Question about Canon PC1061 Copier
Unable to open to remove paper jam
How do i remove a paper jam
  • 734 Answers
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Posted on Dec 04, 2008
I HAVE A PRINTER BROTHER DCP-T700W AND RECEIVING PRINT UNABLE 35 ERROR MESSAGE AFTER REMOVING A PAPER JAM.
great day, unable to print 35 means, paper jam, first open the the scanner cover, and see the strip encoder, ( Transparent color) and clean it with a piece of tissue. thank you
Nov 20, 2017 | Brother Office Equipment & Supplies
PRINT UNABLE 70
You would need to remove jammed paper opening back cover.
Nov 18, 2013 | Brother Mfc 250c Clr Inkjet P S C F Usb...
I have a message on my display screen that says "unable to print 36" What does that mean and how do I fix it?
36 usually means that a paper is jammed. You will have to open it up and manually remove the paper.
Mar 22, 2011 | Brother MFC-845CW multi-function...
I HAVE A CANON PIXMA MP830 INK JET PRINTER WHICH HAS A PAPER JAM CAN YOU HELP
Here are the basic steps that can resolve your issue.
- Paper jam in the Paper feeder or in the output slot
pull out the paper slowly, if the paper tears open the printer cover(scanning unit) and remove the paper (careful not to touch any printer components) after removing the paper restart the printer, then redo the printing process.
-Paper jam inside the machine
Open the rear cover, if you seen the paper remove it, then close the back cover then restart the printer and redo the printing process, if your unable to get the paper from the rear cover, open the casette infront of the printer and slowly pull out the paper, return the casette and restart the machine..
If your still unable to get the paper,
remove the casette, stand the machine with the left side on the buttom (make sure its not the right side) pull out the paper while pulling the green cover toward you, return the casette, restart the machine and redo the printing.
If your having difficulties or still unable to remove the paper contact the canon support center in your area.
Here is a link where you can see visual step by step procedures.
I hope this will help you a lot.
Thank you for choosing fixya.
Mar 03, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Keeps showing follow instrctns in right cover to remove. Unable to copy
ther is a paper jam in the machine, open the side cover and remove the paper jam, if the paper is not visible then there is a small piece stuck somewhere.
Nov 17, 2010 | Ricoh Aficio 2015 Copier
PAPER JAM PROBLEM
remove power (turn off) machine, and open just to show the roller, and manually turn the roller just guide paper out.
Mar 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
We are unable to load the paper on our Sharp UX-266 as the paper jam sign comes on every time we try it .
Unplug the machine open all covers and check for paper jams, remove the paper draw check for paper behind the draw. load paper before pluging in
Aug 15, 2009 | Sharp Office Equipment & Supplies
Paper jam. caused error print unable 30
"Machine Error 30" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
Even a ripped part of a paper will be able to cause the paper, so it's important to be careful when taking jammed paper out to not rip the paper (do this by carefully pulling the paper among the same way as it would go when printing, not the opposite direction).
However, if that doesn't work, the error is mechanical (but still most likely caused by the jam, either a sensor getting dirty and unable to do it's work, or actually getting broken), and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Canon PC1061 Copier Logo
339 people viewed this question
old marine
old marine
