Ethernet not working
I have a Medion MD96489 with Vista Basic. I cannot connect to the internet using the LAN port. On checking in Device Manager the Network has two drivers assigned to it, Realtek and Via. With the Realtek one enabled and the VIA one disabled I get a red cross though the LAN icon in the System tray with the VIA one enabled and the Realtek one disabled I get a blue circle in the System tray icon. However I am still unable to connect to the internet. Can you help in this matter please.
Deryck Campbell (deryckscampbell@talktalk.net)
bpcs
  • 112 Answers
SOURCE: The ethernet port is not working, and the network card is not being detected in device manager
If the device manager is not detecting the network device it is not going to work. turn off the laptop and remove the network/modem device located on the bottom of the laptop, then restart the laptop, now shutdown the laptop again and reinstall the device restart the laptop if device manager still does not detect the device then it is defective and will need to be replaced.
BPCS
Posted on Dec 06, 2007
SOURCE: Dlink Router not assigning IP to NAS
DI-624 (Update to FW 2.70+)
See: http://www.infrant.com/wiki/index.php/Hardware_Compatibility_List_-_Network_Switches/Routers#D-Link
Posted on Dec 29, 2007
edo333
  • 55 Answers
SOURCE: Realtek RTL8168/8111 Family PCI-E Gigabit Ethernet NIC (NDIS 6.0) code 10
Try the vista driver listed here
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=13&PFid=5&Level=5&Conn=4&DownTypeID=3&GetDown=false
Posted on May 01, 2008
Hi
My system Network adapter is not working. so i checked another one external card connect , at the time internal card automatically worked? how ? pls tell me i am very confuse
Posted on Jul 25, 2008
SOURCE: Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
Similar problem with XP Pro SP2, Intel 82562V-2 10/100 on Dell Vostro, Belkin G router. Windows will often say network cable is disconnected. I haven't isolated the problem to power management, but I wouldn't be surprised after seeing your post. Tried different cables, ports, and no other network devices have the problem. I just tried tuning off "reduce link speed during standby" in the network driver options maybe that will fix it. Before here are the things I would have to do to get it to work: unplug cable, wait (for several seconds), plug it back in, retry, retry, or restart the computer. When it isn't working there are no ethernet LED's on, if the lights come on when I replug the cable in then it works, but this does not always happen.
Posted on Jul 26, 2008
Asrock 4core1600p35-wifi+ lan port not working
Driver: Small piece of software that allows the Operating System to communicate with a device
http://www.asrock.com/mb/download.asp?Model=4Core1600P35-WiFi&o=Vista
Have you downloaded AND installed, the Realtek LAN driver?
If so tell me the procedure you used.
If that still doesn't do it use an Ethernet Card in an open expansion slot;
PCI
or
PCI-Express x1.
Post back in a Comment if you need guidance in downloading and installing the LAN driver.
Also for any additional questions.
Regards,
joecoolvette
Mar 03, 2013 | Asrock 4Core1600P35-WiFi Motherboard
"Ethernet cable unplugged"
A few things to try. Plug the cable into a different port on the router to rule out a bad port on router. Try a different ethernet cable (they do go bad). If this is an older router it may not be able to do logic swap on the pins and you would need to use a cross-over cable and not a straight through. Also check in device manager and make sure the computer is not allowed to disable the lan adapter in power saving mode. Also if your really want you can test your ethernet port by buying or making your own loopback plug. Look up ethernet stander T568A. You basically would buy a empty ethernet jack and run a short wire from pin 1 to pin 3 and a wire from pin 2 to pin 6. This will simulate sending data to another device (the other device will simply be the receiving pins on your own ethernet jack.
Feb 02, 2012 | Microsoft MN-820 802.11g/b (r88-00001)...
My acer 4310 connects fast to wi-fi pero pag internet cable na as in ung dsl hindi gumagana
When you plugged in the ethernet cable, does it show on your windows tray (lower right corner of the screen) that the LAN is connected? It should show you "Connected" if you hover your mouse on the LAN icon.
Try also to plug in the ethernet cable to a different port on the router, and that the port number on the router is showing a solid green led light.
