Question about Technics SA-EX300 Receiver
Technics SA-G9057 overload
I disconnected all the speaker and the problem continues (the screen shows the message overload), please somebody be able to help me?
Thanks in advance,
Marcelo.
  • Anonymous Oct 22, 2008
    Overload
Check the fan connections at the back. The connections (just two flimsy metal prongs) came apart (I believe), so I have had to re-enforce them with electrical tape so the connections stay together until I investigate a further replacement fan. For now the connections are extremely sensitive to motion/viberation/impact/etc... but it does work now.
Posted on Apr 03, 2009
  • csprevost1 Apr 03, 2009
    Now, before you open up the amp to check the fan, I MUST URGE CAUTION! The fan is right by the transformer. You have three plastic pieces that stick out to hold the fan in the amp case. two of them are in tight spaces, and one is precariously close to the transformer and power unit, and the other is close to capacitors. Of course I need not mention to unplug it for obvious reasons. Hope this helps!
OVERLOAD
1. unplug the stereo
2. check all speaker connections
3. open the cover
4. clean it [fan dust]
5. unplug the MAIN POWER connections, [ INSIDE THE STEREO ] let sit for 1 minute
6. PROBLEM SOLVED
Posted on Feb 17, 2010
    Problem Solver:
  • 19 Answers
If you are a technician, try remake every soldering of the Audio output Module ( The big Grey IC ) and to all the components who are fixed to the Big Aluminum Heat sink.This tipe of big thin heat sinjk tend to dilate ( change of size) and move up and down quite a bit due to the high operating temperature of this class of ampli.
Sorry for my bad english writing.
Spider Guy
Posted on Mar 15, 2010
Overload
Probably dry joints around the power amplifier.
Mar 18, 2017 | Technics SA-AX720 Receiver
When I turn on unit, a message "overload" appears.
Check the speakers and the power supply for any signs of shorting.
This is due to the fact that the safety circuit works to switch off the set preventing a high damage.
So check the output for short or the presection .
Sep 28, 2010 | Technics SA-DX940
On switching my technics sa-dx750 it says switching off overload
The question is what is causing the overload? The power supply or the output devices on the heat sink?
If you have accidently shorted a speaker wire, then the answer will be output devices, otherwise it could be anything in the power section. You may find a burnt or damged device with either of the causes.
Mar 08, 2010 | Technics SA-DX750 Receiver
OVERLOAD
First of all the KEF is a powered sub which means that it wants a line level signal NOT a speaker level. Send the signal from a tape output or pre-amp output to the sub input. The overload is because the impedence load for the speaker output is too low and looks like a short to the amp. Continued attempts to connect the system as described will result in damage to the output section of the amp.
Please let me know if you need more info.
Dan
Feb 03, 2010 | Technics SA-DX750 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Overload signal
The overload is the same as protect mode. Remove the speaker wires and turn the unit back on. If the message remains, there is a problem internal to the unit in the final stage of the amp.
Please let me know the results of the test above.
Thanks,
Dan
Mar 02, 2009 | Technics Audio Players & Recorders
Overload protection
Doe this always go into overload independent of the volume level? Try disconnecting the speakers completely and running the set. Does the set shutdown then too?
Thanks,
Dan
Jan 16, 2009 | Technics Audio Players & Recorders
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
Technics SA-GX470
over load means your speakers and its cable----please check it for bad cable or bad speaker------try to insert speaker one by one and test each time to investigate the bad one.--------if every thing is ok and you keep good ventilation around your receiver (no blocking of ventilation holes)and you still have a problem your protection circuit in your receiver needs to be checked by service technician
Aug 06, 2008 | Audio Players & Recorders
1,199 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
