Question about M-Audio Audiophile USB Audio and MIDI Interface (Macintosh and and Windows) External Sound System
Toshiba A205-S4707 audio dropouts
I'm running a Toshiba laptop A205-S4707, Cubase SE, Alesis io/26 controler,using a FreeAgent Tera byte external hard drive 7200 bps for storage.
During recording my audio from other recorded tracks dropout intermitantly.
I have also tried Audacity and it drops out also.
I've went from 24bit to 16bit, lowered the color resolution on my monitor, turned off my battery monitor, networking and camera in device manager, and I've adjusted my sample rate all the way down and all the way up!
Tried mixing down all tracks to one track then importing it and recording another track with it but it still drops out at different times?
Thank you for your help, I've spent hours online trying to find help.
I finally don't know what to do.
John
  • jjk748 Sep 23, 2008
    Forgot to mention I'm running Win XP Pro and the Alesis io/26 is firewire
  • geoffrey884 Nov 10, 2008
    Mine is an A205-S5804, and with that Alesis IO26, the dropouts exceed 60% at any latency setting, quite useless. Latency check shows up fine. The IO26 works flawlessly on my other computers, one of which is a P3-800 with 256MB ram !!!
    I believe the problem is that toshiba puts a shared IRQ between the Video and the expresscard slot, and windows will not install on a non-ACPI HAL on that machine, I think thanks to that SATA controller, so you can't change the IRQ = we're screwed. My final e-mail from alesis tech support was one of resignation on that computer.
    In the end, I gave up, and started using the forementioned P3 minitower for mobile recording
3 Suggested Answers
SOURCE: After I record an audio
JE VOUDRAIT INSTALLER DRIVER CARTE SON ET AUDIO POUR MON MICRO ORDINNATEUR
PORTABLE AMILO PRO V 8210
Posted on Sep 30, 2008
  • 26 Answers
SOURCE: M-Audio Fast Track Pro
I guess if your still looking for an answer your probably desperate. Never the less, if someone else is looking for an answer you need to select FT Pro in the preferances. Basically, you have to tell the software what to record and when. Pretty easy really.
Posted on Apr 14, 2009
How to fix TBX Error on Toshiba Satellite a205-s4707
Take out battery from it, and re-insert it after 15 minutes or so. This must make it a hard reset. If it too doesn't help you, make sure there is a software corruption has been occurred. Re-install the O/S is the only solution. Electro help
Jun 06, 2014 | Toshiba Satellite A205-S4707
Toshiba a205-s4707 will not boot windows from any location.
You didn't mention the DVD/CD rom? Shut down, unplug, remove battery, plug in reboot and try this procedure: http://www.ehow.com/how_5766144_restore-satellite-laptop-factory-disc.html
Dec 16, 2012 | Toshiba Satellite A205-S4707 Notebook
Toshiba Satellite A205-S4707 Boot time is to long need help
you may need a fresh install of the OS, maybe upgrade the ram to 2-3gb, or the worst case factory discs for series model laptop.
Oct 19, 2012 | Toshiba Satellite A205-S4707 Notebook
Can i attach an external usb hard drive to a toshiba lcd tv
The usb external hard drive was designed to work with windows operational system giving access to all the files, attaching the hardware would give limited use at best and may not respond.
Apr 22, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hello all! I have Toshiba Satellite a205 s4707, with Windows 7. It has latest Toshiba drivers, bios is after update, but I can't run camera. I tried everything that I found on the internet but non...
Go to toshiba.com and download the correct drivers plus the updates. Any other problems use the phone number on the web site for technical assistance.
Toshiba have got it right.
Jan 17, 2011 | Toshiba Satellite A205-S4707 Notebook
Toshiba Satellite A205-S4707 ethernet connection issues
Try this:
Open a command prompt. If it has been opened before you should see it on your start menu. If so , RIGHT click on it and select Run as Administrator.
If it is not directly on your start menu , go to Start > All Programs > Accessories > command prompt and do the same.
In the command prompt , type "ipconfg /release"
without the quotes of course.
Then type in "ipconfig /renew"
You should have an IP Address now.
Type "ping www.google.com"
you should get something like this:
Pinging www.l.google.com [64.233.169.104] with 32 bytes of data:
Reply from 64.233.169.104: bytes=32 time=15ms TTL=247
Reply from 64.233.169.104: bytes=32 time=14ms TTL=247
Ping statistics for 64.233.169.104:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 14ms, Maximum = 15ms, Average = 14ms
You should have 0% loss. If not , something else is going on.
Otherwise , try your browser now and you should be able to connect.
Mar 03, 2009 | Toshiba Satellite A205-S4707 Notebook
On my Toshiba Satellite a205-s4707 dvd player not working
Allright this one can be tricky so we need to isolate the problem between software and hardware.
First, get into the bios and see it's being detected.
If not then turn off the computer and unscrew the drive from the laptop, MAJORITY of laptops only need to have one screw unscrewed to release the drive. If yours doesn't then you'll have to do a little more work, let's just assume you have the majority for now.
Next, pull the drive out, feel free to give the back connector a quick puff of air, now carefully place the drive back into the laptop so that it's nice and tight.
Check to see if that solves your problem.
If not we'll try something else.
Feb 22, 2009 | Toshiba Satellite A205-S4707 Notebook
Freeagent
Turn off computer.  Unplug hard drive from computer port.  Turn on.  uninstall from Add/Remove Hardware in Control Panel.  Reboot computer.  Plug in external hard drive.  Verify Full System functionality in Control Panel, System, Hardware, Device manager.  If nothing is expanded all IS functional.
James Mac
Sep 08, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Open Questions:
M-Audio Audiophile USB Audio and MIDI Interface (Macintosh and and Windows) External Sound System Logo
94 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
