Question about Indesit W 123 Front Load Washer
Bearings i need to replace bearings do i need to remove drum to do this please
  • 99 Answers
Yes all bearings and seal avaliable.
Posted on Oct 11, 2008
Exacly how to remove rear brake drums ? 2001 Ford Focus SE. I don't want to remove the hub & spindle. I simply want to replace the drums & Brake shoes.
The drum and hub are one assembly on that vehicle so you will need to remove the dust cap in the center of the drum and remove the large axle nut. The drum/hub/bearing assembly will then pull off of the spindle.
If you want to replace the drum you will either have to find one with a bearing already installed, Have your old bearing pressed out of the old drum and pressed into the new drum, or have new bearings pressed into the new drum.
When installing the new drum it is very important to tighten the axle nut to the proper spec. I can get that spec for you if you need it.
Apr 06, 2011 | 2000 Ford Focus
I need to know how to change the rear wheel bearings on my 1997 Dodge Grand Caravan.
Hello pixxi 29: My name is Roger and I will help you. To replace the rear bears would be impossable to do. THis is a sealed unit you must replace the entire hub and bearing unit. To do this raise and support the van. Remove the rear tire and wheel. Remove the brake drum to expose the hub unit. Remove the 4 bolt that hold the hub onto the backing plate. Reinstall with the new hub and bearing and tighten the bolts. Make sue they are tight replace the brake drum and tire and wheel. Should you need further help please just ask. Please rate the answer you received. hank You for using Fix Ya. Roger
Sep 23, 2010 | Dodge Grand Caravan Cars & Trucks
Replace drum bearing ... in a ASKO W6551 step by step
you need to remove the drum start at the front remove front panel,four screws 2 under front,1 behind soap drawer and the one near the filter,next take door off 4 spring clips on the next panel plus screw on door lock,remove door lock,then undo clamp band,bolt at bottom and remove counter weight panel (heavy).remove stainless steel inner panel,use a screwdriver to loosen,from the back remove drum pulley.the drum will then pull out.replace vseal and bearings.hope this helps
Jun 05, 2010 | Asko WL6511W Front Load Washer
Dryer squeaks when clothes are drying
Squeaking can mean bearings going bad or the pulleys needing some oil on them. The pulleys can usually be accessed from the rear of the dryer. The bearings are a different story, you would need to remove outer casing of the dryer to remove the drum to get the bearings behind the drum. I would recommend trying to oil the motor and idler pulleys and if that doesn't fix the problem if your handy you can try to replace the bearings. Its a big job, the bearings are behind the drum and are screwed in from the inside of the drum. In order to remove the drum the casing of the dryer had to be removed, usually the front and the top (the top will sometimes tip back on hinges). After that the drum should slide out with the bearing assembly attached. Installation is the same as removal. {Note: If you find it to be too much trouble, I would just leave it squeak, other than being annoying it won't hurt anything. Also, some dryers have a compartment in the back where you can see the bearing assembly, maybe you can spray some WD-40 in there and see if it stops squeaking. The time you really need to replace the bearings is if your drum is loose, as the bearings have gone bad, not just squeaky}
May 12, 2010 | Dryers
Hotpoint WMA48P bearing replacement
REMOVE THE POWER PLUG FROM THE SOCKET
this is a messy job, you will need to remove the lid remove the front of the machine 2 -3 screws behind the clip on pannel front bottom I cant rember if the front hangs on two lugs one either side or if there are acouple of screws behind the faceplate, you will need to disconnect the door safty switch (make note of the wire positions), remove the wire band that clamps the door seal to the outer drum, now you should be able to see the drum and the drum outer casing, you will neeed to remove the access panel from the rear of the machine and if the belt has not already come off remove it , you notice a large nut holding the flywheel on inspect closely as there may be some securing tags (large washer with folded edges stopping the nut from comming undone ) remove nut , you will now need to remove the drum from the front of the machine using a peice of wood place on shaft and strike it with a heavy hammer or a mallet do not worry about damaging the shaft as you will need to replace this as well as the bearings as when bearings fail it is normaly to do with water getting to the bearing and corroding them (rust) untill they give up this normally damages the shaft, once the shaft is removed if you look through to shaft hole you will see the outer casing of the beaings thease need to be removed normally by tapping out (not always easy)there are two one at fromt one at back the back one is removed from inside the drum front removed from rear of machine , once this is all clear you are ready to the reverse putting it all together, the bearing kit should contain all you need to replace the bearings including the spider ( the three legged fitting that connects to the drum and has the shaft on it) when replacing the bearings make sure that where the old bearings come out of is nice and clean (fine sanpaper to remove small high spots) i use vaselene to aid bearing seating , using a rubber mallet genlely tap the edge of the bearing into place (never hit the center of the bearing as you could damage the seal and or the bearing) when the bearings are in smear some grease onto the shaft and rfit, a bearing kit trade is about 20 uk pounds
Jan 15, 2010 | Washing Machines
NEED TO REPLACE REAR BEARING.GOT A NEW BEARING.NEED A DIAGRAM ON DISSASSEBLE,REPLACEMENT AND REASSEMBLE. OR SOME HANDS ON ADVICE....THANKS ..TY
really tedious job. if you are really keen, pl. follow.
remove motor, remove shoker top pins, remove top stone, remove all hose connecting drum, remove heater/other connections, remove door gasket from front, support drum from top, remove springs, lower drum, dismantle drum in two pieces, remove inner steel drum.
well rest i think you can think yourself.
