Question about Mitsubishi WT-46809 46" Rear Projection Television
Convergence Amplifyer I had occasional times when blue and yellow lines would pop up along faces sometime across the tops of heads and words would look slanted and blue and yellow. Then it would go away, when I would plug and unplug the TV Now it is there to stay. Would it be better to just buy a new TV, or spend $800 or $900 to have it repaired? It is a 9 year old Mits rear projector. Please advise me. Thank you
  • grannyglow Sep 23, 2008
    Yes, this is a 2000 56 inch rear projector...Thanks I'll get the book out.
In the manual are instructions for doing convergence. They are pages 46 and 47. It's worth a try because you can always go back and do a factory reset. It's easy once you try and kind of like a video game. Do you have the manual?
Posted on Sep 23, 2008
My print outs are having lines across them
You need to have your printer go thru head cleaning cycle. Check to make sure the ink is not leaking from the cartridge. Are you using OEM ink or second hand?
Jun 20, 2014 | HiTi P720L Photo Printer
Out of nowhere- The top half of the screen has the green coming down in swervy, double lines. Words are doubled and tripled. As well as, peoples heads and faces, etc. Is this fixable or time to say...
It sounds like a convergence failure. Often replacing the two Convergence ICs and the 6 associated resistors will repair that issue. You can get the convergence repair kits which contain the parts and the CD with instructions from www.tvrepairworld.com
Jul 21, 2011 | Hitachi Director's Series 57XWX20B 57"...
Green hazy upside down arch of color across the screen
Your convergence board is in need of reworking on a component level or replacing the board! And you will most undoubtedly need to resolder the vertical IC and all ICs mounted on heatsinks on the power supply board. This TV is showing its age. You may choose to repair and that may last a year more or so! Good Luck and thank you for asking!
Jun 20, 2010 | Mitsubishi VS-50605 50" Rear Projection...
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Color is mostly yellow and blue with double images
you have lost the convergence IC`s in your set, this really isn`t a diy repair unless you are very proficient in un-soldering and re-soldering components, once replaced there will be an alignment procedure as well that will require the service manual also, if you have more questions feel free to ask away, video-tek
Feb 04, 2009 | Hitachi 53UDX10B 53" Rear Projection...
A wavy line with 3 colors
this a convergence problem and the convergence IC's will need replacing along with some testing of resistors and or replacement
to have a technician come out to do this repair will cost about $300 - $350 to get this fixed
Dec 12, 2008 | RCA HD52W59 HDTV Projection Television
Red color not lined up
You can try making adjustments to the convergence in the user menu. If they still will not line up you will need to have the convergence ICs replaces along with a few resistors in the convergence circuit. Fairly common in many rear projection TVs.
Sep 11, 2008 | Hitachi 57F500 57" Rear Projection...
Hitachi 43FDX01B Convergence Problems
Hitachi remote part # HL01643........I like the original remote
to do adjustments.................T.
Aug 06, 2008 | Hitachi 43FDX01B TV
Hatachi 53uwx10a picture out of focas /words are also double and a yellow line about 10 inches thick sloops down from the top along the top of the tv
i replaced the ic's on the video convergence board ,wasnt hard . they were STK392-110 amplifiers , they had no heat sink paste on them ! everything else checked out fine
Jun 29, 2008 | Televison & Video
Sounds like there is a problem in the convergence circuit. There should be an on board cross hatch and controls to adjust the lines to a white line. If these control wont adjust then the power ICs in the convergence circuit are most likly bad. if you know how to solder and know how to replace electronic parts then get a service manual find the part #s and order the parts . If you dont know how I can teach you here sorry. But I will tell you that a repair like this will run about 300 to 400 bucks to repair. Good Luck
Jun 04, 2006 | JVC AV-56WP30 56" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
