Question about Dacor MCS130 Millennia Electric Single Oven
Dacor oven light
The oven light goes on and off constantly. it makes the most annoying clicking noise and this happens randomly. sometimes for a hour or better. i have tried holding the light button in but that dosen't help. it starts up again. any suggestions before i call a repairman who wil probably charge me $200 or better? thanks, I so appreciate your sugestion.
  • 1 more comment
  • mebfleming Dec 26, 2008
    The oven light goes on and off constantly. i see that the solution is to replace the front control panel. If this is correct - this will be the 3rd time (in 6 years) the front control panel has had to be replaced - previously it was because of shorting which caused an F2 error and high-pitched warning tone. This all seems to be because of very poor design by Dacor - the front panel is not protected properly from moisture getting in from outside and damaging the circuitry.
    I will never buy a Dacor stove again - poor quality design for a very high price.
  • jjms Jan 04, 2009
    Had the same problem and yes the service charge was $100 to just show up. Solution was replace the pad for $500 or just disconnect it so I had no light at all. Choose the former solution figuring the light in the kitchen would be enough. Can't wait to get rid of these ovens.
  • Franca Sep 27, 2012
    We had the same problem, except it went on for a few weeks until the lights finally blew out. The clicking is still hapening even with no lights in the oven. The repairman to day said it was likely the relay board, but he did not sound like he was really sure. He's going to get back to me with an estimate, any feedback on relay boards?
Open the over door. Remove the four screws holding in the digital display. Pull it off (have something to stand it up on). Look for the small ribbon going between the printed circuit board (PCB) and the digital display you just removed. Pull the ribbon out from the connector on the PCB. On my model, ECS127SBK, push the three right pins down, and re-connect with just the two left pins. Other models, may be different, so you may have to test it out. Be sure to turn off the power at your breaker box while working on it. You won't have the use of the lightbulbs anymore, but you won't have the damn ticking either! (And you'll save yourself getting ripped off from a technician.) I'm not very skilled when it comes to this stuff, so if I can do it, you can too!
Posted on Apr 08, 2010
I had the same problem. It was covered by my service plan but required replacing the whole front control panel.
Posted on Nov 03, 2008
My wall oven is making a constant unusual noise
Without a model number its hard to be exact. If your oven is older it will have a clock timer motor that turns the dials or flips the clock display cards. This timer has gears and bushings that will be annoying as they wear and start a vibrating hum or clicking-usually not worth tinkering with..it can be taken out and checked or replaced. Electronic timers of course don't have any moving parts to the timer, but have relays in the circuit to turn the oven on and off. They do not 'whir'. This is the likely issue.
Repost..let us know.
Apr 28, 2015 | Ovens
Interior light blinks on and off quickly
Possibly needing to screw them in a little tighter, please disconnect the mains power before doing so
Jul 06, 2014 | Dacor ECD227 Epicure Electric Double Oven
My friend pressed self clean on the oven and the oven said it turned off how do I turn the oven back on. I can't click bake but I can just click light.
The self clean cycly lasts several hours during which time you can't open the oven or turn it off. You will just have to sit and wait.
Sep 18, 2010 | Dacor ECD230 Epicure Electric Double Oven
Put oven through self clean for 2 hours. Oven
What has happened is IF the temp gets to hot in the electronic controls area, an in line fuse/limit burns out and shuts down everything.
I have a DACOR tech sheet HERE
So what I think is happening is the in line fuse in the wiring harness could be blown. You won't know till you or someone checks.
Jan 15, 2010 | Dacor Ovens
My DACOR + ECS 130 covection oven light relay keeps clicking.....
I have the same problem and sent an e-mail to DACOR. A James Carlos responded and advised that DACOR could not provide DYI info because of liability problems, pure BS in my opinion. I've had problems with a DACOR microwave (manuf. by Sharp), my DACOR wall oven Model ECS103 and my DACOR Raised Vent system and told Mr. Carlos so. I don't know how to fix the blinking oven light other than cutting power at the circuit breaker panel or removing the two light bulbs which other have advised but suspect a new front control panel is required. If you find a fix, please advise me at bsquared37@yahoo.com. I think DACOR products are overpriced and junk.
Thanks, Bill 12/10/2009
Aug 27, 2009 | Dacor ECS130 Epicure Electric Single Oven
Switch problem?
click here sir
there select range/stove/oven
in that select switch
after doing that see for the 3rd part.
this is the light switch you need.
replacing it is not very tough. but it is not that easy also.
since you are going to work near circuit boards this must be done carefully. if any small mistake will cause more problems.
everything depends upon your expertise sir.
thank you
Aug 15, 2008 | Dacor MCS130 Millennia Electric Single...
Dacor CPO130W F4 fault
f-4 on decor ovens mean the oven temp sensor is bad. replace the oven temp sensor and it will be fine
Nov 27, 2007 | Dacor ECS127 Epicure Stainless Steel...
Dacor MCS130 Millennia Electric Single Oven Logo
660 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
