52" JVC Convergeance won"t line up and the remote doesn't help adjust it
  • 4,234 Answers
Either there are bad connections on the pins of the convergence ICs or the ICs are defective. If you can solder, you shuold be able to resolve this yourself. Figure on $40-$60 for parts plus the local labor rate if you decide to get this repaired. If you wish to do this yourself, update this and I'll provide more instructions.
Posted on Sep 23, 2008
I have a jvc 52g78 but I no longer have the original remote control and somehow it got stuck on digital..anyway to put it back on analog with out the a/d button that's on remote
i am sorry but there is no other way to do this without the original remote. i had the same thing happen to me and i called jvc and thats what they told me. so i went on line and found one at
Aug 05, 2013 | JVC HD-52G787 52" Projection Television
Where is the ZOOM button on the remote?
There are som remote control, that doesnot have zoom. However you must read the instruction manual. IF you do not have download for free. or
God bless you
May 08, 2012 | JVC RM-C18G-1H Remote Control
Picture adjustment for JVC HD52G886
Here is the manual, also may need to go into picture advance settings to do some calibrations.
Apr 02, 2012 | JVC HD-52G886 52" Rear Projection HDTV
My 52 " GE Projection
Tv needs to be realined by adjusting the Screen Drive Controls to Tubes.
Located behind the Front bottom Panel on front of Tv.
Focus/Screen Control Block 3 on top for focus and 3 under them for screendives to each Tube R/G/B.
Jul 03, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
The colors are unalligned and the picture is blurry
hello,,the deffective part of your tv probably the convergience ic,it is a 2 pcs big ic with heatsink mounted on the mainboard you can replace it with a new one..or try to adjust first the allignment of your cathodes the RGB cathodes..on your front pannel there is a convergeance manual allignment button use this button to allign the convergeance..on your remote control there is also an allignment command consult your manual for the command .after the adjustment you must save the adjustments before exit the convergeance adjust..if thris adjustment do not work replace the convergeance ic ..mostly the ic is labeled STK XXXX..
GOODLUCK i hope i this helps you..
please rate my help tnx.
May 29, 2010 | Philips 51PW9303 51" Rear Projection...
Colors are not lining up on the screen
I'm sorry to say, but alpug is not correct. The problem here is either poor connections at the convergence ICs or defective ICs. These are large black ICs attached to a heatsink. If you can solder, resolder the pins of these ICs and try again. If that fails, the ICs are likely to be defective. They will be marked STK-xxx. Replace them and make suer that you use heatsink compound when attaching the new ones to the heatsink. Also, there are either small pico fuses or low valued resistors that may be open in the same area.
If you wish to attempt this repair, please update this and I'll provide additional details.
May 20, 2010 | Sony KP-48S65 48" Rear Projection...
52 inch has double vision like the red and gereen colorr are serperated.
the convergeance is off. some remotes allow you to tune this in the setup menu on your television. in most cases though this is something that has been caused by moving the television around or just plain ole time. if you cannot correct it using your remote and the normal menu on your tv then you will need to contact a repair technician in your area to schedule him/her to recalibrate your tv and repair the separating 3d looking issue that is common with convergeance.
Good Luck!
Jul 20, 2009 | Philips Magnavox 9P6034C 60" Rear...
Blue convergeance
Can you use a meter and solder? If you I can help you fix it. If not you will need to call a repairman. let me know what you would like to do!
Tim Nolan
Sep 13, 2008 | Sony KP-53S65 53" Rear Projection...
Remote LOST - need info on what button to press...JVC AV-48WP30
There might be some features that the universal remotes aren't able to do. To perform the convergence alignment you should have the original remote.
Do you have the user manual or service manual?
The service manual will explain this process better.
Apr 10, 2008 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
