Mitsubishi TV CS-3503R
I know its an older set but is in great shape so im trying to save it for another 2-3 years if I can.Im trying to locate the vertical output ic in this unit.I have no idea what im looking for or where to start.Thanx for helping.
  • 934 Answers
SOURCE: Samsung Rear Projection HD tv IC convergence green only messed up now. Help please
To check the pico fuses you're merely testing for continuity. If you get an infinate reading you're in good shape - if it doesn't budge the meter the fuse is open... That's a really easy set to work on for convergence problems - the convergence board is easily removed..
Another cause for mis-alignment like that are the youke return resistors... There are several out front of the convergence amps that may have changed in value. They are 3.9 ohm - 2w resistors and will look identical to Rz123 and Rz124 (same banding). For those simply select a low ohm setting on the meter and check to see if any of them have some way low or way high reading...
Need anything else just ask...
Posted on Dec 10, 2007
  • 14 Answers
SOURCE: Phillips 60PP920217F Convergence Problems
I have the same set and just fixed this problem toinght! I bought a couple of STK392-120s for $20 from and with a soldering iron, heat sink compound and a solder sucker was able to do the job myself in a few hours. I did purchase the 6.8 ohm resistors too, but they all checked out find so I didn't replace them. There's a great site online at that shows you the ropes, just not for this exact set. Once I did a multipoint reconvergence, the HD looks like new! This is at least a $600 service call from what I can gather, and if you're handy you can fix it yourself.
Posted on Jan 14, 2008
  • 8617 Answers
SOURCE: TELEVISION (mitsubishi model CS-3503R 1988)
your vertical output IC is either defective or needs re-soldering
Posted on May 04, 2008
  • 927 Answers
SOURCE: vs-45607 Vertical Hold Problem
Good Day; Just replace the caps first, 99.9% fix if not replace 9v regulator. Good Luck, big IRISH.
Posted on Nov 24, 2008
  • 10594 Answers
SOURCE: panasonic pt-53wx53g vertical output ic
IC451 (Vertical Output) LA78045 part number is C1AA00000521
Available in Part Store.
Above info are taken from related service manual and an image of s.manual is given below...
Posted on Jun 19, 2009
Where is a manual for a mitsubishi CS-31205 tv?
The manual for Mitsubishi TV model CS-31205 can be found by clicking the link below (Although the link says "CS 31305" , other models such as CS-31205, CS- 31309, and CS-31304, will use this guide as well)
Download Mitsubishi CS 31305 Owner Manual
Available for download (and offline viewing) in PDF format with a very short registration, or bookmark in your browser, and utilize online.
Or click below to visit the very useful website (the library is large, yet easy to use).
ManualsLib Makes it easy to find manuals online
(*just read this 2 year old question today- hope the OP found resolution)
May 25, 2012 | Mitsubishi CS-31205 TV
Hey Sir how is Doing? Im Great Thanks GOD. I have LG CE0168 Cellphone I was Bought Before 6 Months New Brand But I Have warranted For One Year But Im Not Live That Country far From There.... Now Im Here In...
Hi, your problem to your LG CE0168 is Touch Screen sometime malfunction and hang up and have a year warranty,please try my advice, you try to reset your cellpone and maybe is full memory to your cellphone.before you factory reset to your cellphone first step you need to back up your files to your cellphone 1.contacts-you need to mark all and copy to sim memory, 2.picture,music,video if save the phone memory you need to mark all and copy to memory card to save.second step after your back up all or save your files now you go to the phone setting and select the restore setting and the default password 0000 and after you type the password the cellphone is automatic restsart and after you success restore you need to pull out the battery and sim and memory card after a few seconds you back in the simcard and battery,memory card to your cellphone.i aware you if the cellphone restore is back the normal sorry to my poor english and i hope you understand to my advice and i hope that i help you.thank you.
Jul 22, 2011 | Health & Beauty
Mitsubishi CS-35301 35 in. rear projection. can't switch inputs
if you have s video connected some tvs wont allow you to use input 1 or 2.disconnect s video cable and try that other wise you got something wrong.
Apr 25, 2010 | Mitsubishi CS-35305 TV
Cs-36509 mitsubishi tv has a flicker.Makes it hard to read words. Is real bad when you first turn the tv on, but after a minute it settles down, but is still there all the time... any suggestions?
Yes first it may just be bad solder on the
flyback transformer , or the Picture in Picture
module has some bad caps . a fair shop
price is about 180-200 and it worth the repair
they are great TVs and are made to last.
ps i have repaired my mitsubishi once , and
its going strong. 18 years old .
Mar 25, 2009 | Mitsubishi CS-36509 TV
Older projection tv won't turn on.
id replace the tv its 15 years old and past the livlihood they usually have. it would cost more in parts to repair it than to go out and buy a new one. im sure you probably already know that though. have the tuner checked but i dont think it will save the tv but if it comes on when the cable box isnt hooked up then the problem could be in the tuner. its hard to tell. the tuner is about 100.00
Dec 29, 2008 | Televison & Video
My misubishi diognostic
unplug the convergence yoke plugs all three and try powering up the set. then let me know if it powerd up. Please reply to this same post when responding.
Jul 27, 2008 | Mitsubishi WS-65513 65" Rear Projection...
No power at all.
HI,IM JOHN FROM PHILIPPINES IM A TECHNICIAN,the problem with your tv is ethier the power ic,,fuse..capacitor,,or the circuit protector diode R2KY,,R2KS
May 26, 2008 | Mitsubishi CS-40503 TV
Mitsubishi VS-60705 Horizontal Hold issue. Hi, I have a projection TV thatis about 7 years old. I moved and recently hooked it up after sitting for 1 year. It worked great. 2 weeks later I turn it on and...
Dec 17, 2007 | Mitsubishi CS-35707 35" TV
Mitsubishi CS-35305
334P24201 is the part number. There are alternative numbers 334D100018 and 334P24201(0) which Mitsubishi state as an alternative. You can get these both on; or (second one specifies is in stock) There are many more - please ask again with details of where you are if you would like us to find the best option. Hope this helps :)
Aug 16, 2007 | Mitsubishi CS-35305 TV
Televison & Video Logo
Top Televison & Video Experts
