Question about HP Pavilion a305w (DM181AR) PC Desktop
Pc connention the cord that goes from the monitor into the pc and has the two screws on each side (mines is blue) well i went to pull it out and one of the screws i had not unscrewed all the way and i PULLED and the connection will no longer connection a little blue message pops up on the monitor that says PLEASE CHECK CONNECTIONS. and i tried to manuever it back in place but, the whole little metal frame in the back i think has to be removed. CAN IT BE FIXED????
    Scholar:
  • 68 Answers
Definitely it can be fixed.....in order to remove that blue plug.....first you have to unscrew the two screws in that blue plug....then it can be taken out....that message is coming on monitor because that plug it not properly connected to pc.....to solve this....you have to take that plug out first....that i told you above how to take that.....then you just put the plug back into the slot....then tighten the two screws in that plug.....thats it....your problem will be solved... i am a software engineer and i have experience in these areas......try this....it will work 100%......
Posted on Sep 23, 2008
  • 661 Answers
Sometimes graphics cards are only "clipped" in place internally, it sounds like the card is now not seated fully down in it's slot, probbably all that needs to be done is the card just needs reseating into it's slot, this can be done easily, however opening your computer can invalidate your warranty
How do i unplug big blue cord on tower emachine
You do have to unscrew the two screws on either side of the plug to remove the cord. Hope this helps.
Jan 01, 2014 | E-Machines eMachines Desktop PC
I can not turn off the sleep mode on my LG Flatron monitor W2361VG-PF
This monitor has a manufacturer's defect in two of the wiring harnesses: the harness going from the controller board to the power button (4 grey, 1 blue wire) and from the power button to the side controls (3 grey, 1 blue wire). Open the monitor (snaps apart, no screws) and gently tug on each wire individually. One of them is causing the problem. You can replace the harnesses, try to fix them, or solder new wires directly to the pins.
Feb 16, 2013 | LG FLATRON W2361V 23 inch LCD Monitor
Husqvarna 345 decompression valve
The345 should have a blue push in deco valve on the r/h side of the cylinder, if not there may be a 13mm blanking screw there, this can be removed and a deco valve fitted.
Dec 24, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I am having a problem with the dvd player (rse unit) in my 2006 Terraza. How do I remove the unit from the overhead rack. I don't see how the cover comes off and there are no visible latches or...
open the monitor so it is down behind are two screws up in the monitor behind it remove the two screws pull it down and out there are two hooks in front opposite the screws once you pull it out disconnect the cord i have problems with mine no video but sound i replaced the lamp in the monitor but that was not it
Jul 31, 2011 | 2006 Buick Terraza
Need to remove front bezel to install a touch screen panel onto a samsung 226bw monitor, cant figure out how to seperate the parts
- This is how it went for me..I have a Samsung2.gif SYNCMASTER2.gif 2053BW. I leave my monitor on and let it hybernate when I shut down PC. I'm 3 months outside of my warranty. Two weeks ago something started happening. I boot PC and video doesn't come up for 10 minutes, and when it came up it worked perfect. VC/Monitor/MB?? It became 20 minutes and ...now..I have the analog/digital box in top left screen, power light on monitor flashing, no menu available on monitor and none of the other buttons work for anything. I test the monitor on Laptop..nothing(same as above)..I break out the old(working) monitor from deep within the closet. Plug it in and I'm up and running. So...
HOW TO OPEN A SYNCMASTER2.gif 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable, two clips super close to where the sets of wires come around the housing and into the panel.Unhook the 4 plugs(pink inside/blue outside)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.56ec44b.jpg
Reassemble but DO NOT re-snap the frame into place....yet... Test it! There is a reason the caps got hot in the first place, therfore it has a good chance of happening again. This is not fullproof...but.....mine has been on now for a day with no glitches whatsoever. So I have resnapped mine back together. I hope you can too. - I must also add that this is one of the best producing monitors I have ever seen...in 60hz. The clarity is top notch. If you purchase one get the extended warranty. FYI...I paid $4.00 for those caps
Sep 15, 2009 | Samsung 226BW Monitor
The power light blinks solid blue every four seconds or so (it?s off in-between). The screen is blank. None of the buttons on the side function (such as ?menu?). I have a second similar monitor from the...
