Question about HP Officejet 5610 All-In-One InkJet Printer
It says printer cartridges missing or not detected cartridge error, or not deteceted, started with printing only partial pages, now nothing. changed cartidges, rest printer, still nothing
    Guru:
  • 558 Answers
Is it working perfectly before installing new cartridge.
Try to turn off and reinstall the cartridge again. Also shutdown the PC. Then power on PC & then Printer.
Do unplug before PC start.
Let me know the status. Dont forget to rate me if it help you.
Regards
ELLIN
Posted on Sep 23, 2008
HP Deskjet D4260 prints partially...
You can check the HP 74/75 ink cartridge's electrical health by running the Tap 41 diagnostics check...refer to D4200 printer procedure at the following Inkjet411 support page:
http://inkjet411.retailinkjet.com/?page_id=792
Apr 17, 2013 | HP Deskjet D4260 Printer
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I have an HP Photosmart A526 printer. I have tried 2 new cartridges and neither print yellow. I thought it was a fault with the cartridges but now think it may be the printer. I have aligned and...
There are two possible malfunctioning in this case.
  • Issue with the cartridge.
  • Issue with the printer.
Its better if we start resolving this issue linearly and logically first by following these steps as given in the manual on the following link.
Please click here:
Missing, Faded, or Dull ColorsIf the above doesn't help, we might try a printer reset to bring it back to the default print settings and configuration.
Performing a Partial Reset
  1. Disconnect any universal serial bus (USB) cables attached to the printer.
  2. Open the print cartridge door and remove the print cartridge.
  3. Close the print cartridge door
  4. Press the Power button to turn the printer off and wait for the printer to shut down before proceeding to the next step.
  5. Unplug the printer AC adapter from the printer and the wall outlet or surge protector.
    NOTE: The adapter itself has an overload trip that may need resetting, but will not reset if power is flowing to it.
  • Wait approximately fifteen to forty-five seconds and proceed to the next step.
  • Plug the AC adapter back into the wall outlet, and then into the printer, but do not plug in the USB cable.
  • Wait for the appropriate missing print cartridge error to verify that the printer can recognize this error.
  • Open the print cartridge door and re-insert the ink cartridge.
  • Print an internal test page.
    1. Remove any memory card, if inserted.
    2. Use the arrows (c01070297.jpg ) to highlight Print test page .
    3. Press Print to begin printing a test page.
    This is how the Test Page looks like:
    If still the printer is not printing the way it should, we might think of going for a HARD RESET by following the steps below:
    Performing a hard reset of the printer
    1. Unplug the power cable from the back of the product.
    2. Unplug the power cable from the electrical outlet.
    3. Wait 15 seconds.
    4. Reconnect the power cable into the product and then reconnect the power cable into the electrical outlet.
    5. If the product does not turn on, press the On button.
    This should bring the printer back to normal.
    Wish you luck.
    Regards,
    techbuddy247
    Nov 15, 2010 | HP Photosmart A526 photo printer
    Error message on printer:
    Unplug from the wall, press power button three times, plug back in. After trying all other solutions, this one worked.
    Aug 01, 2010 | HP Photosmart C4580 All-in-One InkJet...
    Printer cartridges missing or not detected. error message that comes up on my c4272 printer even though the cartridges have recently been changed
    Possibly dirty contacts. Try wiping the copper contacts on the print cartridge or, more likely, the printer where the cartridge makes contact.
    Nov 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
    I changed ink cartridge and now nothing is printing
    Did you pull the plastic tab off the ink cartridge?
    Oct 26, 2009 | Dell A940 All-In-One InkJet Printer
    Hp lj 2500 flashing yellow light
    The yellow-print-cartridge
    light is blinking, and the
    printer stops printing.
     The print cartridge is
    empty or missing.
     The printer cannot
    detect the print
    cartridge correctly.
    1. Reinsert or replace the print cartridge.
    2. If the print-cartridge light is still blinking but the
    Attention light is not on, turn the printer off and
    then back on.
    3. If the problem persists, repeat the above steps
    with yellow print cartridges until the error is
    resolved.
    4. If the problem persists, replace the printcartridge
    E-label reader, which is located on the
    pressure assembly of the print-cartridge
    carousel.
    Jan 09, 2009 | HP LaserJet 2500L Printer
    Canon Multipass F30 not printing
    Did you remove the tab that covers the cartridge head where the ink comes out, if the drivers and software that you loaded on your pc work
    good and your printer shows under device MGR, then it is the printer
    itself,,most times you can not see how much ink in the cart,,,most are sealed,,,just try to put the cart in again and make sure it is locked in good,,try running the cleaning program with pc,,make sure the right
    cart is in the right spot, bl in one spot and color in a spot.
    Dec 30, 2008 | Canon MultiPASS F50 All-In-One InkJet...
    Printer suddenly stopped printing
    verify if you are printing with the correct paper size..... long is 8.5 by 13 and not 8.5 by 14.....
    or
    1. delete the installed driver
    2. turn off the printer and let your computer detect the printer.... let it finish
    3. restart your computer
    Nov 09, 2008 | HP LaserJet 1020 Printer
    Print Cartridge Missing
    had cartridge refilled put back but comes up no cartridge
    May 21, 2007 | Lexmark Optra S 2450 Laser Printer
    HP Officejet 5610 All-In-One InkJet Printer Logo
    85 people viewed this question
    Seeker5211
    Seeker5211
    mukhtar21 shaikh
    mukhtar21 shaikh
