Question about Lexmark X215 MFP All-In-One Laser Printer
Lexmark x215 paperjam #2
Cleared it out and still saying error
  • awvenning Nov 25, 2008
    Cleared all paper from printer. The paper came out completely. There were no bits left behind. Still get the message but can't see any paper.
    HELP!
  • 162 Answers
The exit sensor is defective if the paper has left the printer
completely but it appears
paperjam #2.
Once the paper has left completely, the exit actuator
must return to the original position to close photo sensor. Sometimes takes
more time than it had and it does not return.
The actuator can be deformed by the temperature.
Posted on Oct 19, 2009
Lexmark 5660 paperjam
printer says paper jam no paper in printer i have on pluged it to clear it and its continueing to say paper jam what should i do?
Oct 20, 2012 | Lexmark X5650 All-in-One InkJet Printer
Me salta error de calor abierto en la impresora lexmark x215, quiero saber si sustituyendo el fusor se resuelve el problema o es otro el motivo del error
Si se obtiene un error de calor abierto, significa que la impresora detecta que el termistor no está conectado o defectuoso.
Si el problema persiste la unidad fusible se ha sobrecalentado y necesitan ser reemplazados.
Para obtener asistencia adicional, póngase en contacto con asistencia técnica de Lexmark.
Feb 21, 2011 | Lexmark X215 MFP All-In-One Laser Printer
How to solve the error Lsu Error of lexmark x215.
Hi shirazsoleja
Unplug the power cord and plug it back in..If this doesn't fix the problem call service support in the U.S. or Canada, call 1-800-Lexmark (1-800-539-6275). For other countries/
regions, refer to http://support.lexmark.com.
Hope this helps cheers nikki
Please rate the answer. Thanks for using FixYa.
Jan 15, 2011 | Lexmark X215 MFP All-In-One Laser Printer
X215 continously displays paperjam 1, there is no paper jam,
I didn't have this exact problem, mine was a paper jam 0 error. The problem was caused by a spring that got old ended using one out of a retractable ink pen. Once you take the four screws out that hold the back plate on and remove it. When facing the front of the printer the left side where the handle is will push back and top can be pulled down to remove. Be careful this is where the speaker is located. The speaker is connected by a six inch wire that can be easily unplugged. Facing the side of printer that was just removed is a plate with 5 or 6 numbered screws only remove the ones that are numbered. This is the drive system for the paper tray and out feed. My problem was the cam gear located to the right of the plate that was just removed. It is like two gears made as one with a spring in the middle and two coils used as a brake for the in feed. I did notice on the left side of the drive system was a light that is used for paper detection pointing towards a photo eye. Most likely that light has burned out for you. There is a side diagram located at http://support.lexmark.com:80/perl/support/support.cgi?relevance=&ccs=229:1:0:393:0:0&mode=DOCS&doctype=topdoc&term=&docid=ENUS20058
Jan 22, 2009 | Lexmark X215 MFP All-In-One Laser Printer
Lexmark x215 using printer cartridge 18S0090
Continued to open and shut all covers eventually cleared
Jul 10, 2008 | Lexmark Office Equipment & Supplies
LEXMARK X215 MFP ERROR MESSAGE
press menu-#-1-9-3-4 with the copier on enter in tech mode. press menu and scroll to new cartrige; select yes. press again menu-#-1-9-3-4 to exit service mode (do not modify other item; your machine will broken!)
good luck !
bogdan_enache89@yahoo.com
Apr 01, 2008 | Office Equipment & Supplies
Lexmark x215 printer/fax/scanner
I have an X215 also. It is not built to suit a duo line hence no fix is available.
Feb 07, 2008 | Lexmark X215 MFP All-In-One Laser Printer
Lexmark X215 Drivers
I lost installation CD's , I need to download drivers.
Jan 04, 2008 | Lexmark X215 MFP All-In-One Laser Printer
Lexmark X215 MFP All-In-One Laser Printer Logo
253 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
