Question about Admiral AW22 Top Load Washer
My admiral washer fills but won't agitate' - Admiral AW22 Top Load Washer
Caused by damage to the sensor line attached to the drum. The damage occurs when the motion of the drum in normal action or when it's out of balance, rubs over a period of time against the metal edge of the hole through which it is fed to the back panel, cutting it in two. This is called poor poor design.
1> Remove the top back metal panel from the back of the washer. The sensor is immediately in front of you on the right hand side.
2> Insert a screwdriver between the top and base of the machine on the front and lift it up so you can see the drum inside. You should see a small water line attached to the base of the drum that runs to the back of the top panel and connected to the sensor. Where it runs through the hole to the back panel is where you should see the hole cut in the line.
3> Remove the line with wire pliers and take it to Ace Hardware or Home Depot and get a duplicate. Be aware of the need for the same type of line. If it's too hard you'll end up having to splice ends of the old line on to the end of the new so it will bind to the nozzles.
Posted on Sep 24, 2008
It won't turn on
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com Troubleshoot your Admiral Top Load Washer that has these following ... The machine will not complete cycle (fills but won'twash or agitate) I recalibrate it and it ... my washer will not startbecause of lid latch it is an admiral.
Sep 29, 2015 | Admiral Washer Control Panel Frame 35-5733...
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
WATER WON'T CUT OFF
Possible that the water level sensor has failed and so does not trip the controller to shut off the inlet valve. The sensor is a pressure activated switch and you must be able to track it down and test the switch to work with air pressure. If so the switch must be replaced.
Jun 05, 2012 | Admiral AW22 Top Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer won't fill. will only agitate or spin
Set the washer to the position where it should be filling up with water. With the solenoid leads unplugged check if its getting 120 volts to it using a voltmeter or a circuit tester. The solenoid I am mentioning about is the one that opens up to let the water into the tub. When 120 volts is applied to it the solenoid opens up the water valve. It is located on the back of the machine. Then we go from there.
May 28, 2011 | Admiral Washing Machines
I have a Admiral washer that fills with water but won't agitate
turn on your washer start programme while it is filling turn of power point if water still enters mchine you have a faulty water valve.if water stops there is a problem with the water level switch or hose that connects from outer bowl to pressure switch maybe perished or split.hope this helps you.
Mar 25, 2009 | Washing Machines
Admiral washing machine
Possible timer problem, timer reverses motor to agitate this is not hapeniing, check timer or wiring to motor.
Nov 02, 2008 | Admiral AW22 Top Load Washer
Admiral Top load washer won't agitate and squeals
Sounds like the gearbox, unfortunatly this is sealed and is cheaper to replace the machine, presume the machine is quite old.
Jun 28, 2008 | Admiral AW22 Top Load Washer
Admiral Washer model #LNC6757 will not agitate
Possibly a loose agitator, try lifting the agitator, if it lifts then it is un secure, remove the softener cap and down inside the agitator you will see the fixing bolt,
You will need to lift out the agitator to retrieve the bolt if it has come fully un done, refit the agitator and secure using a socket and long extension bar.
Apr 15, 2008 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
77 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