Oct 30, 2009 | LG WM-0532HW Front Load Washer
WATER LEAK ON REAR OF DRUM AND EXCESS MOVEMENT hOOVER1400 HPB145
If there is water leaking then you need to repalce both bearings and the seal that sits around the drum shaft and protects the bearing. Check the brass collar on the drum support thats sits in the bearing is not worn or grooved.If it is the shaft and/or the drum need replacing too
Sep 22, 2009 | Washing Machines
Left rear wheel bearing
Hi
Quite easy !
Slacken your wheel nuts, Jack up the car, support on an axle stand, remove the wheel.
Knock off the little domed dust cap with a screwdriver.
Remove the split pin, and undo the nut.
The drum should now pull off if you remember to let off the hand brake !
Pull out the inner seal and the bearing race will fall out, also remove the outer bearing race.
Now you have to knock out the 2 bearing tracks from the drum hub.
Clean up the drum, carefully tap in the 2 new bearing tracks with a socket, and then grease the bearing races liberally with LM bearing grease.
Fit the bearing races to the drum, along with the new seal, and refit the drum, tighten the castle nut, then just back it off slightly, and fit new split pin, and then the dust cap.
Back on with the wheel, and give it a spin, and check for play by holding tyre, top and bottom.
Good Luck !
Let me know if you have any problems !
Give me a FixYa Rating Please.......Nearly a Guru !
John.
Feb 05, 2009 | 1995 Geo Metro
Removing/replacing main drum bearing on a zanussi WDT1085
Yes you do need to remove the drum, it entails stripping the washer down, and it is normal practice to replace the complete drum half with the bearings pre-fitted..
It is not a job to undertake, unless you feel competent to do do it, as it entails al ot of work and time..
Good luck if you decide to proceed.
Plz rate my suggestions.
.Thanks.
Jan 03, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Candy drum bearing replacement
Hello
This is fairly straightforward but little hard work to remove and fix. If you have Candy Washing machine such as model CE430 which is fully automatic electro-mechanical with AC motor , the replacement will be as follows that I have done successfully
1. Remove the belt and motor, then remove the hex nut on then drum pulley. But pulley may not come out. It is suggested to remove the hex nut whiled drum on the frame because it is easy to remove while it is on the frame.
2. Take the complete drum assembly out of the washing machine frame.
3. Leave the drum assy on a bench with pulley side upward, use puncher to tap onto the center of the drum spindle, make sure that you will not damage the screw threads on the spindle. the spindle should go down the pulley should pop up.
4. Then keep punching until drum spindle and the “Y” arm assemble comes out.
5. Now you will have the pulley and drum and Y spindle removed. the 2 bearings and water seal still in the drum casing.
6. Use rust cleaner chemical or spray to dissolve the rust off. Then use either bearing puller or use iron puncher to tap on the bearing gently but hard , may use 1kg hammer and take each bearing out. The inner bearing will come out with the water seal.
7. How to get the spare parts; these parts are very common in this geographical region ( Asia). You can buy generic parts. Get the mechanical specifications on the bearing to buy the bearing. The water seal which is generally referred as oil seal, look for specifications such as specs will have inner & outer diameter and the height ( width) ie 22 mm, 40mm and 10mm for water seal of the Candy CE430. Make sure you have the exact shape of the water seal as the original one.
8. Install back the new parts: you need to smoothen the spindle and clean the area as well. to have less friction , smoothen the spindle surface using sand-paper, it will be easy to press the bearing and the spindles.
9. 1st you install the bearings. You need to add thick lubricant in between the inner bearing and inside of the water seal. Then insert the water seal as well.
10. The drum spindle can be inserted to the bearing, you cannot use iron hammer because it will dent the drum, you need to push and may use wooden plank warp with thick cloth like towel to batter on to the center of the drum gently, if the spindle is smoothen properly it should go in with out a hassle. Make sure that drum rotates freely, then pulley can be installed.
11. The drum bearing replacement is completed
12. Re-install the other parts back.
Pub
Jun 12, 2008 | Candy AQW130 Front Load Washer / Dryer
Indesit W 123 Front Load Washer Logo
91 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
