Question about Toshiba DKT-2020 Corded Phone
Resetting the voicemail
How do I reprogram voicemail??
  • 31 Answers
Can you please clarify so I can better answer your question?
Posted on Oct 11, 2008
I have ZTE MUVEAfter programming my voicemail and follow the instruction, every time i try to access to my voicemail it brought me to the direcction to reprograming voicemail again.
I am guessing you do have a voice mail subscription and if I am right, the issue could be with 'zte'. Not the best phone out there.
Apr 08, 2014 | ZTE Score
Nortel t7100 voicemail
have your in-office phone tech fix it or reprogram it for you..
Jan 07, 2014 | Lands Phones
When i select my programmed check voicemail button i get an error of "not in service". how do i fix this and re-establish it as the check voicemail shortcut?
Try Feature *3 - press the button you had programmed of check voice mail - the press Feature 981. This should reprogram your button.
Aug 20, 2013 | NorStar T7316E Corded Phone
How do I set up my voicemail box on my mytouch 4 g I access my voicemail it tells me to press star and then enter my 10 digit phone number. the prompt then number not recognize
If your number was changed then you will need to have a master reset on your phone which will take your phone back to factory settings then you will need to reprogram your phone with the right phone number. You should always make sure through your cellphone company that they have the correct phone number listed.
Oct 10, 2011 | Cell Phones
Voicemail retrieval issue on my treo750
Your voicemail number on your phone is usally different than your own number. It's called a "retrieval number" which your provider has. You will need to contact them and get this number and they should be able to assist you with reprogramming the number into your phone. Hope this helped.
Apr 17, 2010 | Palm Treo 750 Smartphone
How do I reprogram the main message on my Lucent Partner 18D and how do I access a line where my employee quit, so I can get her messages?
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234. If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. ,3 for greetings, 1 for auto attendant number, 1 for day greeting 2 for night( if your using a night key at the receptionist station then it usus the night greeting) # to go past selector codes, 1 to start recording 3 to accept greeting hang up when done.
As far as the employees voicemail messages, while in the voicemail administration you can reset her password in the "administer mailboxes" prompt which is either 2 or 4 depending on the voicemail type you have. that will reset her password back to 1234.
Apr 13, 2010 | Lucent PARTNER18 Corded Phone
How can I reprogram my voicemail speed dial in spot 1? Right now it's set to go to ''youmail's'' voicemail and I want it to got to ATT voicemail. I have a Samsung BlackJack 2
the way it is it cannot be reprogrammed because its in the hardware of the phone and cannont be changed sorry hope this was helpful:)
Sep 13, 2009 | Samsung BlackJack II Smartphone
Locked out of voicemail box!
Hi there, let me give this a crack at it...
The Telephone system sounds like a Norstar BCM... what Consultel1 gave you as an answer is correct, for a Norstar Key system.
OK, do all that Consultel1 stated: -> FEATURE 983 -> You will now see LOG:type in 738662 (SETNNA) and press OK -> You will now see PASSWORD: type in 266344 (CONFIG) and press OK -> then you will see the ADMIN and the options for MBOX, AA, OTHR
Now follow Consultel1 advise on changing Voicemail Passwords, from his orginal post.
Good Luck!
Sep 02, 2009 | NorStar T7316E Corded Phone
Since power outage phone lines do not ring - only to receptionist
Your system lost its programming. It will need to be reprogrammed completely. The lines are ringing on the extensions where I voicemail is, unplug voicemail and at least lines will ring in correctly.
Jun 15, 2009 | Avaya Lands Phones
Voice message, reprogramming extensions
How did you program the voicemail so a caller can not leave a voicemail to a particular extension? Line ownership? SO a call goes directly to a milbox?
How can you reprogram the voice message????? Which one, for a particular user or the main Auto attendant greeting????
You have to know the admin login to change a mailbox password.
For that, you need to know which voicemail system this is.
When you log in to check your mail, the lady says, "welcome to Partner......"
Please fill in the blanks.
Nov 18, 2008 | Avaya Lucent Partner 616 Phone
Toshiba DKT-2020 Corded Phone Logo
147 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
