Question about GoVideo Go Video DVD/VCR Combo
Samsung ht-tz315 subtitle character problem
Hey all.New here.
I have a Samsung HT-TZ315 home theater system at home,I live in Turkey and usually pick Turkish subtitles for movies.Anyways,when I plug in my flashdisk from the usb and want to play the divx movies,English .srt files seem to be working fine,but for Turkish .srt files all Turkish characters are replaced with "_" s,thus making it unreadable.Is there any way for me to make the dvd player recognize and show the Turkish characters ?.Should I just call the technical service for this?.I was also looking for the "region free" codes and found it here as well.Great site.Thanks a bunch.
Regards from Turkey.
  • 4 more comments
  • Anonymous Nov 23, 2008
    I have same problem. I'm from Finland and ä:s and ö:s goes "_"
  • Blas007 Dec 25, 2008
    i have same problem whit finnish characters ä and ö
  • Anonymous Jan 05, 2009
    I have the same problem with Greek characters
  • shervin1358 Jan 13, 2009
    i have this problem with Persian & arabic characters "---- ---- ---- @ --- "
  • stevenchen19 Mar 08, 2009
    I have the same problem with display chinese characters.
  • akaramallis May 01, 2009
    I have the same problem with greek sutitles too...
    Top Expert:
  • GoVideo Master
  • 75,581 Answers
Hi Old man
You're going to be in trouble. Beware.
Posted on Apr 11, 2017
  • 4102 Answers
SOURCE: Bad disk
if this disk plays on other sources then it is not the disk and sounds like it is a problem with the laser or the motor that pushes the laser along the disk if it dont play no disk at all then it is the layser if you have used a good quality lense cleaner and that didnt cure it then you could try if you are ok taking the case off leave it for 24 hours to make sure no electric is running through it and look where the laser eye is it should be neer the middle where the center of the cd sits if it isnt gently push it back to the middle this will recalibrate your laser then put it back together and try again if this dont work you will then have to get a replacement laser unit these can be expensive but you should be able to fit it your self as the wire areconected by conector but before you do this make sure you use a good lense cleaner as the cheaper ones wont work all the time and listen if the cd is spinning in the unit if its not spinning then you need replace the unit if you dont feel up to it then a repair shop will do this for you their si no way round it other than to replaceit they usually last the life of the warranty they are made to last no longer hope this is some help but not much more you can do
Posted on Oct 30, 2007
SOURCE: DVD sound problem
Go into the setup menu into the audio options (use arrows on remote to go up and down menu and press left to enter the next menu to change options). By memory when I was running this just through a TV and not through a surround sound system, I had to turn off the addition speaker options in the audio menu. The one's like centre speaker etc have an small/large/off option. I had to turn these off so that all sound would come through the TV speaker only. That is about all I remember as I was trying to get this running for my aunt and I no longer have the DVD player.
Posted on Dec 01, 2007
SOURCE: I cant view DivX Film Subtitle in Sony DVP-NS67P home DVD player
Hi Ramink..
Try the program Sub2Divx (I have the same DVD sony dvp-ns67p worked properly). It takes just 2 minutes to put the subtitle in divx and is not fixed, only appears when tight subtitle on the remote control. I have a link to a tutorial but it is in Portuguese. (http://www.forumpcs.com.br/viewtopic.php?t=195697)
[ ]'s
Ricardo Liu
Posted on Jan 17, 2008
  • 416 Answers
SOURCE: Unable to play a DVD movie
Most probably the TV system is not compatible.
This VCR/DVD uses NTSC formate. Is the DVD in PAL formate. Also the Region code can be different. This DVD palys DVD-Disks with regional code 1 or All.
Posted on Dec 09, 2008
  • 321 Answers
SOURCE: keep getting
your laser lens need to be clean/use a qtips and wood alcool /ject disk open cover keep door open
unplug dvd and you will see the lens just wiped whit the q tips ,gently and you done it should works fine
put the cover back and try it;if it wont work you may have to replaced the laser assembly its easy..
hope that will help you
regards ALAN
Posted on May 06, 2010
Testimonial: "Thank you so much -- I'll try your suggestions. Beats having to go buy a new machine!"
I WANT samsung home theatre ht tz315 remote control. from where can i get it?
These are the setup codes to check with. 2066 2052 2097 2180 2027 2130 2056 2102. If you wish to get more details, check the sites linked here. http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Pull up previous posts, either by entering the brand name to your device in the search box of the display window, or view it in Mosaic / Flipcard / Timeslide option
Aug 23, 2013 | Televison & Video
Samsung home theatre ht tz315 shows
Clean the rear panel fan. It is probably dirty.
Aug 16, 2013 | Samsung Audio Players & Recorders
Can i buy a 3d blue ray samsung dvd player and plug my HT-TZ315 unit speakers to it?
No. A stand-alone 3d player will not have an amp in it to power the speakers. You would be better off purchasing a new 3d surround system.
Jan 17, 2013 | Samsung SWA-4000
Samsung dvd player switches itself onto protect!
hi,i can't connect my audio tv to cinema theater dvd
Apr 02, 2010 | Televison & Video
Removal of region codes
PRESS KEY " ENTER 84269 ENTER "
Oct 28, 2009 | Samsung HT-TZ312 Theater System
Problem "protect"
Hey guys, just had the same problem and found out it was because I had disconnected the central speaker. This it was creating a back impedance or something and reonnecting did the trick! i.e. check your speaker connections and check that they work... duff speakers could cause the problem too!
Sep 20, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Samsung HT-TZ315 Holding "REMAIN" Button
Can you help me, please ?
I have a problem with my samsung. On my screen write "FUN CHK" and I can do anything and in the moment my samsung is turn off. I have read guarantee but I could't find this problem.
Thank You !
Aug 03, 2008 | Audio Players & Recorders
Samsung ht tz315 unlock code
i JUST tried the unlock to multi region for my samsung ht-tz315 and it didn't work does anyone have a crack for this please. thks
the code was
Turn On player with remote
Press Enter on the remote
Press 8, 4, 2, 6 and 9 on the remote
The player will power Off
Switch On power from remote
does not work
Aug 01, 2008 | Televison & Video
GoVideo Go Video DVD/VCR Combo Logo
361 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
