Question about Dell PowerEdge 1400 ( pe1400/210 ) Server
Dell PowerEdge 1400 Server Problem
When power is applied the server will not boot up. All I get is a sequence of beeps which continues to repeat. The beeps are as follows. beep--beepbeepbeep--beepbeep
  • 61 Answers
Check you display card
Posted on Oct 23, 2008
Failed memory.
Posted on Nov 14, 2008
I am having a problem with my dell poweredge 1800, it beeping continuous
Assuming this is still an issue...old as it is...
You need to boot the server and press the correct prompt to enter the BIOS of your PERC RAID controller. There you need to manage your physical/logical volumes.
Chances are that either you had a drive failure or the metadata on your RAID volume (JBOD?) was corrupted. This is a common issue with these LSI-based PERC[5-6]i RAID controllers that Dell utilized.
Jan 18, 2014 | Dell PowerEdge 1800 Server
Dell power edge 2850 make 4 seconds beeps alarm without stopping and without show any error Msg on the screen.
I don't understand the beep code you describe, but the 2850 has many beep codes to help understand what is going on.
First ... Identify the beep. Does the beep start as soon as you power it on, or after several seconds? What is the pattern of the beep - is it a repeating set of beeps - 3 sets of beeps between 1 and 4 beeps ... like 1 beep-3 beeps-2 beeps, or 3 beeps, 3 beeps, 1 beep? Or is it a steady repeating beep - about once per second?
Second ... is the LCD panel on the server blue or orange? If orange, what is the error code(s) it is scrolling?
If it is a steady, once-per-second beep, it is probably your RAID controller. Does the system boot to Windows/OS ok? If so, use (or install) OpenManage Server Administrator (Managed Node from Dell's Support Site) to check the Hardware Logs and check the RAID array (under Storage/Virtual Disks). If it is not booting to the OS, then go into CTRL-M to see what the status of your array is.
Aug 16, 2010 | Dell 3.0 GHz Second Processor for...
DELL POWEREDGE 6400 IS NOT BOOTING FROM THE CD
Go to your BIOS and change the boot sequence so that the system boots to the CD 1st. (You should see a tab or label that says Boot Order or Boot Device.)
Good Luck
C2S
Aug 13, 2010 | Dell PowerEdge 6400 Server
Dell server cont detect hard disk
chk for boot sequence in the BIOS and chk the hard disk is detecting in the BIOS
Oct 29, 2009 | Dell PowerEdge 1800 Server
Dell 1800 power edge is giving long beep continuously.
Power supply, system board, or keyboard problem
Apr 17, 2009 | Dell PowerEdge 1800 Server
Boot from CD is not recognizing the Windows 2003 Server CD
hv u tried booting from other CDs .
if u can boot from other CDs , then this 2003 CD is botched , change it.
Jan 05, 2009 | Dell PowerEdge 1600SC Server
Constant beep on poweredge 840 appears to work alright
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Apr 02, 2008 | Dell PowerEdge 700 Server
Beep sound
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology.
A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen..Use registered memory and it will be fine..
Oct 18, 2007 | Dell PowerEdge 1600SC Server
Computers & Internet Logo
848 people viewed this question
Alun Cox
