Question about HP LaserJet 4 plus Printer
Printer cant print excel files
The printer can print word files and that too when i select AUTO SELECT in the tray column in page setup menu, but this menu is not available in excel page setup and when ever i give print command it gives error PC LOAD LETTER. ive adjusted the paper size to a4 but it only prints doc files...help
  • dembo Oct 11, 2008
    i get the pc load error message every time I send to print mail from outlook express and from gmail.
    on the set up (advanced) paper size is letter although the default is a4.
    I have to change than manually on the printer set-up to paper size a4 otherwise the printer does not work.
    The default for the printer is of course a4 but
    I have another printer (sumsong) and I see that when i send to this printer from outlook and gmail it also shows letter size but it prints ok with no need to change set up.
    thanks for your help!!
  • HP Master
  • 1,113 Answers
Chjange the page size of the excel document, it at present is set to letter, ...file page set up in excel
Posted on Sep 23, 2008
  • Soulvisitor
    Soulvisitor Nov 19, 2009
    Some printers hjave an option to resize or ignore A4 / Letter paper size missmatch, normally an option via printer control panel, some ignore size missmatch, others dont, but either way, the correct method is change the document paper size of the document to be the same as the paper size set in printer driver... HP LJ4's do have the option in the menu to ignore a4/letter mismatch, check in menu settings on printer itself.
How to change Tally T2240/24 Matrix Printer character and line spacing
This sounds like an Microsoft Excel issue. The Windows printer driver controls how printing is done regardless of your printer settings.
Excel controls the format of your page with column widths and line height. Depending on your version of Excel, after selecting your print range and your margins, you will need to go to Page Setup and select "Fit to" -- select 1 page wide and a larger number of pages tall.
Jul 25, 2014 | Tally T2240/24 Matrix Printer
Tip
Microsoft Excel tips
Auto sum shortcut key
Quickly create a Microsoft Excel formula to get the sum of all cells by highlighting the cells you wish to know the value of and pressing ALT and = .
Create hyper links in Excel
Quickly create hyper links in your Microsoft Word, Excel, or Front Page document by highlighting text and pressing "CTRL + K".
Close all open files at once
Close all open Microsoft Word and/or Excel files by holding down the shift key and clicking "File" and then "Close All".
Quickly open recently opened files
Quickly open the recent files by first pressing "ALT + F" to open the file Menu and press 1, 2, 3, or 4.
Create underlines without any text
This tip works with the majority of Microsoft Office applications. Easily create an underlined space by pressing CTRL + U to start the underline, then press SHIFT + Space for each underlined space you wish to create. An example of how this could be used is for printable forms, for example: Name: .
Print only sections of a document
Save on your printer ink by selectively printing in Windows programs such as Microsoft Word, Internet Explorer, WordPad, Outlook, etc. To do this highlight portions of text you wish to print and click print. In the printer dialog window under Page Range choose the option Selection. It is important to realize that not all programs or printer drivers support this feature.
Repeat recent action
Using the F4 key in Microsoft Office 2000 and above allows the user to repeat the last used action. For example, if you have changed the font of a selected text and wish to change another portion of text to the same font, pressing F4 will do this for you automatically.
Quickly undo
Quickly undo mistakes in the majority of most PC Windows program by pressing CTRL + Z.
Quickly above cell contents
In Microsoft Excel press CTRL + SHIFT + " to copy the above cells contents.
Using the Microsoft Excel Auto filter
Organize cells quickly by using Microsoft Auto filter. Columns that contains long listing of data can be easily sorted by using the Auto filter option, to use this option select the top rows of the columns you want to be used and select Data / Filter and Auto Filter. Once successfully completed you can use drop down arrows to filter the data automatically.
on Dec 27, 2009 | Computers & Internet
Forces manual feed of paper whenever printing WordPerfect doc
Is a WordPerfect problem.
In WordPerfect go to file/page setup/select letter (or whatever)/edit/source - set to auto select.
Problem solved!
Jan 22, 2010 | Brother MFC-7820N All-In-One Laser Printer
Trying to print but it ask me to load paper or form feed. also got a bypass tray message.
Sound like the computer printer preferences "paper source" is set to bypass if set to "auto select" select the tray you want. Also make sure type of paper matches what is in printer.
-Carl
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Prints from Manual Tray instead of Tray 4
Open a document. Select File>Page Setup and change the Source to Tray 4.
Or...
Try to print something. When the Print window comes up, select Preferences. On the Print/Quality tab look for the drop down menu labeled "Source is:" and change it to the tray you want. Click on the Save button.
Here is more info from HP:
HP M9050 Tray Configure
Apr 16, 2009 | HP LaserJet M9050 MFP Printer
I have DELL color laser printer 2130cn error msg load SSF ??
Its not a printer problem more of the paper source of that document is selected as SSF. So in most programs go FILE>PAGE SETUP. Select the paper tab and make sure the correct tray settings is selected. I.E "Default tray" instead of "SSF". cLICK "Default" at the bottom to make this the standard document settings and the problem shouldn't crop up again.
Apr 09, 2009 | Dell 2130cn Laser Printer
C6180
load the paper in the tray
go to file menu then page setup.
select HP all-in-one printer
choose the paper size, orientation and scale percentage
chick ok then choose print from the file menu
configure the print settings suited for your project.
click print
make sure that you choose the correct paper type before you click print.
Nov 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
My hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Sep 23, 2008 | HP LaserJet 4 plus Printer
Ricoh CL3100N
Have you setup for double-sided printing?
Jul 15, 2008 | Ricoh Aficio CL3500N Laser Printer
HP LaserJet 4 plus Printer Logo
558 people viewed this question
Seeker5211
Seeker5211
