not use 2x2 power cable adapters with non-compatible older power supplies.
  • Verify that the power supply has the capacity to power all the devices used in your system.
  • Ensure the power cord is firmly connected to the power supply and the AC outlet.
  • If the power supply or the AC outlet has an on/off switch, make sure that it is on.
  • Determine power supply voltage selector setting (230 volts vs. 115 volts) is correct.
  • Check for foreign objects inside the chassis such as screws that may ground the desktop.
  • Attach the desktop board correctly to the chassis base with the spacers/stand- offs. Make sure not to tighten the screws too much.
  • If possible, use a voltmeter to verify that each output from the power supply is correct. If any output is very low (especially the +5 volt output), consider replacing the power supply.
  • If possible, use a voltmeter to verify the PowerGood signal is +5 volts. If the signal is below 1.0 volts, there may be a short or overload causing a constant reset. Consider replacing the power supply.
Ok this may help you to trouble shoot your power supply and it may fix your problems,...I got it from Intel site
http://www.intel.com/support/motherboards/desktop/sb/CS-010254.htm#powersupplyissues
Please let me know if this helped
Thank you, Techlahj
Posted on Aug 22, 2009
What Web-based Management Features Do Switches Excluding the S1700 Support?
Table 1 lists the web-based management features supported by S series switches.
Table 1 Web-based management features supported by switches Category
Function System management Upgrade, patch loading, PoE, DNS, stacking, viewing log files, and setting the system time, SNMP parameters, and EasyDeploy parameters
NOTE: Switches in V200R002 and later versions support SNMP and EasyDeploy parameter configuration. Interface management Viewing/configuring basic interface attributes and viewing statistics on an interface Service management VLAN, MAC address, STP, voice VLAN, DHCP, ARP, VRRP, and IGMP snooping ACL management Creating/modifying/deleting ACL rules and effective periods QoS Priority mapping, traffic policy, rate limit on an interface, traffic shaping, and congestion management Route management Viewing IPv4 routes, configuring static routes, and setting the preference of static routes Security management Port isolation, static user binding, AAA, 802.1x authentication, and MAC address authentication Tools Ping, Tracert, and VCT S2300 Switch Thunder link com
Feb 09, 2017 | The Computers & Internet
Tip
USB PORT FIX WIN 7
Method 1
*For Microsoft Windows Vista (and windows 7) Click Start, and type device manager in the Start Search box. Click Device Manager in the Programs list. If you are prompted for an administrator password or confirmation, type your password or click Continue. In the Device Manager dialog box, expand Universal Serial Bus controllers. Right-click USB Root Hub and then click Properties. In the USB Root Hub Properties dialog box, click the Power Management tab. Remove the check from the Allow the computer to turn off this device to save power check box. Repeat steps 1 through 4 for each USB Root Hub listed in the Device Manager.
Under Power settings, check the 'USB settings' -> 'USB selective suspend settings' and make sure it is disabled.
Check Thumbnail, highlighted: Open Device manager, Double click on Universal Serial Bus controller at the bottom, Double Click USB Root Hub, Click Power Management on top right, Uncheck Allow Power...
Method 2
*You can disable the USB Selective Suspend feature as a workaround by editing the registry. The USB device may become unresponsive because of a race condition in the Selective Suspend feature. The Selective Suspend feature suspends the USB device to efficiently maintain battery power by enabling the computer to turn off the USB device. However, sometimes this feature may not correctly wake up the USB device. Therefore, the USB device is unresponsive when you try to use it. You might want to disable this feature for server products where power management is not important or required. *To disable the Selective Suspend feature, follow these steps: Click Start and then click Run. Note If you are running Windows Vista, click Start, and then use the Start Search box. Type reedit, and then click OK. Registry Editor opens. Locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\USB If the DisableSelectiveSuspend registry entry is present, double-click it. If it is not present, create the entry. To create the entry, follow these steps: On the Edit menu, point to New, and then click DWORD. Type DisableSelectiveSuspend, and then press ENTER. On the Edit menu, click Modify. In the Value data field, type 1 to disable the Selective Suspend feature, and then click OK.
on Feb 14, 2010 | Computers & Internet
How to recover Windows BKF file?
To recover BKF files, You need to Download BKF File Recovery Tool. It can nicely repair or restore corrupted or damaged and inaccessible BKF file without any trouble. That software provide facilitate multiple corrupted or damaged BKF file repair in single cycle. It is supports all BKF files created using ntbackup.exe and Backup Exec by VERITAS software.
For more information,Click here:- BKF File Recovery Tool
Jan 12, 2017 | Office Equipment & Supplies
How do I restore my files? my windows based computer does not understand a .bkf file type.
Download NT Backup Restore Utility
http://www.microsoft.com/en-us/download/details.aspx?id=4220
To run Windows NT Backup Restore Utility, you need to turn on Removable Storage Management.
To turn on Removable Storage Management
1. Open Programs and Features by clicking the Start button , clicking Control Panel, clicking Programs, and then clicking Programs and Features.
2. In the left pane, click Turn Windows features on or off. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
3. Select the check box next to Removable Storage Management to turn the feature on, and then click OK.
Nov 09, 2015 | SimpleTech 160GB USB 2.0 / FireWire...
BLOCK THAT POP-UP WINDOW.
N NEVER ENTER ANY PERSNL INFO...IN POP POP WINDOWS.......
ALL D BEST
Oct 03, 2010 | Computers & Internet
When i try to download something, it will go to getgo download manager. my getgo download manager is corrupted one. if i try for downloading, my system will stuck up. due to this, i cant download anything...
you will have to uninstall the Getgo download manager. to do so :
1. Open Control panel
2. Open Add/remove progrms ( XP ) or Programs and FEatures ( Vista and Win 7 )
3. from the list - click on Getgo Download manager
4. click on uninstall on top TAB.
Jun 16, 2010 | Microsoft Windows XP Professional for PC
How do I fix the pop up that says corruption has been detected in Feature Manager?
i have e dell latitude. a have forgotten my password. how to remove this password
Jul 01, 2009 | Dell Computers & Internet
Feature Manager Pop up & back up file has been loaded.
I received a pop-up that said, '' Corruption hads been found detected in Feature Manager, back-up file has been loaded. Sierra Wireless Aircard 881 Most of the time you can repair the feature file by opening and closing AT&T Communication Manager (ACM). If that doesn't work try this... 1. Close ACM. 2. On you computer browse to C:\Documents and Settings\All Users\Application Data\Communication Manager. 3. Delete the files called featuremanager.xml.rc4 and featuremanagerBackup.xml.RC4. 4. Open ACM. 5. If your still having the problem delete the entire Communication Manager directory in Application Data. 6. Uninstall and Reinstall ACM.
Try this and let me know if it helped you Thank you, Techlahj
Jun 07, 2009 | Computers & Internet
I keep getting an error message when I start up my laptop. the 2 wire gives me a "corruption has been detected in feature manager, backup file has been loaded", and it will not connect. All other programs...
If the machine is a Dell with DellControlPoint, open start, run then type msconfig and hit enter. Choose the Startup tab and find the startup item named "Dell" with the Command from "C:\Program Files\Dell\Dell Control Point\Connection Manager\Dell.UCM.exe" and uncheck the box. Hit Ok, then reboot your computer.
Jan 16, 2009 | Computers & Internet
Computers & Internet Logo
9,217 people viewed this question
David Payne
David Payne
