Question about Frigidaire Kitchen Ranges
ON my Gas range there is and F3 error code comes up when I turn on the oven? please help!!
  • 943 Answers
Hi thanks for the question f 3 fault code shows a open oven sensor replace this part its located in oven left top corner looks like a small pencil remove from back and replace thanks please accept and a positive feed back thanks the appliance doc
Posted on Sep 23, 2008
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
www.partselect.com/JustForFun/Amana-Appliance-Fault-Codes.aspx
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges-cooktops/143114-amana-g...
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from forum.appliancepartspros.com
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
Tappan gas range model 30-3991-23/03 - when the oven is heating, an F3 code comes on, followed by an F2 code. The oven turns of and I can't heat it again until it has cooled. Can I repair it myself? ...
Hello & Welcome to FixYa
F3 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 15, 2011 | Tappan TGF320 Gas Kitchen Range
F3 keep showing up on oven screen and when i turn on the eye it never come on it just clicks
Hi harrismarvin,
The F3 fault code description is a shorted or open oven temperature sensor (RTD). Please check the sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope it helps.
Thank you for using FixYa.
Mar 27, 2011 | Magic Chef 31000 Gas Kitchen Range
Oven wont come on f3 code magic chef gas range
Hi hardcaseone,
Hope it helps.
Oct 28, 2010 | Magic Chef 31000 Gas Kitchen Range
Oven goes out ,display flashes --F3-
Hi jstpchy1953,
F3 code error means open oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Oct 24, 2010 | Tappan TGF320 Gas Kitchen Range
Error code F3 and F5
Hello there:
Here is the code for these 2 codes hope they are very helpful for you
F3
Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
Feb 04, 2010 | Maytag CWG3100A Gas Single Oven
Oven will not turn on
Hi mcifaretto,
F3 code error indicates a bad oven temperature sensor (RTD). To fix this error, Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope this helps.
Oct 08, 2009 | Tappan TGF320 Gas Kitchen Range
F3 error on magic chef electrical range
Hi glrecu,
Hope it helps.
Sep 06, 2009 | Magic Chef 31000 Gas Kitchen Range
Unlock my Tappan Gas Over Door?
Hi wewada,
Hope this helps.
Aug 03, 2008 | Tappan TGF320 Gas Kitchen Range
F3 error code
f3 is the code to replace your oven sensor most you replace by pulling the back panel and removing the scerws
Feb 17, 2008 | Maytag MGR5750 Gas Kitchen Range
Kitchen Ranges Logo
48 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
