The fan and fan shroud need to be removed as one assembly. You will need a 34mm wrench to get the fan clutch removed from the water pump. Once the fan clutch is unthreaded and the bolts that hold the fan shroud to the radiator are removed you will be able to remove the fan clutch/ shroud assembly from the vehicle.
You do not need to remove the radiator nor can you remove the radiator without first removing the clutch/shroud.
You will notice that when you are removing it it will be a little tight getting around the inlet for the upper hose on the radiator . Once the shroud is removed trim a notch where the shroud was hitting on the inlet and I will make install a lot easier.
If you have any questions let me know. Thank you for using fixya.com!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
