Question about Canon PowerShot SD850 IS Digital Camera
Camera won't power up even after battery has been fully charges...
Help!
The camer is only 5 months old! It died on me last week. I charged the battery overnight then placed it back in the camera and now it won't power up.
What are possible solutions? Thanks!
Rosalie
  • 489 Answers
Hi
If you have the purchase information you should contact Canon directly and get them to repair it under warranty. That should be your first step. You can call Canon in the US here: 1-800-828-4040 Have your camera with you so you can give them the serial number.
One thing you can check easily yourself is the battery door. Is it closed properly? There is a small switch that is triggered when the door is closed, if this switch (beside the memory card slot) is not activated the camera will not turn on!
If that's not the problem then I would suspect the fuse has shorted out due to static shock or some other source.
Hope this helps! If I can help with anything else please let me know, we are a digital camera repair business!
Good luck from: Darntoothysam com
Thomas
Posted on Oct 10, 2008
My camer will power up say battery low but shows to be full but goes off and will not come on and charge.
How old is the battery? Batteries do die with with time. Be sure to replace it with a manufactures battery, not an aftermarket one.
Nov 14, 2012 | Sanyo Vpc-t1496 14 Mp Digital Camera - Red
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
What are the Best replacement batteries for the Jazzy Select 6 and Where is the best place (retail store or online) to buy them? I bought the U1 Gel Batteries at wholesalebatteriesonline.com and they...
ggirl why did you buy a pig in the poke they should refund your money because the batteries should have a six month warranty. Now always ask for the date code on batteries you are buying they shouldn't be any older than 4 months old. There are good batteries out there but if I offend anyone I'm sorry but MK batteries are very good also Interstate batteries and probably others that I'm not aware of. The best way to insure good batteries are buying fresh batteries, Charge them before you use the chair and always get into the habit of charging overnite if you use the chair daily. Never leave the charger plugged in more that 12 hours and if you don't use the chair daily charge at least once a week and always put up fully charged. Mk recommends charging the batteries daily for the first 20 days. Never run the batteries or let them fall below the red light on your battery level indicator. Your chair runs on about a 5 volt range (26-21 volts) after that the red light blinks like crazy. If it falls below 20 volts the charger will not charge the batteries. If you take care of them they should last you 3 years or more. Hope this helps
Oct 19, 2010 | Pride Jazzy Select 6 Indoor Power...
I keep putting in new or recharged batteries and every time I get ready to use my camera if it over a week, it says change the batteries. This has just started happening the last 3 months. The camera is...
The rechargeable batteries, especialy NiCD and NiMH ones, loose they're charge over time. Even if fully charged, they loose all of the charge within a week or two. This is not a malfunction.
However, if you are using alcaline batteries and still get this problem, probably you have some electric problems inside (maybe some batteries leaked in the past). In this case try cleaning the inner contacts of the battery slot. If the problem persists, go to a local electronist for repairs.
Apr 12, 2010 | Canon PowerShot A570 IS Digital Camera
I fully charge the battery and recently it lasts just 2 days in the camera whether being used or not. the camera is just 5 months old. Would this be abattery or camera fault
Mine is over a year old. I typically need to charge it once a month if not in use and otherwise after about 800 shots without flash or 300 shots with flash.
Oct 26, 2009 | Canon EOS 450D Digital Camera
Battery not running
Possible that whoever replaced your battery sent you the defective one back. Note the serial and model numbers on the battery, then request another one. When you receive the replacement, do a full recharge. Most new batteries come already half charged. Even in this state, take time to fully charge it (between 4 and 8 hours depending on the type and model). Then try running it on battery power. If the charge holds more than 2 hours on a new battery, youre good; less than an hour new, its defective. If after all of this still not resolved, request the company honor their warranty (usually a limited one year with purchase).
Mar 01, 2009 | Dell Inspiron Desktop with Intel Core 2...
Canon dc100 wont swich on
The camera seems to have these problems, and I think its because the power switch is on when the camers is being charged.
Sep 11, 2007 | Canon DC100 DVD Camcorder
Canon PowerShot SD850 IS Digital Camera Logo
51 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
