Question about Brother Office Equipment & Supplies
Brother mfc 7420: dust on drum error. - Brother Office Equipment & Supplies
  • 320 Answers
SOURCE: my brother 7420 MFC has
take the drum out and clean the grid on the drum unit. this is called the corona wire in the grid
Posted on Jan 14, 2009
jtuminaro
  • 56 Answers
SOURCE: Brother MFC 7420,SAYS DUST ON
Dust on drum is an issue with the corona wire. Use the blue tab on top of the drum unit. Slide it back and forth 10+ times and this should correct your issue.
Posted on Jan 15, 2009
jtuminaro
  • 56 Answers
SOURCE: RESET DRUM
Open the front door where you put the toner/drum unit in the machine. Press options then press 1.
Close the door.
Counter reset!
  • 320 Answers
SOURCE: error 2001 on brother mfc 7420
please tell me more! i just checked my brother manual and i do not see a error code 2001????????????
Posted on Feb 16, 2009
pineworks
  • 4041 Answers
SOURCE: brother mfc-7420 - unable to print
OK Try
Solution:
  • Machine off
  • Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
  • Press 80
  • Press the “mono start” button several times until you see “purge: xxxx”
  • Press “2783” in order to reset the purge counter. You will see: “purge:0000”
  • Press the "stop" button.
  • Press “99” to exit the maintenance mode.
All the best
Posted on Jan 30, 2010
Brother MFC-7420; "Take Drum out; Slide blue tab..."
go online type in Brother MFC-7420 reset and follow details
Jan 30, 2013 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 change drum soon light, did, still says change drum soon, how do I rest the drum, I cannot find my manual. Tks
Simply open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
This procedure wil work on the majority of the Brother MFC series of laser based Printer Scanner Fax Facsimile machines.
Good Luck and Thank You for using Fixya
WheatlandServices
Nov 05, 2010 | Brother MFC-7420 Printer
My drum is dusty. How do I get the dust off?I have an brother mfc 7420
Jul 23, 2010 | Brother MFC 7420 All-In-One Laser Printer
Drum en soon MFC 7340
The drum counter counts to 15000 then says replace drum soon. Just open the front door and press options. Select yes.
Feb 03, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 screen displays "Back Door Open" have cleaned etc. Can you help ?
Remove the drum and toner (cartridge), look inside the machine, there should be a piece of paper, remove it and error msg should go away.
Nov 08, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420 prints black pages
The drum is defective. The cleaning blade has failed.
Jan 31, 2009 | Brother HL-2040 Laser Printer
Brother Printer MFC-7420
Open the front cover and take out the toner/drum unit. On the top of the drum unit you will see a blut tab that you can slide side to side. Do this 10+ times and this should fix your issue. Make sure to put the blue tab back in the original start position which is believe is to the left on that model.
Sep 06, 2008 | Brother MFC 7420 All-In-One Laser Printer
328 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
