Question about Epson Stylus CX6400 All-In-One InkJet Printer
Not workin' "Printer Error: See your documentation and call service if necessary" Under the hood there is a gold colored ribbon that rotates like a conveyor belt. It moves normally while giving clicking noises. The ink cartridges do not move. How can I fix this problem?
  • Anonymous Sep 30, 2008
    Documentation required
  • zing94 Oct 07, 2008
    I have the same exact problem. I received this printer second hand so it may have been damaged when I got it, but I would still like to know what the problem is and if it is worth fixing or not.
  • 706 Answers
I assume you've checked and done all the basic things like a power down and power up reset and checked to make sure all the ink cartdridges are properly installed and seated.
The user manual discusses your error message and suggests you do the following: Open the scanner unit to make sure any tape securing the ink cartridge holder has been removed; close the scanner unit/ press the ON button to turn off the CX6400, then turn it back on . If the error message still appears, contact your epson dealer or Epson tech support. If so,then you may want to get direct support and information from Epson at this website : http://er.epson.com:8001/start?TM=false&CMD=iSearch&CB=1886098358&LG=1&TP=NoviceCase&Q1-1-1886170412=1886170410&FI=1&firstQuestionID=Q1-1-1886170412&firstAnswerID=1886170410&category=allinone&model=cx64__&displaymodel=Epson+Stylus+CX6400&referralmodel=Stylus-CX6400&restart=yes
Technical Support Not workin' - line_dkblue.gif United States Phone Number:
(562)276-4382
Hours: Mon.- Fri. spacer.gif 6AM-6PM (PT) Canada Phone Number:
(905)709-3839 Hours: Mon.- Fri. spacer.gif 6AM-6PM (PT)
Posted on Sep 23, 2008
I got a color print ribbon and it won't install
Please post the configuration for the printer which is on the left side under the cover (white sticker) and your ribbon part number. If you are sure both are correct you may have a defective print ribbon or your printer will need service.
Feb 24, 2014 | Datacard SP35 Plus Printer
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Hi there, I got a Canon Pixma MX320. One year ago, there got the error of "Document in ADF" and actually there was no any jammed paper. I sent it to Service Center and was fixed. But two month...
If the device is not functioning properly or to clear memory, reset it. important.gif Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. for instructions to attempt a service reset.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Service Reset:
  1. On the operator panel, press and hold the <ON/OFF> button for one second to power off the printer. (The display will go blank.)
  2. Confirm the printer is not on and then unplug the power cord from the back of the printer.
    If the power cord was disconnected (as stated in step 1) in order to shut off the printer, go to step 3.
  3. Press the <ON/OFF> button repeatedly five times.
  4. Re-connect the power cord.
  5. Press the <ON/OFF> button to power the printer back on.
  6. Wait until the device has completed its cycling process before submitting another job request.
Solution:2 Load documents properly into the MX310 document feeder
Load the documents properly into the Automatic Document Feeder (ADF) Fan the documents and then align the edges before loading them into ADF.
  1. Remove all documents from the ADF.
  2. Fan out the sheets of paper well so that they do not stick together.
  3. Stack the documents on a flat surface to align the edges of the paper.
  4. Insert the top of the document, face up, into the ADF until a beep is heard.
Ensure that the edge of the document stack is in line with the Paper Size Mark (A) imprinted on the Document Tray.
Aug 30, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
How do I print using the foil ribbons? I do not see Gold foil as a color choice.I am interested in any info from a manual on this subject of gold or silver foil ribbon printing.
Your ALPS MD-5000 MUST be set to print in DYE-SUB. mode.... Is there a Memory upgrade plugged into the slot next to the Printer Port? If not, then it's not an option......
Feb 11, 2010 | Alps MD 5000 Thermal Printer
Printer error
This means see the document you are printing or install it again
Nov 19, 2009 | Epson Stylus RX580 InkJet Photo Printer
Red ! mark. LCD panel says: Error...Printer
The waste ink tank is full.Read this instruction.
If this not help there is a manual reset for this printers but I'm not tried yet.
  • Press and hold B/W+COLOR+STOP button.
  • Press power button, don’t release all button until you see the led indicator blinking and a message display on the LCD.
  • Release the button.
  • Press COLOR button to clear protection counter
  • Turn off the printer by pressing power button.
  • DONE!
Oct 28, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Ribbon Breakage
You can try to lower printhead setting values (color and black), if not resolved then try another ribbon, old ones trend to fail this way.
Regards
Jul 10, 2008 | Zebra Eltron P310I Thermal Card Printer
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX6400 All-In-One InkJet Printer Logo
188 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
