Question about Dell E177FP LCD Monitor
Dell Monitor won't stay on
I have a Dell computer monitor that comes on for just a second when turning it on and then goes back off. Do you know of anything I can try?
  • beardbase Oct 13, 2008
    I had my monitor set to hibernate, so my light turned yellow after 20 minutes, however, when I move my mouse or hit a key, the monitor flashed my desktop and blacked out, so I set the monitor to always on. This time it would go dark like it was hibernating, but the light would stay green, and the end result would be the same as before. I turn the monitor off and do a hard shutdown on my system, give it a ten count, restart, and the monitor comes back on. Again, however, the screen flashes through the post and boot sequences, instead of displaying the GUI the way it should. It will all come up finally, and continue to work fine as long as I don't allow it to sit. This is frustrating! Any ideas anyone?
    Novelist:
  • 180 Answers
When it goes black, does the power buton stay green or is it orange? If it's orange, the power supply/inverter is your main culprit. If the power button stays green, it sounds like the backlight for the display is bad. Either way, unless you have parts for the same monitor laying around to swap out, you're due for a new monitor. The good news- with the economy in the tank, you can search online and find some reputable vendors selling nicely sized screens for less than $100! Heck, I've even seen a 22" for $129 (once but it was there).
Posted on Feb 14, 2009
Dell st2410b monitor won't stay lit
Ok, same issue here as well. Monitor would come on for 1/2 second and then the backlighting will go off. It's next to impossible to tell, but if you shine a bright flashlight at the screen, you can make out the video signal/desktop.
I have now replaced all the Capacitors except the very large one (didn't come with the kit that was available.) None of my caps looked bad (bulging) including the large one. Unfortunately, I still habe the same issue
So my question is....large capacitor replacement or something else?
Nov 29, 2012 | Dell ST2410 Monitor
Are soyo monitors compatable with dell computers?
try running it in safe mode tap f5 when you see the dell screen. if it boots to safe mode remove the driver for the display adapter in device manager. the dell computer doesn't know what kind of monitor it's plug into. install the soyo monitor driver
Jun 13, 2017 | Computers & Internet
Monitor comes on but then shuts off in about a second
Try reducing the resolution (boot at safe mode)
Stelios.
Feb 22, 2010 | Dell UltraSharp 1908FP Monitor
My monitor goes blank after a few seconds of turning my computer on. I turn off the monitor & turn it back on again and it only stays on for a few seconds thanks
It basically goes to Power Save Mode. Check for the same error in System Setup screen, if the Monitor goes off in System Setup then you better need a replacement. Else you would need to reseat the Video Card(If any) and the Memory Modules. Please keep posting for any further issues / improvements.
Dec 30, 2009 | Dell Computers & Internet
Monitors comes on for a few seconds then goes black. the only way is to turn it on and off but still only stays on for a couple for seconds
I think the power board might be going bad in there. Hook up a different good working monitor to the computer and see what happenss.
If the monitor still turns off after a few seconds then you know its the video card acting up. If the monitor stays on then you know its the original monitor that is bad for sure.
Jul 03, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
My E172fp has a blank screen...when i unplug and plug it back in,the "dell dimension" or whatever that logo is comes on for a second, then the screen goes blank and stays that way.another monitor works...
i have the same issue before with my DELL 2001FP, I replace the 3 capacitor on the board that look like defective because the top is look like swolen, it should be flat. I replace it with the same value and now the it works better.
i hope this might help .
Feb 25, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E156FP Monitor Problem
If the screen is not completely black (i.e. just very very dim, turn the lights off to see) try using the controls at the bottom of the monitor to reset to factory settings (all settings). I have had this problem with two dell monitors so far and this seems to work.
Jan 08, 2009 | Dell E156FP 15" LCD Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Dell SP2208WFP Flat Panel Monitor flickers out and goes black.
Hi again,
Any luck with the Dell people?
A favor if I may, at your convenience, would appreciate if you can rate our Live Session as you see it fit.
Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 05, 2008 | Dell 21" M1110 .22DPI 1600x1200 *SUPER...
Problem with dell lcd monitor
Frt. Power button control board shorted. Part# 715L1153-1A
Apr 29, 2008 | Dell E173FP 17" LCD Monitor
Dell E177FP LCD Monitor Logo
3,658 people viewed this question
Alun Cox