Two days ago I received a Gateway 900w FDP1975W Monitor from a friend. He told me that he would have to let it rest and it would work for about a hour or so and flash green with lines, then Flashing blue power light, then nothing. I have seen this problem on several LCD monitors, including Dell and Sceptre. The problem with the blue power light on/off is with the power supply inside the back of the monitor. The manufacturer runs so close to the minimum that these power supplies burn out in about 2 years. I am typing this messege using the very same dead monitor. How you ask? You must remove the trim from around the out side of the monitor - this one had two(2) screws in the back. bottom, outside corners then the trim can be pried off (dissconnect power button cable) - then you must remove the LCD screen four(4) screws in the 4 corners. (remove with caution - lay it face down on a flat surface with soft cloth or towel - do not break LCD) lift up LCD (a little) from plastic case and remove two pairs of blue/pink wires connected to side of power supply.(these are in two sets of four - two connectors at topside and two connectors at bottomside - make note of which goes where - you must depress cliplocks to unclip) Lift a little higher and remove the main cable from back of power supply. Remove LCD to a safe place. Unscrew three(3) small, four(4) medium and one(1) large screw from the power supply cover and remove. The power board will be on top of the control board, remove four(4) screws holding down the power board and pull up to disconnect from control board (careful the power cord socket connection HAS to slide straight up out of its holder!) Then remove screw holding ground wire and remove the power board. NOW WHAT, do you say? Look at the Capacitors - on mine, it hade 4 680uf@25volt 2 470uf@25volt 3 220uf@25Volt 1 10uf@50volt and 1 22uf@50Volt . The 680,470,220 were all swollen (shorting/shorted) This probably happend because one of the small 10 or 22 control caps were going (high resistance) I went to radio shack and got 35volt (yes they fit and yes they work) 220, 470 and1000 (Yes 1000 fit and yes they work) (Think of capacitors as a glass of water - when they filter the power they fill only to the charge of the rail - This case 20volts (35 gives more space) and the MicroFarad uf to the use of the circuit - now I dont know all about electronics - but the small caps that control the rail MUST be the same 10uf - 10uf 50volt - 50volt (they control the circuit power and their values are designed into the circuit - but the large ones filter the power and in this case, are limited only by the space they have to fit into and cost of the parts - but these can be upped) Now with the larger 1000uf caps and the 470/220/10/22uf all replaced (I replaced the 10uf ad 22uf control caps because this is what probably caused the overvolt/overheat (they didnt show bad - just replace them all!) Cost $13.00us - Put all parts back together - Power board ground wire & screw first - slide power board power cord socket down and connect the 8 -10 pin connector and push down firmly - put back the four(4) small screws and replace power supply cover - put back the three(3) small and four(4) medium and one(1) large screw - reconnect the main connector and the two upper and two lower side connectors. Place LCD all the way down on the cover and replace all four(4) corner screws. Plug power button cable back in and rest trim on top of monitor - Plug power cord in to test - blue light should come on and stay on 'Gateway' logo should flash - then with no signal should go to amber - test with computer - If you soldered all your connection correctly - the monitor will work as good as new!
Einstooge.
Aug 17, 2009 | Gateway FPD1975W 19" LCD Monitor
Has a cord that has the same type of connection on both ends
Look on the back of the emachine, there should be a blue connector with 15 holes in it. Thats the VGA connector and thats where the other end of that cable goes.
May 31, 2009 | E-Machines eMachines Desktop PC
TFT monitor went dead
Hi
How old is your TFT Monitor?
It looks like the Monitor has got some problem.
First, make sure the cables are connected correctly.
Try Changing the connecting cable (between monitor and pc) with another one.
Try using another monitor with your pc & using same cables.
If the problem persits, pls try your monitor on another Computer.
This is all what you can do, if the problem wasn't solved, then maybe the problem is in the monitor that you need to take it to a specialit to repair it for you.
I hope my steps were helpful.
Nov 06, 2008 | Computers & Internet
Lcd monitor goes white
The E151FPb's seem to have a problem of this sort. After doing some research online I've found that the most common problem is a few dry solder joints on the large circuit board inside the monitor. There was also some talk of a connector suffering from heat creep that sound be connected better on the inside, but usually that would make the screen turn black if it were to become disconnected. The monitor can be opened by unscrewing all the screws on the back, there should be 6 screws you need to pull out before being able to open the case. After those, insert a thin, but strong piece of metal into the side and sort of twist/slide it along the side and it should pop open some clips and just work your way around the perimeter. After that it's just some simple and obvious screws to get to the circuit boards.
Apr 11, 2007 | Dell E153FP 15" LCD Monitor
HP Pavilion a305w (DM181AR) PC Desktop Logo
125 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
