My halstead combi boiler keeps flashing the power light i have reset it but no joy there is power and gas supply not sure what wrong with it
  • 13 Answers
SOURCE: radiant combi boiler put hot
either defective sensors, or check the flow temperature going into the plate heat exchanger, if this getting very hot, but not circulating out the other side, it will probably be a blocked or restricted - replace
Posted on Mar 03, 2009
  • 30 Answers
SOURCE: Vaillant combi boiler problem
when the tap is turned on and the water light on the boiler doesn't this means the diverter valve is not operating it could be down to low water pressure in the house this can be checked at the cold tap in the kitchen. if there is plenty of pressure then it could be the diagphram in the diverter valve is worn or split. the diagphram is only a few pounds but it depends on the engineer you get as to how much money he wants to fit it.
the egg timer symbol (or two pyramids together) is an ignition indicator turn off and on again to see if it will fire with the tap running. reset the boiler with the lower right hand control knob.
Posted on Mar 26, 2009
  • 163 Answers
SOURCE: We have a Halstead Ace
What is the model number? Do you know the fault number?
Posted on May 10, 2009
gasman44
  • 83 Answers
You need to get a qualified 'Gas Safe' engineer to check the Venturi in the flue, and clean it out. The other thing to look at is the igniters, clean them wirth emery paper as this boier relies on flame rectification (ignite and sense flame)
The other important aspect which also hasn't been mentioned is to check the inlet and working pressure (as i have had a faulty gas meter governor before)
Quite often the simple faults are overlooked and everyone goes for the PCB, It is doubtful it's a loose wire on the gas valve, The best advice is to get a gas engineer in and for him to call Halstead while on site.
Be very careful when working on your own gas boiler, as any mishaps, and your house insurance is void.
Posted on Jul 10, 2009
sloooo44
  • 235 Answers
SOURCE: I have moved into a
Can you please get a part number? I t might be on the outside of the unit. If not, you'll need to remove the front covers. There should be a nameplate with a model number, serial number, amp, volts, and other info. Let me know what that says.
Posted on Sep 28, 2010
After moving my gas meter from inside the home to outside and having a semi concealed meter connected we cant get the combi boiler to work properly we can get hot water and have the gas fire on but
your boiler needs a minimum gas pressure of 16 mb to light successfully. if your gas pipe has been extended it has to be able to flow enough gas. it may need upgrading to 28mm for even as little as a metre from the gas meter. if your central heating works ok when the fire is off then this is your problem
Oct 12, 2014 | Water Heaters
Halstead 102 combi boiler dhw/ch run for 1second then goes off
You might try cleaning the flame detector. It sits in the combustion chamber and looks like a small bent nail fixed to the burmer [usually at the rear]. Use a medium emery cloth and make sure that the gas holes around it are clean and clear of debris
Apr 18, 2014 | Water Heaters
Halstead Finest Gold Combi Boiler water input temp
I know of no limitations on the temperature of the inlet water for any boiler. The warmer the water, the less energy it will take to heat it to desired temp and the colder the water, the more energy it will take. Extreme temps over an extended amout of time in either direction can stress a unit and could possibly, only possibly reduce service time.
Mar 31, 2009 | Water Heaters
Combi Boiler - Hot water pressure low
the coil inside got clogged
Dec 22, 2008 | Water Heaters
Heating & Cooling Logo
300 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