If all has been observed and still you cannot connect, look if the network adapter for your lan is working. RIGHT click your My Computer or "Computer" and select Manage. The Computer Management window will open. Click on the Device Manager on the left to show the list of devices on the right. Look for Network Adapters and click the + sign. See if your LAN adapter is not showing any yellow exclamation point. Also, right click on it and select Properties. You should see the device is working properly under status.
Please let me know how this goes. Thank you for using FixYa.
Jan 22, 2011 | Acer Aspire 4315 Notebook
I changed my drive C to XP I had to format the disk and lost the software for the wireless lan driver,The application& support disk does not download it either for XP or for the Partition drive D which...
Use an Ethernet cable to connect from the network-port on your computer to one of the LAN ports on your router, to get Internet access.
Then, access http://WindowsUpdate.Microsoft.com
and click "Custom" scan.
When it completes, on the left, click "Optional Hardware",
and see if Windows Update is offering you a device-driver for your wireless adapter.
If so, check-box that driver, and install the update.
Sep 28, 2010 | Medion MD-40954 Notebook
Wireless connection to internet works. But when I take the eMachine 260 notebook computer to another location with only a LAN cable, the LAN connection to internet doesn't work. What's wrong?
hi there, first thing is to check if drivers for your ethernet is installed in your computer. you can go to control panel then system then device manager then look for network adapter. your ethernet device should be present there tand there is no exclamation point in front. if LAN device is not present, or with exclamation point, you may try reisntalling you LAN card drivers to fixed the issue. you drivers must be located at the driverdisk that came with the system.
thanks
Apr 14, 2010 | E-Machines 6809 Notebook
Spilled a drink on my lenovo2373, it turns on, winxp reboots but my internet connection is gone
check into the device manager to see if the lan card is still present ...or the wireless what ever you use to have on ....
if used to have a LAN cable Ethernet connection and it is not present in the hardware manager ..(device manager ) it is a problem detecting it or it is dead...
to go to manager ...just right click on my computer ..properties...than hardware and device manager ..there u will have a picture about all that it is on ...working ...what it is not present and it should be its not detected or disabled...and what is in yellow..with an ask sign has no driver anymore ...try first to right click on it if you find the lan card in yellow and update driver ...if it doesnt find it ..just insert the driver or reinstall it from where you have it ...
if you can not find another Lan card ...and is dead...check for the moment if your wireless is still functional ...and use it for connection ...just buy a cheap wireless router and install it in the wlan at home ...and you will have 4 ports with internet on cable ..and wireless to use with the laptop ..until you get another lan card to match...
lets hope is nothing that radical...and it just need a reinstalling ..it also may be still wet ..and cause dysfunctions.....gave it time ...and check it after you reinstall the windows in final...
anyway ..to get a router if u will have to use the wireless..will cost just about 30 bucks on ebay ...
Dec 25, 2009 | IBM ThinkPad T40p 2373 Notebook
How can i connect a toshiba runniung windows me. to the internet via ethernet cable? is it possible with just the cable and no card? is there a programe i can download to help my laptop? what can i do?
It should have a LAN (network card) built in to the laptop.
First of all make sure you have the LAN (network drivers) installed. You can do this by checking in device manager.
To open device manager click Start, point to Settings, and then click Control Panel.
Double-click the System icon. Click the Device Manager tab and look in the list for network adapters/controllers.
If the driver is installed you should be able to directly connect the ethernet cable to your laptop.
I'm not quite sure where the ethernet port is on that particular laptop but it will be on the back or sides of the unit and it will be the only port the ethernet cable fits into.
From there you should be good to go, if you can't get a connection reset the modem by removing power from it for 2 minutes, connect the power again, wait another 2 minutes for the device to settle and try the internet connection again.
Regards.
Oct 01, 2009 | Toshiba Satellite 1715XCDS...
Ethernet port not "active"
Hi there.
Restart the PC and go into the bios to make sure the on-board LAN is enabled, if it is try as jery says and try another ethernet cable.
Post back please and good luck
Apr 21, 2009 | Dell Latitude C400 Notebook
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Local area connection, no internet connection
My guess is the LAN port on your motherboard is bad. The simple solution would be to add a PCI ethernet card and disable the one on your motherboard in device manager.
Jun 18, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Computers & Internet Logo
David Payne
David Payne
